Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2008 Location: philippines Age: 44
Member: 883572 Status: Offline Thanks: 102
| n70 white screen only pls help(moulnisky) all i did is create a back up of rpl, pm n all certificates. now i turn the phone on n only white screen.pls help i have all back up Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918 Handling device: [Cyclone Team], [Cyclone Box] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Initializing box... Box Firmware: Cyclone Nokia Application v1.07, (Sep 11 2009 03:35:10, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: NoFlags Box Firmware: Cyclone Nokia Application v1.07, (Sep 11 2009 03:35:10, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: NoFlags Box Serial Number: C00018E6 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Box Serial Number: C00018E6 Initializing security card... HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19 Initializing security card... Card Serial Number: D3000133 Card Firmware Revision: 0109 Card is activated Card Serial Number: D3000133 Card Firmware Revision: 0109 Box is activated Card is activated Started box selftests procedure USB Voltage 4.93v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.75v PASSED Box is activated Started box selftests procedure USB Voltage 5.02v PASSED MCU Voltage 3.30v PASSED Core Voltage 1.75v PASSED VBAT Voltage 1.42v PASSED VBAT Voltage 4.91v PASSED Box VPP disabled VBAT Voltage 1.52v PASSED VBAT Voltage 4.88v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V 05wk07v47 MCU Date 30-01-07 Product RM-84 Manufacturer (c) Nokia. IMEI 351863019701966 Mastercode 6062704112 IMEI Spare 3A15680391079106 IMEI SV 3315680391079116F0000000 PSN CTD056836 Product Code 0539272 Basic Product Code 0536420 PSD 0000001700000000 RETU 32 TAHVO 53 AHNE 22 HW 7002 RFIC 150a160f DSP rolf_05wk07v29p1 Failed to read info -> Failed to read SP info Selftests to proceed: 26 Passed ST_TAHVOINT_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Failed ST_CMT_APE_WAKEUP_TEST Passed ST_BACKUP_BATT_TEST Passed ST_RADIO_TEST Passed ST_HOOKINT_TEST Passed ST_VIBRA_TEST Passed ST_BTEMP_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Passed ST_CDSP_WCDMA_TX_POWER_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST Failed ST_CDSP_GSM_TX_POWER_TEST Selftests done, Tests total: 26, Tests passed: 24, Tests not passed: 2 |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006 Location: king solomons temple
Member: 301387 Status: Offline Thanks: 31
| yes after unlock you get white screen hope we get thier attention and product supporters try to resolve this problem...... regards |
| | #5 (permalink) |
| Booting RAP... APE_SYSTEM_ASIC_ID: 17100701 APE_ASIC_MODE_ID: 00 APE_PUBLIC_ID: BE01C5F21E8ECD5A5475BECA369B5153A3060C3F APE_ROOT_KEY_HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 APE_ROM_ID: AB5E4ADB27A06946 CMT_SYSTEM_ASIC_ID: 000000010000022600010006000C192101002200 CMT_EM_ASIC_ID: 00000232 CMT_EM_ASIC_ID: 00000353 CMT_PUBLIC_ID: 20B00007F1135951D03E9C27B40BBA59B9FA2E6E CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: E9EFF4BFAA5393217CA6B17755FC3E14 CMT_ROM_ID: F28A211FCEA7B19D RAP3Gv2_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.21.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC225000000121, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D helen3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.35.0, Algo: BB5 FlashChip[0,APE]: 0x0098003600A500C0, Toshiba, NAND Requested Algorithm: OMAP1710 UNISTORE-II-1.2.1 ALG (APE) FlashContent[0,APE]: 00020000000600000000000000000000, NAND h3_sam_nand_xsr.fg, Type: Algorithm, Rev: 0.1.49.0, Algo: OMAP1710 UNISTORE-II-1.2.1 ALG Box VPP disabled Internal APE Phone VPP Enabled PAPUBKEYS Hash for APE: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Flashbus Write baud set to 5.0Mbits Restarting MCU... |
| | #6 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Sep 2006 Location: On Vacation !!! Age: 36
Member: 348680 Status: Offline Thanks: 411
| You Phone goes to Localmode ? try to put in "Normal" ( in "Info" tab, mark "normal" and press "set" ) You can try to restore the Certs that you create: search for "20B00007F1135951D03E9C27B40BBA59B9FA2E6E" and use "write certs" BR |
| | #9 (permalink) |
| this problem also hhappen to me and was resolve by anothher tool.... did not know by just baccking up n70 gets white screen. i did not check after back up../ what i did is backup then unlock result is white screen. perhaps this problem needs to be look upon by cycclone producers.. regards |
| | #11 (permalink) | |
| Quote:
| | #12 (permalink) |
| its not hardware fault look at my post was resolve by anothher tool.... still software..... ye phone was working normal before backup and unlock... if one of you now has n70 do try to read back up and unlock you will see result.. try it and believe.... i tried another n70 same result white screen... i was not afraid to do it because i know the cure... and can be cured by another tool... not to mention tool brand in this section you know "ETHICS"..... still software... REGARDS |
| | #13 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2005
Member: 154932 Status: Offline Thanks: 2
| To Ferdie1969 Mate just read my previous post the same problem im encountered my n70 just to read info for read codes after that Result: "White Screen" What you did for remedy just to flash for same version or higher version and your problem solved......... |
| | #15 (permalink) | |
| Quote:
I had to go get it flash with jaf n now phone working again. Man, i never had a phone turn white screen just creating a back up. Thats f--k up. Anyways problem solve by jaf | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| N70 white screen only | aland1234 | HWK | 7 | 08-30-2009 15:47 |
| n70 white screen not virus problem pls help | kendevil | Nokia Hardware & Hardware-Repair Area | 15 | 11-03-2007 17:13 |
| n70 white screen only..plz help | markrhi | Nokia Base Band 5 ( BB-5 ) | 10 | 07-16-2007 16:42 |
| another ways n70 white screen pls help | markrhi | Nokia Hardware & Hardware-Repair Area | 7 | 07-05-2007 15:00 |
| N70 white screen only...flash with mt-box only boot failed...hardware or software | acelai00 | Nokia Hardware & Hardware-Repair Area | 8 | 04-05-2007 11:02 |
