Member: 234244
Sonork: 100.1583737 Thanks Meter: 5 | N81-8GB RM179 After Full Flash Cant On!!! - SOLVED This Phone Befor Flash was can on ,i just Up date version .after full flash cant on~~~ Quote:
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7828
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v1.05, (Jun 22 2009 12:23:29, gcc-4.2.2, RTOS v5.2.0), Type: Signed Production Application, Flags: CONST-TX2-PIN ; VISTA-SUPPORT ; BB5-NCK-CALC
Box Serial Number: C00007DE
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27
Initializing security card...
Card Serial Number: D200047F
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 4.95v PASSED
MCU Voltage 3.28v PASSED
Core Voltage 1.77v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 4.80v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Internal Box VPP Enabled
VPP Voltage 4.75v PASSED
Box VPP disabled
VPP Voltage 0.00v PASSED
External Box VPP Enabled
VPP Voltage 0.09v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Initializing FBUS...
All initialized - Ready to work
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\...
Found 156 products, Filtering BB5 Products - wait...
60 Products left after filtering. Ready.
Retrieving Variants for Product RM-179 - wait...
36 Variants Retrieved
Processing pre flash tasks...
Read RPL operation not possible for USB bus
Backing up simlock...
[BB5 NMWCD]: Found 0 active devices
[BB5 NMWCD]: Not Found!
Simlock backup problem -> Phone not detected
Backup simlock thread finished, continuing...
Pre flash tasks finished, continuing...
Selecting USB Flashing Method...
[BB5 ADL Server]: Found 0 active devices
[BB5 ADL Server]: Not Found!
Proceeding with Dead USB Mode
Press power-on shortly to run USB Boot ROM
[BB5 BootRom]: Found 1 active devices
[Nokia USB Flashing Generic]: Opening Connection
[Nokia USB Flashing Generic]: Port opened OK!
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 0FB00008706700589385C3C52A181D543F69552E
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9A28E119033B91D14D22838C86D0D53C
CMT_ROM_ID: A8C1D6713E691FF8
DeadUSB.raw, Type: 2nd Boot Loader, Rev: , Algo: BB5
Sending RAW Loader...
DeadUSB.alg, Type: Algorithm, Rev: , Algo: XSR 1.5
Sending CMT RAW Algorithm...
Waiting for ADL Server Startup...
[BB5 ADL Server]: Found 1 active devices
[Nokia BB5 ADL Loader USB Generic]: Opening Connection
[Nokia BB5 ADL Loader USB Generic]: Port opened OK!
ADL Server Startup Confirmed OK!
Processing RM179_21.0.010_prd.C00 (CMT)...
RM179_21.0.010_prd.C00, Type: Flash Image, Algo: BB5, XSR 1.5
Partitioning...
Partitioning OK
Started flash erase
EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND
EraseArea[0,CMT]: 0x00083400-0x0087FFFF, ONENAND
EraseArea[0,CMT]: 0x00B80000-0x05F7FFFF, ONENAND
Erase Partition (CMT)
Erase taken 1.343s
Writing all blocks...
Writing CMT ADA Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT PASUBTOC Certificate...
WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS
Writing CMT PAPUBKEYS Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS*CORE Certificate...
Writing CMT SOS+ROFS Certificate...
Programming Status OK!
All blocks written OK! Time taken 90.469s
Processing RM179_21.0.010_prd_1401.V14 (CMT)...
RM179_21.0.010_prd_1401.V14, Type: Flash Image, Algo: BB5, XSR 1.5
Started flash erase
EraseArea[0,CMT]: 0x03730000-0x05F7FFFF, ONENAND
Erase taken 0.594s
Writing CMT SOS+ROFX Certificate...
All blocks written OK! Time taken 67.844s
Processing RM179_21.0.010_002_erase_uda.fpsx (CMT)...
Processing RM179_erase_E.fpsx (CMT)...
RM179_erase_E.fpsx, Type: Flash Image, Algo: BB5, XSR 1.5
All blocks written OK! Time taken 16.328s
Restarting CMT...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Factory defaults OK
Reading info...
Failed to read info -> Phone not detected
Read info thread finished, continuing...
Post flash tasks finished! Flashing successfully finished! | |
