04-03-2010, 21:10 | #1 (permalink) |
Insane Poster Join Date: Dec 2005 Location: Austria
Member: 213935 Status: Offline Thanks Meter: 2 | Initial SP corrupted or not a Baseband5 phone detected can any one help me, i tried to unlock Nokia 6280 and N70 without success, i got the same thing here are the logs : Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.8236 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.21, (Feb 12 2010 23:32:03, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk6 Box Serial Number: +++++++++ HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 Initializing security card... Card Serial Number: ++++++++++ Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,90v PASSED MCU Voltage 3,30v PASSED Core Voltage 1,78v PASSED VBAT Voltage 1,47v PASSED VBAT Voltage 4,83v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,83v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V 03.36 MCU Date 05-12-05 Product RM-78 Manufacturer (c) Nokia IMEI 357+++++++++++++ Mastercode 3626647431 IMEI Spare 3A75060340788400 IMEI SV 3375060340788400F1000000 PPM V 03.36, 05-12-05, RM-78, (c) Nokia, C CNT Content: 3_at, V 03.36, 05-12-05, RM-78, (c) Nokia, PSN SJE859980 Product Code 0529987 Basic Product Code 0520041 PSD 0000001F00000000 RETU 32 TAHVO 52 AHNE 30 HW 1000 RFIC 17191719 DSP pb05w32v16 LCD SHARP Failed to read info -> Failed to read SP info BB5 Unlock Started... MCU Version V 03.36 MCU Date 05-12-05 Product RM-78 Manufacturer (c) Nokia IMEI 3576+++++++++++ Mastercode 3626647431 Warning: Failed to read SP Info, Assuming defaults BB5 Unlock Failed -> Initial SP corrupted or not a Baseband5 phone |
04-03-2010, 21:19 | #3 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | and update your software ( 1.0.0.8236 ) you are using an old version.... download and install the 1.04 stable installer: http://www.***************/downloads/...xInstaller.exe once you have installed it copy the last EXE in the Cyclone Box program folder ( overwrite the existent exe ) http://www.***************/downloads/Cyclone.exe BR BR Last edited by ptt; 04-03-2010 at 21:29. Reason: correct link |
04-03-2010, 21:23 | #4 (permalink) |
Freak Poster Join Date: Mar 2010 Location: In Your Heart Age: 36
Member: 1258712 Status: Offline Sonork: 1596509 Thanks Meter: 157 | Update Your Box Just download EXE file and replace at C:\Program files\Cyclone Box\Make sure Installer is installed aswell (this one from january, else you will have message RootkeyHash not supported). You don't need any activations,logs to use this update. Notes: SX4 Emulation works offline and emulates SX4 card 1:1, in case of failure still server will be used. BB5 NCK Calculator works for phone relocked by Cyclone Only (unlocking using IMEI only, no need know other data, just imei - no need cable or connection to box too). BB5 USB Unlocking and other security tools works only if phone log (by flashbus) is readen before. Update is fast and most of security functions (sd,rpl) works very fast. Don't forget to upgrade your Box Firmware to v01.21. Download Link : http://rapidshare.com/files/349693053/Cyclone.exe http://www.***************/downloads/Cyclone.exe Then Just click on "skip read SP Info", Then Try To Unlock.... |
04-03-2010, 22:05 | #8 (permalink) |
Member: 213935 Status: Offline Thanks Meter: 2 | i have downloaded the new software, but i can not update it, it is always the old one. when i click boxmaintenance, i get the following : Updating Security Area... Security Area Update Skipped, Not allowed Updating Main Firmware... Main Firmware Update Skipped, Not allowed Updating Secure Bootloader... Secure Bootloader Update Skipped, Not allowed or not needed Disconnected from Cyclone Server Box Maintenance finished successfully what shall i do now ? |
04-03-2010, 22:10 | #9 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | You dont need to update your Box FW you have the last version ( v01.21 ) and if still have problems reading info from 6280, try this: http://forum.gsmhosting.com/vbb/4811517-post1.html BR |
04-04-2010, 14:43 | #10 (permalink) |
Member: 213935 Status: Offline Thanks Meter: 2 | i have tried the solution posted by moulnsky, but it did not work, i have ticked also skip SP read, but the problem is the same i can not unlock these two phones Nokia N70 and Nokia 6280 here are the logs : Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.8236 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.21, (Feb 12 2010 23:32:03, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk6 Box Serial Number: ************ HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 Initializing security card... Card Serial Number: ******** Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,91v PASSED MCU Voltage 3,29v PASSED Core Voltage 1,79v PASSED VBAT Voltage 1,48v PASSED VBAT Voltage 4,83v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,88v PASSED Box VPP disabled VPP Voltage 0,00v PASSED External Box VPP Enabled VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V 03.36 MCU Date 05-12-05 Product RM-78 Manufacturer (c) Nokia IMEI 357********* Mastercode 3626647431 IMEI Spare 3A7******** IMEI SV 337********0F1000000 PPM V 03.36, 05-12-05, RM-78, (c) Nokia, C CNT Content: 3_at, V 03.36, 05-12-05, RM-78, (c) Nokia, PSN SJE859980 Product Code 0529987 Basic Product Code 0520041 PSD 0000001F00000000 RETU 32 TAHVO 52 AHNE 30 HW 1000 RFIC 17191719 DSP pb05w32v16 LCD SHARP Failed to read info -> Failed to read SP info BB5 Unlock Started... MCU Version V 03.36 MCU Date 05-12-05 Product RM-78 Manufacturer (c) Nokia IMEI 357********** Mastercode 3626647431 Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1D400115627A0054D197D0886372C0070ECC44DF CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC22FE00000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: EA424306455C103E3853B304DD1BC0E10F839FBC APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Determined PA Simlock: PA_SL Checking for Rootkey Hash support and selecting Unlock Method... Selected Unlock Method: PM Security Block Calculation Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000352 CMT_PUBLIC_ID: 1D400115627A0054D197D0886372C0070ECC44DF CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Writing Security Block... SP Accepted, doing reset to update block... MCU Version V 03.36 MCU Date 05-12-05 Product RM-78 Manufacturer (c) Nokia IMEI 35************ Mastercode 3626647431 Warning: Failed to read SP Info, Assuming defaults BB5 Unlock Failed -> Initial SP corrupted or not a Baseband5 phone detected any other suggestion PTT ? thanks |
04-04-2010, 21:54 | #12 (permalink) |
Member: 213935 Status: Offline Thanks Meter: 2 | i think cyclone team has no answer for me, of course i have checked the phone, it is locked , when i put other sim card it does not work, i can not solve this problem. Last edited by ptt; 04-04-2010 at 22:00. Reason: please dont use black color |
04-04-2010, 21:58 | #13 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | For N70 use other tool, read here : http://forum.gsmhosting.com/vbb/f528...ap3gv2-857926/ And you still using the 1.0.0.8236 software, install the lates software version 1.0.0.8552 read the phone info ( 6280 ) using USB cable instead F-Bus.... BR |
The Following User Says Thank You to ptt For This Useful Post: |
04-04-2010, 22:50 | #14 (permalink) |
Member: 213935 Status: Offline Thanks Meter: 2 | Nokia N70 is already unlocked using other tools, my issue now is Nokia 6280, trying to read info with usb cable instead of Fbus cable, but i get always phone not detected. thank you for your reply. |
5130c ERROR: Missing SP BLOCK or PM corrupted ![Not supported yet] | dhanrhage_24 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 01-20-2010 05:28 |
6630 SP data corrupted to not locked but error | urromeo | Nokia Base Band 5 ( BB-5 ) | 0 | 07-18-2007 15:49 |
Sp Corrupted On Bb5 Phones () | Formingus | Nokia Base Band 5 ( BB-5 ) | 10 | 05-26-2007 11:38 |
Error: Could not initialize GDFS access. can fix or not? | .::Gsmdenis::. | Cruiser Suite | 14 | 10-29-2005 08:30 |
"Could not initialize GDFS access" or "Failed" How come? | MG77 | Cruiser Suite | 3 | 10-26-2005 05:18 |
