07-14-2011, 12:52 | #1 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 331337 Status: Offline Thanks Meter: 72 | n70 flaashing problem. please help thanks in advance... Code: Processing rm84_50737301.c0 (CMT)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100701 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 0AE84FA27FDC783F0F464B9A77C0ADA82F2FFC7A APE_ROOT_KEY_HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 APE_BOOT_ROM_CRC: AB5E4ADB APE_SECURE_ROM_CRC: 27A06946 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000341 CMT_PUBLIC_ID: 1FB0000B18884651240672C330D4ED8C00EFA06D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_BOOT_ROM_CRC: F28A211F CMT_SECURE_ROM_CRC: CEA7B19D CMT Ready! rm84_50737301.c0, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP1610 GBBM-1.8.1 ALG Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001000200000111, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00010002 (AMD), Size: 8MBytes, VPP: 31V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x0052B515, NOR EraseArea[0,CMT]: 0x006A0000-0x006BFFFF, NOR EraseArea[0,CMT]: 0x006DF000-0x006EFFFF, NOR EraseArea[0,CMT]: 0x00700000-0x007EFFFF, NOR Waiting 320s for erasure finish... Erase taken 45.584s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Skipping CMT PAPUBKEYS Certificate (already sent)... Programming Status OK! All blocks written OK! Time taken 25.755s Flashing Speed: 9579.49 kBit/S Restarting MCU... Processing rm84_50737301.c0 (APE)... Booting CMT... APE_SYSTEM_ASIC_ID: 17100701 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: 0AE84FA27FDC783F0F464B9A77C0ADA82F2FFC7A APE_ROOT_KEY_HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 APE_BOOT_ROM_CRC: AB5E4ADB APE_SECURE_ROM_CRC: 27A06946 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000341 CMT_PUBLIC_ID: 1FB0000B18884651240672C330D4ED8C00EFA06D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_BOOT_ROM_CRC: F28A211F CMT_SECURE_ROM_CRC: CEA7B19D CMT Ready! rm84_50737301.c0, Type: Flash Image, Algo: BB5, BB5 ALGORITHM, BB5, OMAP1610 GBBM-1.8.1 ALG Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0001000200000111, AMD, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00010002 (AMD), Size: 8MBytes, VPP: 31V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,APE]: 0x00EC003600A500C0, Samsung, NAND Requested Algorithm: OMAP1610 GBBM-1.8.1 ALG (APE) FlashContent[0,APE]: 00020000000600000000000000000000, NAND Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol) FlashChip 0x00EC0036 (Samsung), Size: 64MBytes, VPP: 21V h3_sam_nand_gbbm.fg, Type: Algorithm, Rev: 0.1.33.0, Algo: OMAP1610 GBBM-1.8.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Flashbus Write baud set to 5.0Mbits Partitioning... Partitioning OK Started group flash erase EraseArea[0,APE]: 0x00000000-0x0000FFFF, NAND EraseArea[0,APE]: 0x00010000-0x0001FFFF, NAND EraseArea[0,APE]: 0x00020000-0x000203FF, NAND EraseArea[0,APE]: 0x00050000-0x03ECFFFF, NAND Waiting 320s for erasure finish... Erase taken 6.365s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing APE KEYS Certificate... Writing APE X-LOADER Certificate... Writing APE PRIMAPP Certificate... Writing APE SOS+LOADER Certificate... Writing APE SOS+XZIP Certificate... Writing APE PASUBTOC Certificate... Writing APE PAPUBKEYS Certificate... Skipping APE PAPUBKEYS Certificate (already sent)... Writing APE SOS*CORE Certificate... Programming Status OK! All blocks written OK! Time taken 32.276s Flashing Speed: 7644.06 kBit/S Restarting MCU... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Reading info... MCU Version V 05wk07v48.1 MCU Date 28-08-07 Product RM-84 (Nokia N70) Manufacturer (c) Nokia. IMEI 357093005788116 Mastercode 454214472 IMEI Spare 3A75900350871801 IMEI SV 3375900350871811F2000000 PSN CPB340426 Product Code 0529040 Basic Product Code 0522156 PSD 0000001700000000 RETU 32 TAHVO 41 AHNE 22 HW 6001 RFIC 150a160e DSP rolf_05wk07v29p1 Simlock Server SIMLOCK SERVER VERSION 58 Simlock Key 2343300000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 1 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 23433F Simlock [2,1] State: OPENED Type: MCC-MNC Data: 23486F Simlock [3,1] State: OPENED Type: MCC-MNC Data: 23433F Simlock [4,1] State: OPENED Type: MCC-MNC Data: 23486F Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 07-14-2011 at 15:24. Reason: add Code Tag |
07-14-2011, 15:32 | #5 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Middle East
Member: 950386 Status: Offline Thanks Meter: 114 | Cyclone is know to have issues with N70. Also 6680. It is wise to use another tool with this model. Anyway saying that as kaisak said use TX2. If the problem is still there then you could be flashing this phone in the incorrect way (The n70 is like the 6680 when it comes to flashing, MCU & PPM only). When ever i flash n70 with image i get problems (like the phone would switch off after 15 minutes). If indeed its a bad flash you will need to clean the phone (format) before reflashing. Only flash with MCU & PPM. Kind Regards |
The Following User Says Thank You to LOCKED4EVER For This Useful Post: |
07-15-2011, 18:41 | #6 (permalink) |
Member: 331337 Status: Offline Thanks Meter: 72 | hi mate, i have tried both but still same problem. i have done selftest and info its like below. any idea because this phone still stuck on nokia logo. please help Passed ST_TAHVOINT_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Failed ST_CMT_APE_WAKEUP_TEST Passed ST_BACKUP_BATT_TEST Passed ST_RADIO_TEST Passed ST_HOOKINT_TEST Passed ST_VIBRA_TEST Passed ST_BTEMP_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Failed ST_CDSP_TX_IQ_TEST Failed ST_CDSP_TXC_DATA_TEST Failed ST_CDSP_WCDMA_TX_POWER_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST Passed ST_CDSP_GSM_TX_POWER_TEST Passed ST_KEYBOARD_STUCK_TEST Passed ST_LPRF_IF_TEST Passed ST_CAMERA_IF_TEST Passed ST_SEC_CAMERA_IF_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_MAIN_LCD_IF_TEST Passed ST_BT_WAKEUP_TEST Passed ST_BT_SLEEP_CLK_TEST Selftests done, Tests total: 34, Tests passed: 30, Tests not passed: 4 |
07-15-2011, 19:55 | #8 (permalink) |
Member: 331337 Status: Offline Thanks Meter: 72 | this phone was slow so we tried to update software from nokia website, while we were updating battery went dead so phone was dead, now im trying to sort it out with cyclone. i have flashed it but its stuck on nokia logo. |
