07-01-2009, 15:09 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: www.GSM10.com
Member: 720059 Status: Offline Thanks Meter: 33 | how to unlock 1661? i used server to calculate rpl sic 11.................ok i tried to write rpl ........................................ok put the phone stille locked. here is the log: Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7396 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.05, (Jun 22 2009 12:23:29, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT ; BB5-NCK-CALC Box Serial Number: C0000B60 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk01 / wk06 Initializing security card... Card Serial Number: D20006BE Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,98v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,76v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,92v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,97v PASSED Box VPP disabled VPP Voltage 0,02v PASSED External Box VPP Enabled VPP Voltage 5,77v PASSED Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work MCU Version V 03.10 MCU Date 11-02-09 Product RH-122 Manufacturer (c) Nokia IMEI 355221030038528 Mastercode 35365554 Asic 11 HW Signature 285DD7D0D5A38CF2 Simlock Server SIMLOCK SERVER Simlock Key 2140700000000000 Simlock Profile 8000000000030002 Simlock Aux 000B0000 Simlock IMEI 00003552210300385200 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock[2,1] State: CLOSED Type: MCC-MNC Data: 21402F Selecting unlock method... Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RH-122_V 03.10.unlock_img Unlock data not found, Trying to calculate Unlock Codes... Unsupported ASIC for Code Calculation Booting UPP... UPP ID: 2293 [HW_UNKNOWN] Searching for CBUS Loader: UEM Failed to Read UEM IMEI -> CBUS Loader was not found Programming data for IMEI: 355221030038528 Found FLASH Data Rebuild Block Found UEM Data Rebuild Block Booting UPP... Failed to Write UEM -> UPP Not Responding Programming data for IMEI: 355221030038528 Found FLASH Data Rebuild Block Found UEM Data Rebuild Block Booting UPP... Failed to Write UEM -> UPP Not Responding Programming data for IMEI: 355221030038528 Found FLASH Data Rebuild Block Found UEM Data Rebuild Block Booting UPP... UPP ID: 2293 [HW_UNKNOWN] Flashbus Write baud set to 100Kbits u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.77.0, Algo: DCT4 PLL Factor: 3 FlashChip[0]: 0x002088C0 @ 0x01000000, ST, SectorSize: 64kB, Ext: 00007321 Signature: AD7EB61A23100340C605E40120A26514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 0Kbits u3_st_i.fia, Type: Algorithm, Target: FlashChip[0] 0x002088C0 (64Mbits), Rev: 7.4.77.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0,04V Programming FLASH data... FLASH data Programmed OK Programming UEM data... UEM data Programmed OK Terminating flash session Write UEM finished MCU Version V 03.10 MCU Date 11-02-09 Product RH-122 Manufacturer (c) Nokia IMEI 355221030038528 Mastercode 35365554 IMEI Spare 3A55220103305802 IMEI SV 3355220103305812F4000000 PPM V 03.10, 11-02-09, RH-122, (c) Nokia, AG PSN DWE839656 Product Code 0580314 Module Code 0204078 Basic Product Code 0568809 PSD 0000000D00000000 HW 1000 UEM 1328 UPP 8851 RFIC 0700 DSP ICPR81_09w03_UPP LCD WIN:BOHAIv91, NT39121 ADSP Sw p'V 03.10\n11-02-09\nRH-122\n(c) NMP\nag Asic 11 HW Signature 285DD7D0D5A38CF2 Simlock Server SIMLOCK SERVER Simlock Key 2140700000000000 Simlock Profile 8000000000030002 Simlock Aux 000B0000 Simlock IMEI 00003552210300385200 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock[2,1] State: CLOSED Type: MCC-MNC Data: 21402F MCU Version V 03.10 MCU Date 11-02-09 Product RH-122 Manufacturer (c) Nokia IMEI 355221030038528 Mastercode 35365554 Asic 11 HW Signature 285DD7D0D5A38CF2 Simlock Server SIMLOCK SERVER Simlock Key 2140700000000000 Simlock Profile 8000000000030002 Simlock Aux 000B0000 Simlock IMEI 00003552210300385200 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock[1,1] State: CLOSED Type: MCC-MNC Data: 21407F Simlock[2,1] State: CLOSED Type: MCC-MNC Data: 21402F Selecting unlock method... Search in: C:\Program Files\Cyclone Box\UnlockData\ Searching for: RH-122_V 03.10.unlock_img Unlock data not found, Trying to calculate Unlock Codes... Unsupported ASIC for Code Calculation Booting UPP... Failed to Read UEM -> UPP Not Responding Programming data for IMEI: 355221030038528 Found FLASH Data Rebuild Block Found UEM Data Rebuild Block Booting UPP... Failed to Write UEM -> UPP Not Responding credit tool service Started credits checking procedure at 15:54:37 Handling device: [Cyclone Team], [Cyclone Box] Service Tag: 5DEBA02DCA7A512C741A1BF14F60D648 Cyclone Server (1.0.0.476), Cyclone Box Team 2008, 2009 - Ready. Credits: 98 thanking all |
The Following User Says Thank You to husainm For This Useful Post: |
How to unlock 1661 rh-122? | Fernyx | Nokia Base Band 5 ( BB-5 ) | 5 | 01-04-2010 21:17 |
how to unlock 1661-2b | Farshedjon | Cyclonebox | 18 | 10-10-2009 23:45 |
How to unlock 1661 ufs box | challengesenthi | Nokia Hardware & Hardware Repair | 3 | 09-24-2009 13:52 |
how to unlock 1661 rh121 | fofolpo | Nokia Base Band 5 ( BB-5 ) | 2 | 09-17-2009 02:19 |
