02-14-2012, 00:42 | #61 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | I the mean time, you can keep working with your box, just install the v1.17, and answer NO when prompted to update the software. Sorry but for now its the only solution that i can give to you. BR Lamento no poder ayudarte, pero no tengo acceso al Server, y ninguno de los que tiene acceso esta en linea. Como una solucion temporal puedes instalar la version 1.17, y no realizar la actualizacion del soft, de esa forma podras seguir trabajando hasta que Kaisak u otro de los que tienen acceso al server te agreguen tickets para que actualices tu Box. Saludos |
The Following User Says Thank You to ptt For This Useful Post: |
02-14-2012, 00:55 | #62 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 45
Member: 166436 Status: Offline Thanks Meter: 28 | Thanks, i will try ur recomendation, can you giveme a link for download version 1.17 ?, i run installer directly form internet, i dont have installer on hdd. Gracias, intentare tu recomendacion, puedes darme un link para bajar la version 1.17, yo ejecuto directamente el instalador desde internet, no tengo el instalador en el disco duro. |
02-14-2012, 11:57 | #64 (permalink) |
No Life Poster Join Date: Apr 2009 Location: HM unlock fone mandi bahauddin
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Nokia/Blackberry Application v01.86, (Feb 9 2012 15:22:50, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Initialization has failed -> Box firmware is obsolete, please upgrade it card sn =D00C0587 sir plz chek my box cont update |
02-14-2012, 12:39 | #65 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Poland
Member: 209842 Status: Offline Sonork: 100.93537 Thanks Meter: 3,386 | Quote:
02-14-2012, 13:03 | #66 (permalink) |
Member: 1015336 Status: Offline Sonork: 100.1608410 Thanks Meter: 813 | s/n-D00C0587 i cant sir plz fix it Box Maintenance procedure started at 5:02:08 PM Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support Service Tag: 20C5E9BCDDD9A84422337A665895A68A Connecting to Cyclone Server Box Maintenance Error -> Can't connect to Cyclone Server |
02-14-2012, 13:24 | #67 (permalink) |
Member: 166436 Status: Offline Thanks Meter: 28 | Mister ptt, kaisak, thanks for help, box updated : Initializing box... Box Firmware: Cyclone Nokia/Blackberry Application v01.88, (Feb 14 2012 01:59:38, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0005C38 HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk23 Initializing security card... Card Serial Number: D00A01D6 Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 5,10v PASSED MCU Voltage 3,27v PASSED Core Voltage 1,79v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 5,04v PASSED Box VPP disabled VPP Voltage 0,00v PASSED Internal Box VPP Enabled VPP Voltage 5,08v PASSED Box VPP disabled VPP Voltage 0,02v PASSED External Box VPP Enabled VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Credits Left: 100 Avaiable Physical Memory: 1.343GB Avaiable Virtual Memory: 1.498GB Avaiable Pagefile: 3.255GB Initializing FBUS... All initialized - Ready to work |
02-14-2012, 13:31 | #68 (permalink) | |
02-16-2012, 16:43 | #71 (permalink) |
Freak Poster Join Date: Apr 2009 Location: uk southwales sa1 1le
Member: 1005605 Status: Offline Thanks Meter: 11 | Box SN: C0006964 please add mine for update i get Secure Bootloader Update Skipped Box Maintenance procedure started at 15:34:16 Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support Service Tag: E8A0E04E387BFE78A5C71A4DD03ED692 Connecting to Cyclone Server Cyclone Server (1.0.0.686), Cyclone Box Team 2008-2011 - Ready. ========= Box Info ========= Box SN: C0006964 HW Revision: C, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk48 Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty Box registration status: Registered OK Paired Card SN: D0090516 First Name: Richard Surname: L & R computer & mobile repair Nickname: froggyrichy2 Address: 13 Parc-y-rhos Country: United Kingdom E-Mail: [email protected] Reseller: Gsmserver, Hongkong Warranty Start Date: 2011-12-02 Warranty Period (months): 6 Warranty Stop Date: 2012-06-02 Warranty active: Yes ============================ Updating Security Area... Security Area Updated, Took: 0.172s Updating Main Firmware... Main Firmware Updated, Took: 20.844s Updating COM Emulator Firmware... COM Emulator Firmware Updated, Took: 1.375s Updating Secure Bootloader... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Firmware: Cyclone Nokia/Blackberry Application v01.88, (Feb 14 2012 01:59:38, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Boot Agent: Cyclone Secure BootAgent Server v3.01 (C) KarwosSoft 2010 wk41 Bootloader is already Up-to-date Secure Bootloader Update Skipped Disconnected from Cyclone Server Box Maintenance finished successfully |
02-16-2012, 16:50 | #72 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: Murcia,Spain Age: 44
Member: 116918 Status: Offline Sonork: 100.1590386 Thanks Meter: 559 | Check line highlighted in red Bootloader is already at latest version is why update skipd it, no need to update bootloader if it is upto date. BR Quote:
02-16-2012, 16:57 | #73 (permalink) | |
02-17-2012, 12:01 | #74 (permalink) |
Major Poster Join Date: Mar 2007
Member: 477064 Status: Offline Thanks Meter: 4 | hi sir please help me my box not update or not alowd:Box Maintenance procedure started at 12:45:00 Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Bootloader: Cyclone Secure Bootloader v2.13, (Oct 5 2010 17:21:58), Type: Signed Production Application, Added Clip Support Service Tag: 86FED594EB58CFAA67B7ED4FB24DB161 Connecting to Cyclone Server Cyclone Server (1.0.0.686), Cyclone Box Team 2008-2011 - Ready. ========= Box Info ========= Box SN: C0001AAC HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Set: Box, TX2 Adapter, 100 Credits, 6 Months Warranty Box registration status: Registered OK Paired Card SN: D2000420 First Name: amedah Surname: kamel Nickname: kamel0404 Address: galerie prestige rue lamali ahmed tiziouzou Country: algeria E-Mail: [email protected] Reseller: SamPhone, Algeria Warranty Start Date: 2009-10-06 Warranty Period (months): 6 Warranty Stop Date: 2010-04-06 Warranty active: No ============================ Updating Security Area... Security Area Update Skipped, Not allowed Updating Main Firmware... Main Firmware Update Skipped, Not allowed Updating COM Emulator Firmware... COM Emulator Update Skipped, Not allowed Updating Secure Bootloader... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] mailto:[email protected] |
02-17-2012, 15:06 | #75 (permalink) | |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
