Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Junior Member ![]() Join Date: Feb 2012
Member: 1718811 Status: Offline Thanks: 29
| How to remove user code of a nokia 6555c? = ( [ Solved ] The problem is that I can not connect the phone via USB, just plug in a second and then disconnects so do not even detect the PC .... Help Please ... when the phone is on and connect the USB cable is not detected at all but if I connect the USB cable first and then put the battery and pressed power is detected by a second and then turns off .... = ( |
| | #2 (permalink) |
| Super Moderator ![]() Join Date: Jan 2009 Location: England Age: 48
Member: 947561 Status: Offline Thanks: 2,690
| Select usb as connection go to the tab bb5/flashing select the flash files related to this mobile click on check flashing bus connect the mobile in off mode to the usb cable press shortly power on on the mobile. once the check flashing bus is done the mobile wil be in local mode and you will be able to read/delete the user code BR Alex |
| | #3 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2009
Member: 984046 Status: Offline Thanks: 0
| From a thread title & last reply ID (you Alex) on a thread list, I was frighten that the common questions here going in "how to transfer my contacts to SIM" direction... LOL ![]() Br, Haltec |
| | #9 (permalink) |
| mmhhh Just do full flash and factory setting then.. it will be like new. BR Alex |
| The Following User Says Thank You to moulnisky For This Useful Post: |
| | #10 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jan 2011 Location: Honduras
Member: 1488173 Status: Offline Thanks: 422
| if you use fbus cable is more easy read/reset this code, by usb do full flash and then factory settings, your phone will be ok. |
| The Following User Says Thank You to celumaster. For This Useful Post: |
| | #11 (permalink) | |
| Quote:
Problem SolvedProcessing pre flash tasks... Backing up RPL... RPL Creation started... Processing CMT Part... Sending User Abort Signal... Phone not detected at USB -> User Abort Proceeding with Recovery Mode... Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1A500101D4990254E3556DF506FD1DEEB9370E95 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: Single Line 8Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Prepare phone failed with message -> Only New Protocol Loaders are supported for FPIF-USB transport Recovery Mode Failed, storing Certificates Only Booting CMT... [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1A500101D4990254E3556DF506FD1DEEB9370E95 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Prepare phone failed with message -> Only New Protocol Loaders are supported for FPIF-USB transport Failed to Create RPL from phone -> Failed to Boot / Prepare Phone RPL backup thread finished, continuing... Pre flash tasks finished, continuing... Selecting USB Flashing Method... Proceeding with Dead USB Mode Press power-on shortly to run USB Boot ROM [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1A500101D4990254E3556DF506FD1DEEB9370E95 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F DeadUSB.raw, Type: 2nd Boot Loader, Rev: , Algo: BB5 Sending RAW Loader... Sending CMT UPDAPP Certificate and Data... [Nokia BB5 ADL Loader USB Generic]: Port opened OK! ADL Server Startup Confirmed OK! Processing rm276__03.38.mcusw (CMT)... rm276__03.38.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x00000000-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR EraseArea[0,CMT]: 0x01380000-0x014FFFFF, NOR EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR Erase taken 52.104s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... All blocks written OK! Time taken 112.945s Flashing Speed: 1282.24 kBit/S Processing rm276__03.38.ppm_l (CMT)... rm276__03.38.ppm_l, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x01500000-0x01BBFFFF, NOR Erase taken 14.914s Writing all blocks... Initializing TurboCache... TurboCache Loaded! All blocks written OK! Time taken 32.11s Flashing Speed: 1287.47 kBit/S Processing rm276__03.38.image_l (CMT)... rm276__03.38.image_l, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Started flash erase EraseArea[0,CMT]: 0x01FC0000-0x03F9FFFF, NOR EraseArea[0,CMT]: 0x01BC0000-0x01FBFFFF, NOR Erase taken 104.37s Writing all blocks... Initializing TurboCache... TurboCache Loaded! All blocks written OK! Time taken 33.541s Flashing Speed: 1439.79 kBit/S Restarting CMT... All images processed OK! Processing post flash tasks... Setting Factory Defaults... [Nokia 6555c USB Phonet]: Port opened OK! [Nokia 6555c USB Phonet]: Port opened OK! [Nokia 6555c USB Phonet]: Port opened OK! [Nokia 6555c USB Phonet]: Port opened OK! [Nokia 6555c USB Phonet]: Port opened OK! Factory defaults OK Reading info... [Nokia 6555c USB Phonet]: Port opened OK! MCU Version V 03.38 MCU Date 05-10-07 Product RM-276 (Nokia 6555c) Manufacturer (c) Nokia IMEI 357694011657219 Mastercode 5314664452 IMEI Spare 3A75960411562701 IMEI SV 3375960411562701F6000000 PPM Vp 03.38, 05-10-07, RM-276, (c) Nokia, L CNT Content: l, Vp 03.38, 05-10-07, RM-276, (c) Nokia, PSN RBB355023 Product Code 0551499 Module Code 0203394 Basic Product Code 0515129 PSD 0000000000000000 LPSN 0 RETU 15 TAHVO 22 AHNE 30 HW 5055 RFIC 17141715 DSP MD_RAP_PB06_w41v25_01_ENO LCD SEIKO BT 06cc-P9.1 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| New Nokia Software!!!!!!! | Jefferson | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 73 | 05-15-2013 13:07 |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
