Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 08-01-2012, 15:56   #1 (permalink)
GSM_IMRAN's Avatar
Member: 987290
Sonork: 100.1605523
N8 simlock [Solved]
I think cyclone team could help me in this
I had a N8 and wanted to do Factory setting to the phone as it was having security code.
I flashed the phone by usb and fbus with belle and anna versions, The phone flashed well but it wasn't taking factory setting but the phone was switching on perfectly.
So it tried to erase the phone and give it a try.
I was able to backup full pm and Rpl which only has npc, hwc and ccc but no simlock.
I erased the phone flashed it with belle the phone now goes to local mode.
I could do factory reset, but after restoring the rpl, i tried to restore original full pm but it dosent restores its simlock data.
I tried converting the pm file to rpl with cyclone but that rpl didn't works
I have tried writing this pm with sx4 authentication but cant write section 308
Please kindly guide me through this mess.
I have attached the backed up pm and rpl.
Old 08-01-2012, 16:18   #2 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: ( Protected )
Pm 308 write protected .. Sl3 sim lock datas at 120 .. Post your pm restoring and rpl restoring log
Old 08-01-2012, 16:40   #3 (permalink)
GSM_IMRAN's Avatar
Member: 987290
Sonork: 100.1605523
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.01, (Apr 29 2012 16:16:15, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C00079C9
HW Revision: C, Suitable for: Production, Case: 2011 - New Casing, MCU Manufacture Time: 2011, wk01
Initializing security card...
Card Serial Number: D00D016B
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.04v PASSED
MCU Voltage 3.29v PASSED
Core Voltage 1.78v PASSED
VBAT Voltage 1.01v PASSED
VBAT Voltage 4.95v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Internal Box VPP Enabled
VPP Voltage 5.01v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 96
Avaiable Physical Memory: 1.679GB
Avaiable Virtual Memory: 1.898GB
Avaiable Pagefile: 3.669GB
Initializing FBUS...
All initialized - Ready to work
MCU Version V 79_sr1_11w42.5
MCU Date 25-11-11
Product RM-596 (Nokia N8)
Manufacturer (c) Nokia
IMEI 352684047934182
Mastercode 212275137
IMEI Spare 3A25860474391408
IMEI SV 3325860474391438F3000000
Failed to read info -> Failed to read extended info
[1,0] Written, Length: 12 bytes, Status: Not accepted, Code: 19
[1,1] Written, Length: 96 bytes, Status: Not accepted, Code: 19
[1,2] Written, Length: 112 bytes, Status: Not accepted, Code: 19
[1,4] Written, Length: 12 bytes, Status: Not accepted, Code: 19
[1,6] Written, Length: 112 bytes, Status: Not accepted, Code: 19
[1,7] Written, Length: 452 bytes, Status: Not accepted, Code: 19
[1,8] Written, Length: 12 bytes, Status: Not accepted, Code: 19
[1,13] Written, Length: 112 bytes, Status: Not accepted, Code: 19
[1,15] Written, Length: 32 bytes, Status: Not accepted, Code: 19
[1,16] Written, Length: 32 bytes, Status: Not accepted, Code: 19
[1,17] Written, Length: 32 bytes, Status: Not accepted, Code: 19
[1,18] Written, Length: 32 bytes, Status: Not accepted, Code: 19
[1,19] Written, Length: 32 bytes, Status: Not accepted, Code: 19
[1,22] Written, Length: 24 bytes, Status: Not accepted, Code: 19
[1,26] Written, Length: 12 bytes, Status: Not accepted, Code: 19
[1,27] Written, Length: 36 bytes, Status: Not accepted, Code: 19
[1,28] Written, Length: 112 bytes, Status: Not accepted, Code: 19
[1,29] Written, Length: 12 bytes, Status: Not accepted, Code: 19
[1,30] Written, Length: 36 bytes, Status: Not accepted, Code: 19
[1,31] Written, Length: 24 bytes, Status: Not accepted, Code: 19
[1,32] Written, Length: 216 bytes, Status: Not accepted, Code: 19
[1,33] Written, Length: 36 bytes, Status: Not accepted, Code: 19
[1,35] Written, Length: 24 bytes, Status: Not accepted, Code: 19
[1,36] Written, Length: 24 bytes, Status: Not accepted, Code: 19
[1,38] Written, Length: 216 bytes, Status: Not accepted, Code: 19
[1,39] Written, Length: 36 bytes, Status: Not accepted, Code: 19
[1,40] Written, Length: 24 bytes, Status: Not accepted, Code: 19
[1,41] Written, Length: 216 bytes, Status: Not accepted, Code: 19
[1,43] Written, Length: 36 bytes, Status: Not accepted, Code: 19
[1,44] Written, Length: 216 bytes, Status: Not accepted, Code: 19
[1,45] Written, Length: 216 bytes, Status: Not accepted, Code: 19
[2,0] Written, Length: 2808 bytes, Status: OK
[4,3] Written, Length: 12 bytes, Status: OK
[4,4] Written, Length: 8 bytes, Status: OK
[4,5] Written, Length: 8 bytes, Status: OK
[4,9] Written, Length: 8 bytes, Status: OK
[6,0] Written, Length: 96 bytes, Status: OK
[8,0] Written, Length: 4 bytes, Status: OK
[8,1] Written, Length: 16 bytes, Status: OK
[8,2] Written, Length: 16 bytes, Status: OK
[8,3] Written, Length: 128 bytes, Status: OK
[8,4] Written, Length: 128 bytes, Status: OK
[8,5] Written, Length: 8 bytes, Status: OK
[8,8] Written, Length: 8 bytes, Status: OK
[8,9] Written, Length: 8 bytes, Status: OK
[8,10] Written, Length: 32 bytes, Status: OK
[8,11] Written, Length: 4 bytes, Status: OK
[8,12] Written, Length: 4 bytes, Status: OK
[11,0] Written, Length: 4 bytes, Status: OK
[11,1] Written, Length: 4 bytes, Status: OK
[11,2] Written, Length: 4 bytes, Status: OK
[11,3] Written, Length: 4 bytes, Status: OK
[11,4] Written, Length: 1060 bytes, Status: OK
[12,0] Written, Length: 8 bytes, Status: OK
[26,0] Written, Length: 16 bytes, Status: OK
[26,1] Written, Length: 68 bytes, Status: OK
[31,4] Written, Length: 12 bytes, Status: OK
[44,0] Written, Length: 4 bytes, Status: OK
[50,0] Written, Length: 4 bytes, Status: OK
[54,0] Written, Length: 4 bytes, Status: OK
[54,2] Written, Length: 24 bytes, Status: OK
[96,0] Written, Length: 4 bytes, Status: OK
[96,1] Written, Length: 20 bytes, Status: OK
[107,26] Written, Length: 12 bytes, Status: OK
[117,0] Written, Length: 4 bytes, Status: OK
[117,1] Written, Length: 4 bytes, Status: OK
[117,2] Written, Length: 8 bytes, Status: OK
[117,3] Written, Length: 4 bytes, Status: OK
[117,5] Written, Length: 12 bytes, Status: OK
[117,6] Written, Length: 8 bytes, Status: OK
[117,8] Written, Length: 44 bytes, Status: OK
[117,13] Written, Length: 4 bytes, Status: OK
[117,14] Written, Length: 4 bytes, Status: OK
[117,16] Written, Length: 40 bytes, Status: OK
[120,0] Written, Length: 944 bytes, Status: OK
[120,1] Written, Length: 160 bytes, Status: OK
[120,2] Written, Length: 132 bytes, Status: OK
[120,3] Written, Length: 112 bytes, Status: OK
[122,0] Written, Length: 4 bytes, Status: OK
[153,0] Written, Length: 68 bytes, Status: OK
[153,1] Written, Length: 68 bytes, Status: OK
[153,2] Written, Length: 68 bytes, Status: OK
[153,3] Written, Length: 68 bytes, Status: OK
[153,4] Written, Length: 68 bytes, Status: OK
[153,5] Written, Length: 68 bytes, Status: OK
[193,2] Written, Length: 8 bytes, Status: OK
[193,3] Written, Length: 32 bytes, Status: OK
[193,4] Written, Length: 32 bytes, Status: OK
[193,9] Written, Length: 64 bytes, Status: OK
[217,0] Written, Length: 32 bytes, Status: OK
[239,0] Written, Length: 4 bytes, Status: OK
[239,1] Written, Length: 3820 bytes, Status: OK
[239,2] Written, Length: 3820 bytes, Status: OK
[239,3] Written, Length: 3820 bytes, Status: OK
[239,4] Written, Length: 3820 bytes, Status: OK
[239,5] Written, Length: 3820 bytes, Status: OK
[239,6] Written, Length: 220 bytes, Status: OK
[291,0] Written, Length: 92 bytes, Status: OK
[308,0] Written, Length: 4 bytes, Status: Not accepted, Code: 19
[308,1] Written, Length: 8192 bytes, Status: Not accepted, Code: 19
[308,3] Written, Length: 4 bytes, Status: Not accepted, Code: 19
[308,4] Written, Length: 4 bytes, Status: Not accepted, Code: 19
[308,6] Written, Length: 4 bytes, Status: Not accepted, Code: 19
[308,7] Written, Length: 4 bytes, Status: Not accepted, Code: 19
[308,9] Written, Length: 40 bytes, Status: Not accepted, Code: 19
[309,0] Written, Length: 4 bytes, Status: Not accepted, Code: 19
[309,1] Written, Length: 4 bytes, Status: Not accepted, Code: 19
[309,2] Written, Length: 12 bytes, Status: Not accepted, Code: 19
[309,3] Written, Length: 36 bytes, Status: Not accepted, Code: 19
[309,4] Written, Length: 12 bytes, Status: Not accepted, Code: 19
[309,7] Written, Length: 12 bytes, Status: Not accepted, Code: 19
[309,17] Written, Length: 12 bytes, Status: Not accepted, Code: 19
[313,0] Written, Length: 800 bytes, Status: OK
[322,0] Written, Length: 4 bytes, Status: OK
[327,0] Written, Length: 4 bytes, Status: OK
[329,0] Written, Length: 8392 bytes, Status: OK
[334,0] Written, Length: 4 bytes, Status: OK
[341,0] Written, Length: 4 bytes, Status: OK
[341,3] Written, Length: 4 bytes, Status: OK
[341,4] Written, Length: 4516 bytes, Status: OK
[341,10] Written, Length: 4 bytes, Status: OK
[341,11] Written, Length: 1972 bytes, Status: OK
[341,12] Written, Length: 328 bytes, Status: OK
[354,0] Written, Length: 12 bytes, Status: OK
[356,0] Written, Length: 4 bytes, Status: OK
[356,1] Written, Length: 8 bytes, Status: OK
[360,0] Written, Length: 4 bytes, Status: OK
[360,1] Written, Length: 4 bytes, Status: OK
[369,0] Written, Length: 40 bytes, Status: OK
[382,0] Written, Length: 64 bytes, Status: OK
[382,1] Written, Length: 4 bytes, Status: OK
[388,0] Written, Length: 4 bytes, Status: OK
Write PM Finished, Record written OK: 87, Record written NOT OK: 45
Skipping RPL decryption...
Erasing Security...
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104
CMT_EM_ASIC_ID: 00000C35
CMT_EM_ASIC_ID: 00000C30
CMT_PUBLIC_ID: 17100110EDA40344E01184A3A2D11BAEA95EF7D4
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B
CMT_BOOT_ROM_CRC: E693EF0D
CMT_SECURE_ROM_CRC: AC22615B
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.11.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC005000000031, Samsung, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00EC0050 (Samsung), Size: 512MBytes, VPP: Not Supported
RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.11.0, Algo: XSR 1.6
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: D172C32473AE199B213465ABB3853246F9631231
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
CMT NPC Erased
Restarting MCU...
Parsing decrypted RPL...
Processing FBUS Part...
Writing Simlock...
Handling as SL3 Simlock Data
Handling as SIMLOCK1 Format
Reading Security Block...
Security block OK and saved to "RM-596_12345610654321_01082012_80616 PM.SecurityBlock.PM"
15 Digits NCK Found
Simlock ACCEPTED OK !
Processing FLASHBUS Part...
No Certificates detected in RPL File, Skipping...
Write RPL Finished!
Failed to Write RPL File -> No RPL File Provided by User
RPL Creation started...
Processing CMT Part...
Storing Product Code...
Storing PSN...
Storing HWID...
Trying to store Simlock...
Reading Configuration Key...
Hashing...
Reading SHA1-RSA Signature...
Reading SHA1-HMAC Signature...
Storing Simlock...
Trying to store WMDRM RPL...
Reading Keys...
Storing WMDRM PD...
Security block OK and saved to "RM-596_12345610654321_01082012_80635 PM.SecurityBlock.PM"
WARNING: "17100110EDA40344E01184A3A2D11BAEA95EF7D4.C00079C9 " Not Exists, Will read it...
Reading CYC file from phone...
Booting CMT...
Failed to Boot CMT -> CMT Error, not ready to accept Secondary Loader
Prepare phone failed with message -> Failed to Boot CMT
Neither CYC file and exists or failed to read it from phone (Failed to Boot / Prepare Phone)
Booting CMT...
Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem
Failed to Create RPL from phone -> Failed to Boot / Prepare Phone
Erasing Security...
Failed to Write RPL File -> Canceled by user
Storing PSN...
Storing HWID...
Hashing...
Storing Simlock...
Reading Keys...
Storing WMDRM PD...
Security block OK and saved to "RM-596_12345610654321_01082012_80722 PM.SecurityBlock.PM"
Booting CMT...
CMT Ready!
New_RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.10.48.1, Algo: BB5
Sending Auxiliary Loader...
Auxiliary Loader Sent!
Loader: RAPxx CommonBoot v1.06 (C) 2011 KarwosLabs
Custom loader running OK! Working...
Readed OK, Saving to "17100110EDA40344E01184A3A2D11BAEA95EF7D4.C00079C9 "
Storing Additional Data...
Checking Superdongle Key...
Encrypting Superdongle Key...
Storing Superdongle Key...
Checking CMLA Key...
CMLA Key Store Problem -> Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?)
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
APE Subsystem Not Found
Storing NPC...
Storing CCC...
Storing HWC...
CMT VARIANT Not Found
Storing PARTNERC...
Restarting MCU...
RPL Saved OK
MCU Date 25-11-11
IMEI 12345610654321?
IMEI Spare 1A32541660452301
IMEI SV 1332541660452331F3000000
PSN CMJ722875
Basic Product Code 0596826
PSD 0000000000000000
LPSN 0
RETU 35
TAHVO 00
AHNE 11
HW 7300
RFIC |Alli_4.3.4
DSP 79_SR1_11w42.5
Failed to read info -> Failed to read SP info
Erasing Security...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT NPC Erased
Restarting MCU...
Writing Simlock...
Security block OK and saved to "RM-596_12345610654321_01082012_80822 PM.SecurityBlock.PM"
15 Digits NCK Found
Write RPL Finished!
MCU Date 25-11-11
PSN CMJ722875
LPSN 0
APE SW 111.030.0609
APE Variant 111.030.0609111.030.0609.03.01111.030.0609.02.01
APE HW 256
APE ADSP 256
APE BT HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 2128.
RETU 35
TAHVO 00
AHNE 11
HW 7300
RFIC |Alli_4.3.4
DSP 79_SR1_11w42.5
Erasing Security...
Storing PSN...
Storing HWID...
Hashing...
Storing Simlock...
Reading Keys...
Storing WMDRM PD...
Security block OK and saved to "RM-596_12345610654321_01082012_85604 PM.SecurityBlock.PM"
"17100110EDA40344E01184A3A2D11BAEA95EF7D4.C00079C9 " Exists, That is good...
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Storing NPC...
Storing CCC...
Storing HWC...
Storing PARTNERC...
Restarting MCU...
RPL Saved OK
MCU Date 25-11-11
PSN CMJ722875
LPSN 0
RETU 35
TAHVO 00
AHNE 11
HW 7300
RFIC |Alli_4.3.4
DSP 79_SR1_11w42.5
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
CMT PARTNERC Erased
CMT PARTNERC Written
Restarting MCU...
Write RPL Finished!
MCU Date 25-11-11
PSN CMJ722875
Product Code 0599255
LPSN 0
WLAN MAC 2CD2E7331211
APE SW 111.030.0609
APE HW 256
APE ADSP 256
RETU 35
TAHVO 00
AHNE 11
HW 7300
RFIC |Alli_4.3.4
DSP 79_SR1_11w42.5
Write PM Finished, Record written OK: 4, Record written NOT OK: 0
MCU Date 25-11-11
PSN CMJ722875
LPSN 0
APE SW 111.030.0609
APE HW 256
APE ADSP 256
APE BT HCI Version 12 (rev. 64). LMP Version 36 (rev. 64). Manufacturer 4104.
RETU 35
TAHVO 00
AHNE 11
HW 7300
RFIC |Alli_4.3.4
DSP 79_SR1_11w42.5
here is the log i tried writing full pm, tried writing only pm 120 and even tried writing rpl converted from pm.
Old 08-01-2012, 20:37   #4 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
write in the mobile the attached pm then sx4 auth and suggested PM
Please, report
Alex
Help solve an argument !! zeaster Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 11-10-2001 12:11
how do you solve no signal - 5110? philipal Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 09-29-2001 03:27
SOLVED THE FREEZE PROBLEM IN 8850!!!!! Please post below your observations.. jsp_m Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-14-2001 19:52
SimLock Level 4 counter HitMan Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 11-11-1999 23:17
N6150 simlock open??? Tommy Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 05-21-1999 09:31
Page generated in 0.50149 seconds with 12 queries
