03-05-2010, 15:15 | #1 (permalink) |
No Life Poster Join Date: Jul 2007 Location: kingdom of saudi arabia
Member: 540878 Status: Offline Thanks Meter: 910 | N76 contact retailer/sec test failed...error in writing PM a MCU Version V 06wk41v34.2 MCU Date 24-08-07 Product RM-135 Manufacturer (c) Nokia IMEI 356262017723137 Mastercode 136130333 Reading Security Block... Security block OK and saved to "RM-135_356262017723137_352010_61202 AM.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY -- SECURITY PROBLEM -- Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 -- SECURITY PROBLEM -- Step 3 : Analyzing Security Block "15600102AD5C0058E387E84B68EA92C284A30764.C000009B " Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... SIMLOCK FOUND AND CHECKSUM OK! PASSED! Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... CMLA KEYS FOUND AND CHECKSUM OK! PASSED! Checking ECC KEYS... ECC KEYS FOUND AND CHECKSUM OK! PASSED! Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! SX4 Authorization / SD Repair Procedure Started.... "15600102AD5C0058E387E84B68EA92C284A30764.C000009B " Exists, That is good... MCU Version V 06wk41v34.2 MCU Date 24-08-07 Product RM-135 Manufacturer (c) Nokia IMEI 356262017723137 Mastercode 136130333 Reading Security Block... Security block OK and saved to "RM-135_356262017723137_352010_61220 AM.SecurityBlock.PM" SX4 Status: Not authorized (76) Started mutual authenthication with card... Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! WRITE NOW VIRGIN SX4 PM which CONTAINS PM FIELDS 1 and 309! [1,0] Written, Length: 114 bytes, Status: OK [1,1] Written, Length: 4 bytes, Status: OK [1,2] Written, Length: 98 bytes, Status: Not accepted, Code: 20 [1,4] Written, Length: 110 bytes, Status: Not accepted, Code: 20 [1,5] Written, Length: 4 bytes, Status: OK [1,6] Written, Length: 98 bytes, Status: Not accepted, Code: 20 [1,8] Written, Length: 110 bytes, Status: OK [1,13] Written, Length: 98 bytes, Status: OK [1,15] Written, Length: 4 bytes, Status: OK [1,16] Written, Length: 98 bytes, Status: Not accepted, Code: 20 [1,18] Written, Length: 98 bytes, Status: Not accepted, Code: 20 [1,20] Written, Length: 98 bytes, Status: Not accepted, Code: 20 [1,22] Written, Length: 16 bytes, Status: OK [1,23] Written, Length: 4 bytes, Status: OK [1,24] Written, Length: 84 bytes, Status: OK [1,25] Written, Length: 4 bytes, Status: OK [1,26] Written, Length: 110 bytes, Status: OK [1,27] Written, Length: 4 bytes, Status: OK [1,28] Written, Length: 98 bytes, Status: Not accepted, Code: 20 [1,29] Written, Length: 10 bytes, Status: OK [1,31] Written, Length: 98 bytes, Status: Not accepted, Code: 20 [1,33] Written, Length: 36 bytes, Status: OK [1,34] Written, Length: 80 bytes, Status: Not accepted, Code: 20 [1,44] Written, Length: 182 bytes, Status: OK [309,0] Written, Length: 4 bytes, Status: OK [309,1] Written, Length: 2 bytes, Status: OK [309,2] Written, Length: 12 bytes, Status: Not accepted, Code: 20 [309,4] Written, Length: 12 bytes, Status: OK [309,5] Written, Length: 12 bytes, Status: OK [309,7] Written, Length: 12 bytes, Status: OK [309,8] Written, Length: 12 bytes, Status: OK [309,17] Written, Length: 12 bytes, Status: OK [309,22] Written, Length: 12 bytes, Status: OK Write PM Finished, Record written OK: 23, Record written NOT OK: 10 i tried 5 edited PM...but still contact retailer |
03-05-2010, 18:45 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 58
Member: 947561 Status: Offline Thanks Meter: 14,052 | Are you sure it is an N76 RM-135? normally error 20 you get when the PM doesn't belong to the model. BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
03-05-2010, 19:58 | #3 (permalink) |
Member: 540878 Status: Offline Thanks Meter: 910 | based on the sticker...it is rm-135 (n76-1) there is rm-149(n76-5)...but i am not sure if this is rm-149 assuming this is rm-149, do you have a PM for this one? |
03-05-2010, 21:11 | #4 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,052 | Hi Prof, all the PM I have are in this collection I posted time ago http://forum.gsmhosting.com/vbb/atta...8&d=1266250280 Have a check.. may be it is in BR Alex |
03-06-2010, 14:50 | #7 (permalink) |
Member: 540878 Status: Offline Thanks Meter: 910 | there is one guy in philippines posted same problem in our number one local forum...i wrote the PM he used...but unfortunately it did not fix.... Last edited by professor linux; 03-06-2010 at 14:58. |
03-06-2010, 16:21 | #8 (permalink) |
Member: 540878 Status: Offline Thanks Meter: 910 | analyze Security block OK and saved to "RM-135_356262017723137_362010_72433 AM.SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY -- SECURITY PROBLEM -- Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 -- SECURITY PROBLEM -- Step 3 : Analyzing Security Block "15600102AD5C0058E387E84B68EA92C284A30764.C000009B " Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... SIMLOCK FOUND AND CHECKSUM OK! PASSED! Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... CMLA KEYS FOUND AND CHECKSUM OK! PASSED! Checking ECC KEYS... ECC KEYS FOUND AND CHECKSUM OK! PASSED! Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! -------- Selftests to proceed: 34 Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SIM_LOCK_TEST Failed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Passed ST_BACKUP_BATT_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_VIBRA_TEST Passed ST_HOOKINT_TEST Passed ST_BTEMP_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST i had fixed many contact retailer/sec test failed...but this is unusual error... Last edited by professor linux; 03-06-2010 at 16:26. |
N76 security test failed, error in writing PM | professor linux | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 14 | 03-07-2010 08:45 |
N96 Phone Start-up failed Contact the retailer (security Test failed in reading) | dmaetrey | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-08-2010 13:46 |
5220 contact service sec test failed | bhuvanele | Universalbox | 7 | 02-06-2010 16:03 |
5800 contact retailer security test failed sx4 not sucess. why?????? | shahinahmed007 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 22 | 02-02-2010 14:33 |
