06-25-2013, 23:09 | #2 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,512 | |
06-26-2013, 11:04 | #4 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Portugal
Member: 478535 Status: Offline Thanks Meter: 432 | Have you tryed to dump the harmattan firmware from here: flasher: http://skeiron.org/tablets-dev/maemo-dev-env-downloads/ Firmware: http://mrcrab.net/nokia/Nokia_N9.htm...uctType=RM-696 and reprogram it as Haicha refered by linking to post with commands to use with maemo flasher? Get comprehensive info about Harmattan firmware here: [HOWTO] Comprehensive Firmware Flashing Guide for N9 - maemo.org - Talk |
06-27-2013, 12:12 | #5 (permalink) |
Junior Member Join Date: Aug 2011 Location: Mariveles, Bataan, Philippines
Member: 1629679 Status: Offline Thanks Meter: 13 | bro try my tricks ... use USB Connection as u INTERFACE ... be sure to install Nokia USB Drivers are properly install 1. Tick Check Flashing Bus (to be able to go local mode) 2 Tick Common tab then set to test MODE 3. then read Security code INFO ! hope it helps ... 100% work for me ... |
07-02-2013, 13:58 | #7 (permalink) | |
Member: 478535 Status: Offline Thanks Meter: 432 | Quote:
About Ameeriz post, don't know if works (with n9) but i have my doubts. It does not work with N900 Maemo but i may have done it wrong. Cyclone does not support maemo/meego nokia phones. If you are going to try with n9 meego phone and the Ameeriz tip, please post here the result so we can be aware. | |
