04-17-2009, 00:09 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: philippines
Member: 45571 Status: Offline Thanks Meter: 45 | Cannot add image files or flashfile problem Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.6634 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v1.00, (Mar 13 2009 20:30:35, gcc-4.2.2, RTOS V5.1.0), Type: Signed Production Application Box Serial Number: C00xxxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: D10xxxxx Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.02v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 4.91v PASSED Box VPP disabled VPP Voltage 0.00v PASSED Internal Box VPP Enabled VPP Voltage 4.79v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Initializing FBUS... All initialized - Ready to work Failed to Add Image File -> Access violation at address 00000000. Read of address 00000000 |
04-17-2009, 05:40 | #2 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Which Windows u using Along with Which Service PACK ? As Access Violation error is weird in ur case.. try Removing Cyclone BOX setup restart System and Install Again... |
04-17-2009, 09:35 | #3 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Pakistan
Member: 265626 Status: Offline Sonork: 100.1591486 Thanks Meter: 2,982 | Quote:
no need to check SP now sa i am using Windows XP with Service pack 3 and cyclone new exe is working perfect on it just uninstall whole setup restart ur pc install the latest installer after that you need replace Cyclone.exe in C:\Program Files\CycloneBox\, on following: http://www.***************/downloads/Cyclone.exe and after that post result here | |
04-17-2009, 11:35 | #4 (permalink) |
Member: 45571 Status: Offline Thanks Meter: 45 | Everytime i download that exe this is the error. Cannot copy Cyclone:Access is denied. Make sure the disk is not full or write-protected and that the file is not currently in use. I cannot download that exe. |
04-17-2009, 12:15 | #9 (permalink) | |
u need cyclone.exe file here it is just download and replace http://rapidshare.com/files/222393227/Cyclone.rar.html | |
04-17-2009, 12:32 | #10 (permalink) |
Member: 45571 Status: Offline Thanks Meter: 45 | I got the new cyclone exe now but same problem Failed to Add Image File -> Access violation at address 00000000. Read of address 00000000 What seems to be the problem here. |
04-17-2009, 12:51 | #11 (permalink) |
Banned Join Date: Apr 2009 Location: Unlock-Sydney.com.au Age: 37
Member: 1113892 Status: Offline Sonork: none Thanks Meter: 62 | May be registry Problem Hi Bro ! It may be Registry Problem. I have uploaded a Registry Cleaner Software ( With Serial Number ) here : http://www.zshare.net/download/587760600f7567d8/ It would be just a TRY. May be u r lucky. Regards, SU |
04-17-2009, 14:07 | #12 (permalink) |
Member: 45571 Status: Offline Thanks Meter: 45 | No answer from product supporter? My problem is not yet solved.About registry cleaner software i'm afraid to use it because of my other boxes especially HWK.Not worth to risk my other boxes for one box Cyclone.I'm waiting solution from product supporters. |
04-17-2009, 14:53 | #15 (permalink) |
Member: 45571 Status: Offline Thanks Meter: 45 | Maybe my OS but have to wait before format because all my boxes are still doing good with this OS.Only Cyclone box is giving me trouble.Cant afford to format this time.Someday i will, so my new cyclone box is sitting pretty as of the moment waiting product supporter to figure any other solution other that format. |
Failed to add image files | cheong966 | Cyclonebox | 24 | 08-16-2009 04:45 |
Steps On How To Post/share Files Or Image!!! | FullFLASHgSMPH | Off Topic Zone | 4 | 06-15-2009 05:05 |
Hello guys i want full flash image file of 2100 of fls or in any other format | kelika7hills | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 08-18-2003 05:34 |
