09-10-2010, 11:52 | #16 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | if for you is ok, start teamviewer and pass me via private message the parameters for the remote connection: we can have a look at the mobile together BR Alex |
09-11-2010, 19:50 | #20 (permalink) |
No Life Poster Join Date: Oct 2007 Location: South Africa/Pakistan
Member: 619308 Status: Offline Sonork: 100.1591829 Thanks Meter: 243 | first of use mxkey to make npc backup. and then use jaf to erase ur phone. and then flash ur phone with jaf using any version. ur phone will be alive. but imei will be 1234........ . and ur phone will be on contact retailer .then go back to mxkey and recover imie. and ur imei will be ok. then use cyclone to auth sxh and write pm 1 and 308. and then go back to mxkey and recover certificate.now ur phone is 10000% working. and ur problem is software. not hard ware. i did fix lot of phone with this problem |
09-21-2010, 17:42 | #21 (permalink) |
Freak Poster Join Date: Dec 2002 Location: slovakia Age: 48
Member: 18876 Status: Offline Thanks Meter: 27 | Just flash your phone with JAF and 7 pin cable. Cyclone always give the same result (blue screen) for me with N73 flashing. Tested many times. The same flashing problems have MTbox, Universalbox, even HWK with this phones too. |
The Following User Says Thank You to MiH For This Useful Post: |
10-15-2010, 08:59 | #23 (permalink) |
Registered User Join Date: Dec 2009 Location: p A k I s T a N
Member: 1178981 Status: Offline Sonork: 100.1596342 Thanks Meter: 500 | bro flash with that version ( RM-133_APAC_4.0850.43.0.1_v23.0 ) then try to downgarde your problem will be solved i tested many times. |
The Following User Says Thank You to RAVI_SINGH For This Useful Post: |
10-21-2010, 21:57 | #25 (permalink) | |
Freak Poster Join Date: Oct 2010 Location: !!!Suck Me I Know You Can!!!
Member: 1421351 Status: Offline Sonork: 100.1605689 Thanks Meter: 143 | Quote:
If you not sure about the problem and can't use selftest feature, try to powering on the phone,if you hear statup tone.. it mean your phone is okey in software and this is PURE 100% hardware problem In other case if your phone not booted at all, you need to backup FULL RPL AND SIMLOCK area,try to erase flash ic with other tools,after that flash again with higher version and no need to use screwdriver at all,cause it software problem. Please post the result. | |
10-21-2010, 21:59 | #26 (permalink) | |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
