10-27-2012, 10:31 | #1 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Valladolid-Spain Age: 52
Member: 48936 Status: Offline Thanks Meter: 20 | 3120c-1c dead I have a problem with this set,after flash it, with errors, no power on, and when i connect to cyclone with fbus, no info. When I check flashing bus, this is the log: Code: Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1070001140BC0254F944B838FCAE8483E9D0F960 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x0001003F (AMD), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Internal Box VPP Enabled External CMT Phone VPP Enabled, Source: Box Internal 5V Warning: PAPUBKEYS Hash Missing! APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Code: Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm364__09.49.mcusw (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1070001140BC0254F944B838FCAE8483E9D0F960 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm364__09.49.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x0001003F (AMD), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Internal Box VPP Enabled External CMT Phone VPP Enabled, Source: Box Internal 5V Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x00000000-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR EraseArea[0,CMT]: 0x01480000-0x015FFFFF, NOR EraseArea[0,CMT]: 0x00140000-0x0147FFFF, NOR Waiting 320s for erasure finish... Erase taken 5.62s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm364__09.49.mcusw Any help? thanks in advance |
10-27-2012, 16:05 | #4 (permalink) |
Freak Poster Join Date: Sep 2008
Member: 853097 Status: Offline Sonork: 100.1622287 Thanks Meter: 131 | Check ur cable brother.... Clean pinout on pcb... Try with universal Fbus and jig 7pin 7.5k, attach to yellow adapter, Flash. or try with usb interface.. |
The Following User Says Thank You to .::GEANECIV::. For This Useful Post: |
10-27-2012, 16:20 | #5 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | select VPP= phone and be sure the tx2 adapter is used. check as well the cable and clean the phone pinout as error(3) is tx2 line error. once done redo the flash with the latest version then report BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
10-28-2012, 09:42 | #6 (permalink) | ||
Member: 48936 Status: Offline Thanks Meter: 20 | Quote:
I'll try and post | ||
10-28-2012, 16:40 | #7 (permalink) |
Member: 48936 Status: Offline Thanks Meter: 20 | After set vpp=phone and untick use tx2, and tick Use old protocol loaders, finally the phone power up. But after a while, the phone power off itself, randomly. Here is the log, of read info, and selftest: Code: MCU Version V 09.49 MCU Date 03-03-09 Product RM-364 (Nokia 3120 classic) Manufacturer (c) Nokia IMEI 353102027442174 Mastercode 420724076 IMEI Spare 3A35010272441207 IMEI SV 3335010272441277F4000000 PPM V 09.49, 03-03-09, RM-364, (c) Nokia , T CNT Content: t_364_nz_blue, V 09.49, 03-03-09, RM-364, (c) Nokia , PSN KBM845972 Product Code 0562433 Module Code 0203882 Basic Product Code 0553930 PSD 0000000000000000 LPSN 0 RETU 15 TAHVO 22 AHNE 30 HW 2001 RFIC 17141715 DSP ICPR71_08w30 LCD SEIKO BT 06cc-P9.2 Simlock Server SIMLOCK SERVER Simlock Key 2140300000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 21403F Simlock NCK #pw+584581102082503+1# Selftests to proceed: 33 Passed ST_TAHVOINT_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SIM_LOCK_TEST Passed ST_SLEEP_X_LOOP_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_KEYBOARD_STUCK_TEST Passed ST_CAMERA_IF_TEST Passed ST_BACKUP_BATT_TEST Passed ST_LPRF_IF_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_CURRENT_CONS_TEST Passed ST_LCD_TEST Passed ST_SEC_CAMERA_IF_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_BT_WAKEUP_TEST Passed ST_BTEMP_TEST Passed ST_BT_SLEEP_CLK_TEST Passed ST_IVE_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_WCDMA_TX_POWER_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_GSM_TX_POWER_TEST Selftests done, Tests total: 33, Tests passed: 33, Tests not passed: 0 next step? |
10-28-2012, 16:55 | #9 (permalink) | |
when analize segurity, this is the log: Code: Reading Security Block... Security block OK and saved to "RM-364_353102027442174_28102012_045105 p.m..SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block "1070001140BC0254F944B838FCAE8483E9D0F960.C0001306" Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... SIMLOCK FOUND AND CHECKSUM OK! PASSED! Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... CMLA KEYS FOUND AND CHECKSUM OK! PASSED! Checking ECC KEYS... ECC KEYS FOUND AND CHECKSUM OK! PASSED! Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! ? | |
10-28-2012, 19:32 | #11 (permalink) | |
log: Code: MCU Version V 09.49 MCU Date 03-03-09 Product RM-364 (Nokia 3120 classic) Manufacturer (c) Nokia IMEI 353102027442174 Mastercode 420724076 IMEI Spare 3A35010272441207 IMEI SV 3335010272441277F4000000 PPM V 09.49, 03-03-09, RM-364, (c) Nokia , T CNT Content: t_364_nz_blue, V 09.49, 03-03-09, RM-364, (c) Nokia , PSN KBM845972 Product Code 0562433 Module Code 0203882 Basic Product Code 0553930 PSD 0000000000000000 LPSN 0 RETU 15 TAHVO 22 AHNE 30 HW 2001 RFIC 17141715 DSP ICPR71_08w30 LCD SEIKO Simlock Server SIMLOCK SERVER Simlock Key 2140300000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 21403F Simlock NCK #pw+584581102082503+1# Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1070001140BC0254F944B838FCAE8483E9D0F960 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: Single Line 8Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: Single Line 8Bit FlashChip 0x0001003F (AMD), Size: 64MBytes, VPP: 9V RAP3Gv3_algo_fps8.fg, Type: Algorithm, Rev: 0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm364__12.35.mcusw (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1070001140BC0254F944B838FCAE8483E9D0F960 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm364__12.35.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: Single Line 8Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: Single Line 8Bit FlashChip 0x0001003F (AMD), Size: 64MBytes, VPP: 9V RAP3Gv3_algo_fps8.fg, Type: Algorithm, Rev: 0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x00000000-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR EraseArea[0,CMT]: 0x01480000-0x015FFFFF, NOR EraseArea[0,CMT]: 0x00140000-0x0147FFFF, NOR Waiting 320s for erasure finish... Erase taken 5.63s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Programming Status OK! All blocks written OK! Time taken 133.531s Flashing Speed: 1295,36 kBit/S Restarting MCU... Processing rm364__12.35.mcusw (APE)... Processing rm364__12.35.ppm_f (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1070001140BC0254F944B838FCAE8483E9D0F960 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm364__12.35.ppm_f, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: Single Line 8Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: Single Line 8Bit FlashChip 0x0001003F (AMD), Size: 64MBytes, VPP: 9V RAP3Gv3_algo_fps8.fg, Type: Algorithm, Rev: 0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: B778DFBE4C5F277CE2DE8A38AF46E5D6803E4A79 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01600000-0x01CBFFFF, NOR Waiting 320s for erasure finish... Erase taken 29.547s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 37.375s Flashing Speed: 1198,96 kBit/S Restarting MCU... Processing rm364__12.35.ppm_f (APE)... Processing rm364__12.35_ISM_006.image_f_364_graphite_pelephone_il_graph (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1070001140BC0254F944B838FCAE8483E9D0F960 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm364__12.35_ISM_006.image_f_364_graphite_pelephone_il_graph, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: Single Line 8Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001003F00008A21, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: Single Line 8Bit FlashChip 0x0001003F (AMD), Size: 64MBytes, VPP: 9V RAP3Gv3_algo_fps8.fg, Type: Algorithm, Rev: 0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: B778DFBE4C5F277CE2DE8A38AF46E5D6803E4A79 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01FC0000-0x03F9FFFF, NOR EraseArea[0,CMT]: 0x01CC0000-0x01FBFFFF, NOR Waiting 320s for erasure finish... Erase taken 134.781s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 79.687s Flashing Speed: 1263,34 kBit/S Restarting MCU... Processing rm364__12.35_ISM_006.image_f_364_graphite_pelephone_il_graph (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Reading info... MCU Version V 12.35 MCU Date 11-11-09 Product RM-364 (Nokia 3120 classic) Manufacturer (c) Nokia IMEI 353102027442174 Mastercode 420724076 IMEI Spare 3A35010272441207 IMEI SV 3335010272441287F1000000 PPM V 12.35, 11-11-09, RM-364, (c) Nokia , F CNT Content:f_364_graphite_pelephone_il_graph, V 12.35, 11-11-09, RM-364, (c) Nokia , , PSN KBM845972 Product Code 0562433 Module Code 0203882 Basic Product Code 0553930 PSD 0000000000000000 LPSN 0 RETU 15 TAHVO 22 AHNE 30 HW 2001 RFIC 17141715 DSP ICPR71_09w06 LCD SEIKO BT 06cc-P9.2 Simlock Server SIMLOCK SERVER Simlock Key 2140300000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 21403F Simlock NCK #pw+584581102082503+1# Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! or may be hardware problem? | |
