Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 05-25-2011, 09:33   #1 (permalink)
Member: 810916
Thanks Meter: 7
how to use yellow adaptor in cyclone?
good day cyclone user...
how to use yellow adaptor to make testmode of n95 8g...
i'm using ufcv2 in cyclone box...in other bb5 phones even i ddnt use yellow adaptor it can testmode...but in n95 8g and others could not....
i try also to put a charger using info reading but still it cant test mode..
i try to use the yellow adaptor and put the usb to supply but still it cant detect testmode.....
please what is the proper use of yellow adaptor...
tanx...
Old 05-25-2011, 09:42   #2 (permalink)
ABDULMANAN's Avatar
Member: 754324
Sonork: LOVE MOHAMMAD (S.A.W)
Thanks Meter: 469
Yellow adaptor is for bb5 flashing tx2 and for 95 u need 15 k r on bsi
The Following User Says Thank You to ABDULMANAN For This Useful Post:
Old 05-25-2011, 09:44   #3 (permalink)
Member: 810916
Thanks Meter: 7
you mean i will put another resistor 15k in BSI to ground to make it testmode?
even do i will not use usb for supply?
Old 05-25-2011, 11:16   #4 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
Thanks Meter: 22,712
I have N95 on my table working like charm with bundled TX2 adapter.
Just attach TX2 adapter to box, and to adapter attach JAF/UFS cable with 10k bsi resistor (and 68k bsi-gnd).
Before unlocking, you may try to Check Flashing Bus. It helps a lot to turn phone into Local Mode, as long as during leaving FlashMode, phone restarts into Local Mode (even on resistor mismatch).
BB5 Simlock Structure Import Started...
MCU Version V 06wk41v64.23
MCU Date 05-11-09
Product RM-159 (Nokia N95)
Manufacturer (c) Nokia
IMEI 353094025962537
Mastercode 4053535732
Simlock Server SIMLOCK SERVER
Simlock Key 2440700000000000
Simlock Profile 8000000000000006
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Reading Security Block...
Security block OK and saved to "RM-159_353094025962537_2011-05-25_121522.SecurityBlock.PM"
WARNING: "03A00015BC5900529218C51D642A7EF4ED857610.C0003160 " Not Exists, Will read it...
Reading CYC file from phone...
Booting CMT...
APE_SYSTEM_ASIC_ID: 24200705
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID: 10C1DBEC9958EA0C4AA92F979CC85A5756C7A346
APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 03A00015BC5900529218C51D642A7EF4ED857610
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC: A8C1D671
CMT_SECURE_ROM_CRC: 3E691FF8
CMT Ready!
New_RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.48.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x00012C7E00006921, AMD, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
Sending Auxiliary Loader...
Auxiliary Loader Sent!
Loader: RAPxx CommonBoot v1.05 (C) 2011 KarwosLabs
Custom loader running OK! Working...
Readed OK, Saving to "03A00015BC5900529218C51D642A7EF4ED857610.C0003160 "
Checking for Rootkey Hash support with selected Unlock Method...
Selected Unlock Method: RPL Calculation
Asking box to calculate RPL...
Received RPL from Box OK!
Writing Simlock...
BB5 Simlock Structure Import Failed -> Phone not detected (FBUS) <- check flashing bus here again due to bad resistors
Booting CMT...
CMT Ready!
Searching for BootCode: DualLine 32Bit
FlashChip 0x00012C7E (AMD), Size: 16MBytes, VPP: 9V
RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.48.1, Algo: XSR 1.5
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
MCU Date 05-11-09
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK and saved to "RM-159_353094025962537_2011-05-25_121623.SecurityBlock.PM"
"03A00015BC5900529218C51D642A7EF4ED857610.C0003160 " Exists, That is good...
Writing Simlock...
Simlock ACCEPTED OK !
MCU Date 05-11-09
Simlock Key 2600100000000000
Simlock Profile 8000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 26001F
Simlock Structure Import finished! Time taken 9.984s
Unlock Codes (to be used when needed):
#pw+198057617447591+1#
#pw+542811464543185+2#
#pw+148146896514160+3#
#pw+554142045343988+4#
#pw+367926962178771+5#
#pw+027921526562291+6#
#pw+597999634549031+7#
Old 05-25-2011, 11:18   #5 (permalink)
karwos's Avatar
Member: 117496
Sonork: 100.83919
MCU Date 05-11-09
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Booting CMT...
CMT Ready!
Writing Simlock...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Restarting MCU...
MCU Date 05-11-09
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Writing Simlock...
MCU Date 05-11-09
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Old 05-26-2011, 15:13   #6 (permalink)
ABDULMANAN's Avatar
Member: 754324
Thanks Meter: 469
Originally Posted by rhimark View Post
you mean i will put another resistor 15k in bsi to ground to make it testmode?
Even do i will not use usb for supply?
15k r in bsi line not with gnd
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.43539 seconds with 8 queries
