Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2008 Location: k-boxteam THL Age: 36
Member: 716581 Status: Offline Thanks: 1,487
| N-GAGEQD RH-29 Can't write flash Erase complet. when start write flash error but IN same phone and cable flash complet by ufs box cyclone pls.fix Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 1081 [HW_UPP_WD2_v3_1] rh2941.5C1, Type: Flash Image, Algo: WD2 BT2, WD2 ALGORITHM, WD2 CBUS BT Flashbus Write baud set to 100Kbits w3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.76.0, Algo: WD2 BT2 Box VPP disabled Internal Phone VPP Selected PLL Factor: 4 FlashChip[0]: 0x0001007E @ 0x00000000, AMD, SectorSize: 64kB, Ext: 00160111 FlashChip[1]: 0x0001277E @ 0x02000000, AMD, SectorSize: 64kB, Ext: 00020111 Signature: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Flashbus Write baud set to 333Kbits Flashbus Read baud set to 51Kbits w3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x0001007E (128Mbits), Rev: 7.4.76.0, Algo: WD2 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.09V MSID-Crypted: 8440AB22C151882B60A60C0D55 MSID-Plain: 3E4EBAF700DED392A8000000 FAID-Crypted: B5BE6CC7DF5B267234A5F7BF Flashbus Write baud set to 1.80Mbits 3 Region(s) to erase Erasing NOR Region [0x00000000-0x0000FFFF] Erasing NOR Region [0x00010000-0x00FEFFFF] Erasing NOR Region [0x02000000-0x027FFFFF] Erase taken 206.687s Writing 11 blocks... Block Write Failed -> Unknown block at 0 with ID=0x21 found, Can't write Box VPP disabled Processing Flash Image Failed -> Write failed Failed to Flash -> Problem with processing MCU Image file |
| | #2 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: Poland Age: 23
Member: 117496 Status: Offline Sonork: 100.83919 Thanks: 84
| Looks like this is embed CBUS loader, or BT blocks, which we not tested yet ! I will fix this |
| The Following 2 Users Say Thank You to karwos For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| can't write flash in 3220 using UFS3 | dj_mseal | UFS2 + UFS3-Tornadoflasher | 1 | 06-02-2005 07:08 |
| panasonic g60 can't write flash | balanel | Panasonic | 3 | 04-23-2005 12:47 |
| C30 - strange problem - can't WRITE flash! | Tygiel | x1x to x45/x50 | 0 | 11-28-2002 18:36 |
| All Ericsson tool by jethro read ok, but can't write flash?!? | MaRiN | Old Ericsson Phones & Sony Phones | 5 | 07-27-2001 13:00 |
