Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 09-02-2009, 14:24   #1 (permalink)
sameenshah123's Avatar
Member: 619308
Sonork: 100.1591829
how to fix 3500c RM 272 contact service
slf test
Failed ST_EAR_DATA_LOOP_TEST
Passed ST_SIM_CLK_LOOP_TEST
Passed ST_SIM_IO_CTRL_LOOP_TEST
Passed ST_SLEEP_X_LOOP_TEST
Passed ST_UEM_CBUS_IF_TEST
Passed ST_KEYBOARD_STUCK_TEST
Passed ST_CAMERA_IF_TEST
Passed ST_BACKUP_BATT_TEST
Passed ST_LPRF_IF_TEST
Passed ST_LPRF_AUDIO_LINES_TEST
Passed ST_CURRENT_CONS_TEST
Passed ST_RADIO_TEST
Passed ST_BACKLIGHT_TEST
Passed ST_SIM_LOCK_TEST
Passed ST_SECURITY_TEST
Failed ST_BT_WAKEUP_TEST
Passed ST_HOOKINT_TEST
Passed ST_TAHVOINT_TEST
Passed ST_SLEEPCLK_FREQ_TEST
Passed ST_BTEMP_TEST
Passed ST_BT_SLEEP_CLK_TEST
Passed ST_EXT_DEVICE_TEST
Passed ST_CDSP_RF_BB_IF_TEST
Passed ST_CDSP_RF_SUPPLY_TEST
Passed ST_CDSP_TX_IQ_TEST
Passed ST_CDSP_TXC_DATA_TEST
Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST
Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST
Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST
Passed ST_CDSP_GSM_TX_POWER_TEST
Selftests done, Tests total: 30, Tests passed: 28, Tests not passed: 2
here is check and info
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7880
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v1.06, (Aug 8 2009 17:54:19, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: Revised
Box Serial Number: C0000F16
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk10 / wk14
Initializing security card...
Card Serial Number: D0000AB6
Card Firmware Revision: 0109
Card is activated
Box is activated
Initializing FBUS...
All initialized - Ready to work
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101
CMT_EM_ASIC_ID: 00000232
CMT_EM_ASIC_ID: 00000353
CMT_PUBLIC_ID: 14D00106B55C70560CC4662FAEE0AEE9589F307D
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_ROM_ID: 191EC665DFAAF68F
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x00EC220800006921, Samsung, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D
APE Subsystem Not Found
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
MCU Version V 07.21
MCU Date 05-11-08
Product RM-272
Manufacturer (c) Nokia.
IMEI 359830011668974
Mastercode 7734543762
IMEI Spare 3A95380011669807
IMEI SV 3395380011669827F5000000
PPM V 07.21, 05-11-08, RM-272, (c) Nokia. , C
PSN PHL639059
Product Code 0548999
Module Code 0203649
Basic Product Code 0548279
PSD 0000000000000000
RETU 32
TAHVO 53
AHNE 11
HW 2000
RFIC 17211721
DSP ICPR61_08w10
BT 06cc-P9.1
Simlock Server SIMLOCK SERVER VERSION 63
Simlock Key 2440700000000000
Simlock Profile 0000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
this 3500c have contact service. and flash it and aslo writh pm using bb5 sx4 bypass. cant use sx auth. coz server is down. how to fix it
Old 09-02-2009, 18:03   #2 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Now the server is working.. sx4 authorize, go in the tab common info, sx4 bypass "NOT THICKED", click on write PM and select the good PM
Job done
Alex
Old 09-02-2009, 19:54   #3 (permalink)
R@SEL.NET's Avatar
Member: 670820
Sonork: 100.1583728
Originally Posted by sameenshah123 View Post
slf test
Initializing box...
Card is activated
Box is activated
Booting RAP...
Box VPP disabled
Restarting MCU...
MCU Version V 07.21
MCU Date 05-11-08
Product RM-272
PSN PHL639059
Module Code 0203649
RETU 32
TAHVO 53
AHNE 11
HW 2000
RFIC 17211721
DSP ICPR61_08w10
BT 06cc-P9.1
Simlock Key Cnt 0
Simlock FBUS Cnt 0
bro ,when you press power show contact service or startup without sim card then press ok show contact service?
R@SEL.NET
Old 09-02-2009, 20:23   #4 (permalink)
Member: 619308
Sonork: 100.1591829
when i switch on its directly show contact service. with and without sim
Old 09-02-2009, 20:48   #5 (permalink)
R@SEL.NET's Avatar
Member: 670820
Sonork: 100.1583728
bro,its 100% retu probleam rehot or change retu.i am tested on 3110 & 6300
R@SEL.NET
How to Remove Phone locked - please contact service center sameer525kk Various CDMA/TDMA Cell Phones 9 12-26-2009 07:38
how to repair Nokia 5220 xm contact service, SL data corrupted! svchost Universalbox 0 07-17-2009 10:39
How to Solve 5220 RM-411 Contact service Prajith J.A.F. By Jafsupport.com 2 07-11-2009 19:42
how to use pony prog and contact service repairer eureka8888 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 07-24-2001 14:52
Page generated in 0.29369 seconds with 11 queries
