Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2007 Location: ALGERIA
Member: 447187 Status: Online Thanks: 146
| N8 dead not flashed with Fbus Hi, problem with N8 dead not accept flash with Fbus cable. Code: Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Nokia/Blackberry Application v01.82, (Nov 12 2011 09:45:38, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C000 HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk45 / 2008, wk35 Initializing security card... Card Serial Number: D0030 Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 5,07v PASSED MCU Voltage 3,27v PASSED Core Voltage 1,79v PASSED VBAT Voltage 0,81v PASSED VBAT Voltage 5,04v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 5,01v PASSED Box VPP disabled VPP Voltage 0,02v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Credits Left: 99 Avaiable Physical Memory: 551.636MB Avaiable Virtual Memory: 1.490GB Avaiable Pagefile: 1.282GB Initializing FBUS... All initialized - Ready to work Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM-596_025.008_79.92_prd.core.fpsx (CMT)... Booting CMT... Failed to Boot CMT -> CMT Error, not ready to accept Secondary Loader Processing Flash Image Failed -> Failed to Boot CMT Failed to Process all Image files -> Failed to process RM-596_025.008_79.92_prd.core.fpsx Booting CMT... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00000C35 CMT_EM_ASIC_ID: 00000C30 CMT_PUBLIC_ID: 10900219BFA8034476D8ACB430CBB7C31D30336D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.24.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005000000031, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0050 (Samsung), Size: 512MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.11.24.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... Failed to send CMT FUR Algorithm -> Failed to Restart MCU and Load Algorithm Prepare phone failed with message -> Failed to Send CMT Algorithm Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM-596_025.008_79.92_prd.core.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00000C35 CMT_EM_ASIC_ID: 00000C30 CMT_PUBLIC_ID: 10900219BFA8034476D8ACB430CBB7C31D30336D CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! RM-596_025.008_79.92_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.24.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC005000000031, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0050 (Samsung), Size: 512MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.11.24.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... Failed to send CMT FUR Algorithm -> Failed to Restart MCU and Load Algorithm Processing Flash Image Failed -> Failed to Send CMT Algorithm Failed to Process all Image files -> Failed to process RM-596_025.008_79.92_prd.core.fpsx |
| | #3 (permalink) |
| phone dead no accept flash with Usb or Fbus cable, I don't know history for this phone. The customer said to me the problem after insert memory card???. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 04-10-2013 02:07 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
| Help with 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 05-25-2009 16:29 |
| Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 4 | 06-09-1999 17:04 |
| fbus-mbus | ratzfatz | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 06-05-1999 13:46 |
