09-18-2014, 13:04 | #1 (permalink) |
Junior Member Join Date: Mar 2006
Member: 251401 Status: Offline Thanks Meter: 2 | How to repair nokia c7-00 sim lock, cmla key and ecc key & struck on five dots screen CAN ANY BODY SUGGEST ME THE BEST SOLUTION TO REPAIR NOKIA C7-00 SIM LOCK, CMLA KEY AND ECC KEY & STRUCK ON FIVE DOTS SCREEN USING CYCLONE BOX OR INFINITY BEST DONGLE OR UFSHWK. WHEN I CHECKED FLASHING BUS IN CYCLONE BOX THE LOG IS SHOWN AS FOLLOWS: Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 05000117E4A4034460BB5DE8CF4485CEC9BB000D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.11.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.11.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... AFTER THIS WHEN I CLICK ON ANALISE SECURITY THE LOG IS AS FOLLOWS: Started Phone Security Analysis... MCU Version V 79_sr1_12w18.5 MCU Date 27-07-12 Product RM-675 (Nokia C7-00) Manufacturer (c) Nokia IMEI 353755044809020 Mastercode 613171245 Reading Security Block... Security block OK and saved to "RM-675_353755044809020_9182014_50038 AM.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block "05000117E4A4034460BB5DE8CF4485CEC9BB000D.C0005EE6 " Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! NOW THE PHONE WAS STRUCK ON FIVE DOTS BOOTING SCREEN. DEAR EXPERTS NEED ALL YOUR HELP PLEASE. |
