07-01-2011, 10:11 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: BHARAT Age: 42
Member: 823633 Status: Offline Thanks Meter: 1,705 | hi bro moulnisky i am try flash 5300 rm 146 but only show nokia here i am full backup store after full eres flash lettest v rm 146 write backup but show phone imei is 1234560654321? here i am bull backup store here here my backup RM-174_356300012683714712011_23542 PM.rar but i am try flash rm 174 flash this v but phone imei back here but lcd show half here please tell me what my phone prob here i am all reay post atf section but not solve here http://forum.gsmhosting.com/vbb/f609...-help-1296225/ |
07-01-2011, 10:21 | #2 (permalink) |
Member: 823633 Status: Offline Thanks Meter: 1,705 | i am full eres after flash write rrpl file backup here but phone sow imei 12345610654321? but my backup rpl file good here Code: Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 0FE00106BC736B56610E30DCF7E6E2E786720A46 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC220800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2208 (Samsung), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Erasing flash chip... Started group flash erase EraseArea[0,CMT]: 0x00000000-0x01FFFFFF, NOR Waiting 640s for erasure finish... Erase taken 75.406s Restarting MCU... BB5 Full Erase Finished! Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm146__07.20.mcusw (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 0FE00106BC736B56610E30DCF7E6E2E786720A46 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm146__07.20.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC220800006921, Samsung, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2208 (Samsung), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00020000-0x0007FFFF, NOR EraseArea[0,CMT]: 0x00080000-0x000DFFFF, NOR EraseArea[0,CMT]: 0x00100000-0x001FFFFF, NOR EraseArea[0,CMT]: 0x00200000-0x0031FFFF, NOR EraseArea[0,CMT]: 0x00320000-0x0105FFFF, NOR EraseArea[0,CMT]: 0x01060000-0x01067FFF, NOR EraseArea[0,CMT]: 0x01068000-0x0107FFFF, NOR Waiting 320s for erasure finish... Erase taken 3.906s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT PMM_CONF Certificate... Writing CMT SBIF_CONF Certificate... Programming Status OK! All blocks written OK! Time taken 71.266s Flashing Speed: 1714.22 kBit/S Restarting MCU... Processing rm146__07.20.mcusw (APE)... Processing rm146__07.20.ppm_w (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 0FE00106BC736B56610E30DCF7E6E2E786720A46 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm146__07.20.ppm_w, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC220800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2208 (Samsung), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 7C1A1F5C3DB717937F54455937AF9DA76AA2EE13 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01080000-0x015FFFFF, NOR Waiting 320s for erasure finish... Erase taken 1.265s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 18.657s Flashing Speed: 2121.94 kBit/S Restarting MCU... Processing rm146__07.20.ppm_w (APE)... Processing rm146__07.20.image_w_ny (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 0FE00106BC736B56610E30DCF7E6E2E786720A46 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm146__07.20.image_w_ny, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC220800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2208 (Samsung), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 7C1A1F5C3DB717937F54455937AF9DA76AA2EE13 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01600000-0x01FDFFFF, NOR Waiting 320s for erasure finish... Erase taken 2.266s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 15.610s Flashing Speed: 2253.01 kBit/S Restarting MCU... Processing rm146__07.20.image_w_ny (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Reading info... MCU Version V 07.20 MCU Date 23-10-08 Product RM-146 (Nokia 5300) Manufacturer (c) Nokia. IMEI 12345610654321? IMEI Spare 1A32541660452301 IMEI SV 1332541660452321F3000000 PPM V 07.20, 23-10-08, RM-146, (c) Nokia. , W PSD 0000000000000000 RETU 32 TAHVO 53 AHNE 11 RFIC 17211721 DSP ICPR61_08w10 Failed to read info -> Failed to read extended info Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Superdongle key... Superdongle Key ACCEPTED OK ! Processing FLASHBUS Part... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 0FE00106BC736B56610E30DCF7E6E2E786720A46 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 191EC665 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x00EC220800006921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00EC2208 (Samsung), Size: 32MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 7C1A1F5C3DB717937F54455937AF9DA76AA2EE13 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Erased CMT NPC Written CMT HWC Erased CMT HWC Written CMT CCC Erased CMT CCC Written CMT VARIANT Erased CMT VARIANT Written Restarting MCU... Write RPL Finished! MCU Version V 07.20 MCU Date 23-10-08 Product RM-146 (Nokia 5300) Manufacturer (c) Nokia. IMEI 12345610654321? IMEI Spare 1A32541660452301 IMEI SV 1332541660452321F3000000 PPM V 07.20, 23-10-08, RM-146, (c) Nokia. , W PSD 0000000000000000 RETU 32 TAHVO 53 AHNE 11 RFIC 17211721 DSP ICPR61_08w10 Failed to read info -> Failed to read extended info |
07-02-2011, 05:55 | #7 (permalink) | ||
Member: 823633 Status: Offline Thanks Meter: 1,705 | Quote:
full rpl file here but phone flash rm 174 (5200) imei is back here but lcd is half here any solu shere me bro nadeem Quote:
07-02-2011, 06:03 | #8 (permalink) |
No Life Poster Join Date: Aug 2007 Location: England
Member: 575900 Status: Offline Thanks Meter: 3,177 | is your Phone simlock r ok ? If not first repair SIMLOCKS and security Area now ..as it cant read it .. Also what about the Selft tests logs post here .. LCD problem is looking weird |
07-02-2011, 06:09 | #9 (permalink) | |
Selftests to proceed: 32 Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SLEEP_X_LOOP_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_KEYBOARD_STUCK_TEST Failed ST_CAMERA_IF_TEST Passed ST_BACKUP_BATT_TEST Failed ST_LPRF_IF_TEST Failed ST_LPRF_AUDIO_LINES_TEST Failed ST_CURRENT_CONS_TEST Passed ST_RADIO_TEST Passed ST_BACKLIGHT_TEST Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_BT_WAKEUP_TEST Failed ST_IRDA_LED_STRESS_TEST Passed ST_HOOKINT_TEST Passed ST_TAHVOINT_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_BTEMP_TEST Passed ST_BT_SLEEP_CLK_TEST Failed ST_MICB1_TEST Failed ST_EXT_DEVICE_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_GSM_TX_POWER_TEST Selftests done, Tests total: 32, Tests passed: 25, Tests not passed: 7 | |
07-02-2011, 07:33 | #10 (permalink) | |
Crazy Poster Join Date: Jul 2008 Location: Philippines
Member: 805005 Status: Offline Thanks Meter: 46 | Quote:
Hi, Salut New Dominio www.chavalgsm.com | ChavaL | GSM Mobile Links | 5 | 09-23-2001 22:51 |
Hi I need help from a UK guy, please ! | Bph&co | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-12-2001 03:14 |
Hi Can some Help me with the sim clock Number | Ari | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-20-2001 10:23 |
Hi All Please Help With Flasher | NOKIA2002 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-19-2001 21:37 |
