04-05-2011, 12:26 | #1 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1468822 Status: Offline Thanks Meter: 1 | N70 After Unlock in Few time shut off [ Solved ] Thank for Help in Advance. Berry |
04-05-2011, 13:22 | #2 (permalink) |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Check phone security with Analyze Security button and paste log here. Br, Shadab Ahmad |
The Following User Says Thank You to [Shadab_M] For This Useful Post: |
04-06-2011, 12:10 | #4 (permalink) |
Member: 1468822 Status: Offline Thanks Meter: 1 | Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.57, (Mar 10 2011 12:45:53, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 wk9 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: XXXXXXXX HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk40 Initializing security card... Card Serial Number: XXXXXX00 Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.97v PASSED MCU Voltage 3.35v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.06v PASSED VBAT Voltage 4.82v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.83v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Phone is in Local Mode MCU Version V 05wk07v41 MCU Date 08-02-06 Product RM-84 (Nokia N70) Manufacturer (c) Nokia. IMEI KKK551KKK94KKK6 Mastercode 1224376346 IMEI Spare 3A45KKKKK1494309 IMEI SV 3345550KKKKK4309F6000000 PPM V 5.0609.2.0.1, 01-03-06, RM-84, (C)Nokiaj0,5.0609.2.0.1-Euro1, 01-03-06, RM-84, (c)Nokia.n256o16053 PSN YJA347069 Product Code 0530431 Basic Product Code 0522156 PSD 0000001700000000 APE SW V 5.0609.2.0.1, 01-03-06, RM-84, (C)Nokia APE Variant 5.0609.2.0.1-Euro1, 01-03-06, RM-84, (c)Nokia. APE HW 256 APE ADSP 16053 RETU 32 TAHVO 52 AHNE 22 HW 7001i,'V 5.0609.2.0.1, 01-03-06, RM-84, (C)Nokiaj0,5.0609.2.0.1-Euro1, 01-03-06, RM-84, (c)Nokia.n256o16053 PCI i,'V 5.0609.2.0.1, 01-03-06, RM-84, (C)Nokiaj0,5.0609.2.0.1-Euro1, 01-03-06, RM-84, (c)Nokia.n256o16053 UEM V 5.0609.2.0.1, 01-03-06, RM-84, (C)Nokiaj0,5.0609.2.0.1-Euro1, 01-03-06, RM-84, (c)Nokia.n256o16053 UPP V 5.0609.2.0.1, 01-03-06, RM-84, (C)Nokiaj0,5.0609.2.0.1-Euro1, 01-03-06, RM-84, (c)Nokia.n256o16053 RFIC 150a160f DSP rolf_05wk07v24 LCD V 5.0609.2.0.1, 01-03-06, RM-84, (C)Nokiaj0,5.0609.2.0.1-Euro1, 01-03-06, RM-84, (c)Nokia.n256o16053 BT V 5.0609.2.0.1, 01-03-06, RM-84, (C)Nokiaj0,5.0609.2.0.1-Euro1, 01-03-06, RM-84, (c)Nokia.n256o16053 Failed to read info -> Failed to read extended info Failed to make Selftests -> Selftest Server is not ready, Code: 2 Phone is in Local Mode Selftests to proceed: 34 Passed ST_TAHVOINT_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Passed ST_CMT_APE_WAKEUP_TEST Passed ST_BACKUP_BATT_TEST Passed ST_RADIO_TEST Passed ST_HOOKINT_TEST Passed ST_VIBRA_TEST Passed ST_BTEMP_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Passed ST_CDSP_WCDMA_TX_POWER_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST Failed ST_CDSP_GSM_TX_POWER_TEST Passed ST_KEYBOARD_STUCK_TEST Passed ST_LPRF_IF_TEST Passed ST_CAMERA_IF_TEST Passed ST_SEC_CAMERA_IF_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_MAIN_LCD_IF_TEST Passed ST_BT_WAKEUP_TEST Passed ST_BT_SLEEP_CLK_TEST Selftests done, Tests total: 34, Tests passed: 33, Tests not passed: 1 Started Phone Security Analysis... MCU Version V 05wk07v41 MCU Date 08-02-06 Product RM-84 (Nokia N70) Manufacturer (c) Nokia. IMEI 3XXXXXXXX943496 Mastercode 1224376346 Reading Security Block... Security block OK and saved to "RM-84_35XXXXX49434X6_4172011_20504 AM.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block "1D50010C422A545127C130BF410C2AA1AB658313.C000388D " Exists, That is good... Checking SUPERDONGLE... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?) Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Analyze finished! |
04-06-2011, 13:13 | #6 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Both the test are ok Just write some standard calibrations data or check the battery BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
04-06-2011, 16:33 | #7 (permalink) | |
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | Quote:
Br, Shadab Ahmad | |
04-06-2011, 17:40 | #8 (permalink) | |
Member: 1468822 Status: Offline Thanks Meter: 1 | Quote:
Thank Berry. | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
For Jefferson -6110 goes off itself | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-19-1999 21:28 |
