Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 07-17-2009, 15:26   #1 (permalink)
Member: 44485
N81 :imei 12345 after unlock , I can't write cert
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: E70C21157D5AB5AF61AAD376910751FB06D6E9FD
APE Subsystem Not Found
Processing 0B70000DFDCB015853220EBE98BEF71A9B3A7599.Sx4Bypass .NPC.CMT.crt...
CMT NPC Erased
Failed to Write CMT NPC Certificate -> Failed to write CMT NPC certificate
can any one help , i do all knowen solution but no result
Old 07-17-2009, 15:33   #2 (permalink)
irfanamin2's Avatar
Member: 82423
Mate! If you have rpl backup then write it.
Old 07-17-2009, 17:26   #3 (permalink)
Crazy Poster
Member: 339490
How do we in this process even in the same problem with n96
If only the answer With Photo
Old 07-17-2009, 17:54   #4 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
if u have backup... just press on write rpl to phone select rpl backup or new rpl that's it
Old 07-17-2009, 22:59   #5 (permalink)
Member: 44485
write cert DONNNNNNNNNNNNNNNNNNE!!
finally, and tnx ***, phone is alive , probleme was cable !! cyclone box is really a big box !!
N81 Contact Service after unlock bogsboggie Cyclonebox 1 03-19-2010 03:56
N85 imei 12345...... after unlock gsmplaza990reel Cyclonebox 10 05-29-2009 05:14
simplle solution sample for imei 12345 after unlock with UB alfox Universalbox 2 04-08-2009 04:04
5 locks after unlock C902, how write backup? Sakura D-Unlock Suite 9 08-20-2008 10:48
Page generated in 0.24053 seconds with 11 queries
