Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 10-18-2009, 21:48   #1 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 387
Makeing RPL from PM on SL3 posible??????
Hi,
I have a 5310xm v57.57 that now has 1234... damaged imei after trying to downgrade. I had first backuped only PM and not the RPL.
My question is simple: Can I use Cyclone Box function (Make RPL from PM) to restore IMEI to this phone????????
Old 10-18-2009, 22:48   #2 (permalink)
LIEREN's Avatar
Member: 917576
Sonork: QQ:366688456
Thanks Meter: 533
hi,bro
not can,Cyclonebox no support sl3 phone repair imei 123456 fo sp:0000 , bro
Old 10-19-2009, 19:21   #3 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 387
so that means I coud not even bother???????
...same advice from a product supporter???????????
Old 10-19-2009, 20:50   #4 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 13,997
You can make from the PM only a Simlock RPL .. this won't help you in rebuilding the imei.
Did you erase the phone?
Alex
Old 10-20-2009, 05:39   #5 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 956
Dear colleagues, i'm not sure that 5310 v57.57 will accept SL fields - anyway i was test 2 months ago to repair one with damaged security via original RPL ... IMEI is OK, but simlock remain damaged
P.S.
A BIG tnx to moulinisky for all his work and knowledge sharing around new Nokia phones unlock / downgrade / repair ...
The Following User Says Thank You to debeliamark For This Useful Post:
Old 10-20-2009, 10:25   #6 (permalink)
Member: 1021269
Sonork: 100.1623820
Thanks Meter: 9
The latest version of the MX support SL3 write like the RPL
Old 10-20-2009, 10:33   #7 (permalink)
FEATURE GSM™'s Avatar
Member: 276151
Sonork: 100.1577032
Thanks Meter: 231
Thumbs down
Alex
did you have that ok than give her links pls
Old 10-21-2009, 22:12   #8 (permalink)
dragosgsm's Avatar
Member: 148032
Thanks Meter: 387
Unhappy
Alex
sincerily I don't remember if I had erased it it happend long before Cyclone realised this solution (rpl from pm) I had destroyed this phone long time ago when sl3 was at the begining and I didn't know of the apperence of this security type...I think I had erased it...at that time I had tryed evrey thing to return the phone to the initial state to the client...offul moments when this happens...
Old 10-21-2009, 22:29   #9 (permalink)
GSMman187's Avatar
Member: 917893
Sonork: 100.1584763
Thanks Meter: 3,154
Originally Posted by dragosgsm View Post
Hi,
only downgrade or u tried to unlock .. .?!
if onlywrong downgrade..
just reflash phone with correct sl3 software.
Old 10-21-2009, 23:20   #10 (permalink)
moulnisky's Avatar
Member: 947561
If you had a Nokia RPL of that period (an RPL from the Salo server, not from the tucson server) was enaugh erase the phone, flash it with a normal BB5+ firmware version of that mobile, RPL, SX4, FULL PM no 120 no 308 and it was working, BB5+ and easy to unlock
Now without back-ups the only thing you can do is full erase it, including certs, and send to nokia.. it has 2 years warranty
Alex
Create RPL from Pm?.....can Mx do this?. enrocas MXKEY Nokia Flasher and Unlocker (by Alim Hape) 10 08-27-2010 07:19
i can't make rpl from online logger .::PATEL TELECOM::. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 17 03-03-2010 08:52
i need RPL from PM for N96 pls give meeeee cts2007 Nokia Base Band 5 ( BB-5 ) 18 01-11-2010 10:23
Create RPL from PM function moulnisky Cyclonebox 9 06-08-2009 06:56
i want to make rpl from ask file kapilgupta MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 06-07-2009 02:03
Page generated in 0.31268 seconds with 8 queries
