08-16-2013, 04:37 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Age: 39
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | lumia 800 RM-819 after root in cyclone error in unlocking... Code: Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.20, (Aug 6 2013 20:34:19, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Key Flasher Interface (c) 2012 KarwosLabs Box Serial Number: A100031A HW Revision: E, Suitable for: Production, Case: GPG Key Casing, MCU Manufacture Time: Blue PCB Rev. 6 2013 wk6, MCU 2011 wk09 Box is activated Started box selftests procedure All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Lumia No TP is ACTIVATED! Avaiable Physical Memory: 1.512GB Avaiable Virtual Memory: 1.806GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work Lumia No TP Root Procedure Started... If phone is alive, It will be automatically swithced to OSBL mode. If software can't switch to OSBL mode, or phone is generally DEAD do folllowing: 1. Turn OFF device, wait 15 seconds afterwards 2. Eject USB cable, wait 10 seconds 3. Press and hold Volume-UP button 4. Insert USB Cable. OSBL should be booted. Booting CMT... [Nokia USB Connectivity]: WinUSB Port opened OK! Switching to RAW Mode... [Nokia USB Connectivity]: WinUSB Port opened OK! [Nokia USB Connectivity]: WinUSB Port opened OK! OSBL Details Protocol: v1.0 Version: v256.4 Build: 10 Timestamp: 9/29/2011 10:38:56 PM OSBL Bootloader Ready USB&UART Tracing set RSA Signature Calculated for QCB Boot, Writing... OSBL Certificate Details Magic: WP70 Version: 0 Signer Server ID: 0x98031573 Signer Timestamp: 9/28/2011 10:52:12 PM Signer S/N: 23 Signer User ID: 10046114 Auth Level: Care Data Encryption: 0 Image Index: 0 Asic Index: 0 Type: Image Write Hashtable Parsed OK Certificate Accepted [ASIC 0, Storage 4,1] Writing 850.552kB @ 0x000000000007D200 Write taken 1.108s (Average speed: 6288.46kBits/s) Restoring Modem from BACKUP_RAMFS_IMAGE... Restore OK Restarting MCU... Rooting Finished! Looking for phone...Not found! Can't read IMEI, backup will be skipped. ---------------------------------------------------------------------------- Looking for NAND disk...Done. Trying to parse partition tables...Done. ---------------------------------------------------- FAT16 absolute address: 0x001F4200 FAT16 partition size: 0x0927C000 ---------------------------------------------------- Searching locations...Nothing found. Searching restore locations...Nothing found. |
08-16-2013, 07:45 | #4 (permalink) |
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | now its done in a matter of tricky combination hehehe... Code: Looking for phone...Done. IMEI: --------------------------------------- Please follow these steps: 1. Power off the phone 2. Remove the USB cable 3. Press and hold the Vol+ button 4. Plug the USB cable, wait for the buzz 5. Release the Vol+ button --------------------------------------- Waiting for 30 seconds...Done. ---------------------------------------------------------------------------- Looking for NAND disk...Not found. Things to check: 1. Is the phone connected?(Plug to the USB) 2. Is it in the correct mode?(Try to switch to OSBL mode) 3. Have you installed the Qcom loader ?(Use the Install button) ---------------------------------------------------- Looking for phone...Not found! Can't read IMEI, backup will be skipped. ---------------------------------------------------------------------------- Looking for NAND disk...Done. Trying to parse partition tables...Done. ---------------------------------------------------- FAT16 absolute address: 0x001F4200 FAT16 partition size: 0x0927C000 ---------------------------------------------------- Searching locations...Done. Found 1 locations to modify, processing: Reading sector 0...Done. Modify sector...Done. Updating sector...Done. Modification written. Please follow those steps: 1. Disconnect USB cable and remove the battery 2. Insert not supported simcard and power on the phone 3. If asked for PIN code, enter 00000000 4. If asked for PUK code, enter 0000000000 5. After unlock success, connect to USB, enter OSBL mode 6. Press Unlock again to restore the phone to original |
08-16-2013, 09:14 | #6 (permalink) | |
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | Quote:
try to analyze and understand first before you type something its RM-819 when you root in cyclone and unlock in nss error.... so try first before you bla! bla! bla! Last edited by alex_030385; 08-16-2013 at 09:20. | |
The Following User Says Thank You to alex_030385 For This Useful Post: |
09-15-2013, 03:47 | #9 (permalink) |
Member: 875541 Status: Offline Sonork: 100.1604468 Thanks Meter: 327 | for me not working in root and unlock only in rm-809 first attemp failed... need to flash it first in rm-801 then root and unlock success... Last edited by alex_030385; 09-15-2013 at 03:53. |
