Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 07-10-2012, 21:25   #1 (permalink)
Member: 1696040
Sonork: 131076.74716343
N85 nokia logo [Solved]
N85 nokia logo fails and always restart after flashing with cyclone. Any help to get it back?
Old 07-11-2012, 16:14   #2 (permalink)
Member: 1696040
Now I plug the cable pack and does not enter local mode, only vibrates. A help please.
Old 07-11-2012, 16:40   #3 (permalink)
Member: 709604
change the upper keypad board & try
Old 07-11-2012, 22:45   #4 (permalink)
Member: 1696040
And that has to do with the flash, I'm saying is that after flashing it is not in local mode. No team can help me?
Old 07-11-2012, 23:20   #5 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
If it doesn't go in local mode it means you downgraded it.
do read all certs then, with "only npc" ticked click on delete all certs.
If afterward the mobile gets the local mode report
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 07-12-2012, 02:00   #6 (permalink)
Member: 1696040
Ok thank you very much already logged in locally, I'll put the latest version and it's not nokia logo, it is flashing on the logo. I can do to recover?
Old 07-12-2012, 08:28   #7 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: ( Protected )
sometimes n85 hang when flex fault.........
Old 07-12-2012, 08:42   #8 (permalink)
Member: 1696040
It could be also because now imei 12345610654321? and how I can fix it?
Old 07-12-2012, 08:44   #9 (permalink)
Mr.3.'s Avatar
Member: 962029
BB5 / Security / Auto-Recovery IMEI and post result
Old 07-12-2012, 12:33   #10 (permalink)
Member: 1696040
The imei is already solved, but still the same, stays in the nokia logo and will not start.
Old 07-13-2012, 17:32   #11 (permalink)
Member: 1696040
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 4,99v PASSED
MCU Voltage 3,27v PASSED
Core Voltage 1,77v PASSED
VBAT Voltage 0,01v PASSED
VBAT Voltage 4,93v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
Internal Box VPP Enabled
VPP Voltage 4,92v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 99
Avaiable Physical Memory: 976.656MB
Avaiable Virtual Memory: 1.894GB
Avaiable Pagefile: 2.986GB
Initializing FBUS...
All initialized - Ready to work
MCU Version V ICPR72_09w18.6
MCU Date 15-10-09
Product RM-333 (Nokia N85)
Manufacturer (c) Nokia
IMEI 356376028615627
Mastercode 4277575634
IMEI Spare 3A65730682166502
IMEI SV 3365730682166512F0000000
CNT V 53.32.2009.45.xx PRD
PSN CXD089820
Product Code 0574167
Basic Product Code 0555813
PSD 0000000000000000
LPSN 0
WLAN MAC 00BD3A5320D2
APE SW 31.002
APE Variant 31.002
APE Test eno_version
APE HW 256
APE ADSP 256
RETU 16
TAHVO 22
AHNE 11
HW 1550
RFIC |Vapaus_5.1 | ???
DSP wmps.ICPR72_09w17_p1
Simlock Server SIMLOCK SERVER
Simlock Key 2140100000000000
Simlock Profile 0000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: 21401F
Simlock [2,1] State: OPENED Type: MCC-MNC Data: 21401F
Simlock NCK #pw+326478514288180+7#
Auto Selecting Flash Files on User Request...
Product Code: 0574167
This is Valid BB5 Product
No variant found with given Product Code, selecting first one
I can not boot, please help.
Old 07-14-2012, 10:16   #12 (permalink)
Member: 1696040
The phone and on but has imei 1234560654321?, But if you repair the imei I will not start, as I can solve this?
Old 07-18-2012, 12:06   #13 (permalink)
Member: 1696040
Started IMEI Recovery...
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103
CMT_EM_ASIC_ID: 00000296
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 17B000137E8200520F62F35BB9A0C3EE24126015
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC: 4B9B7510
CMT_SECURE_ROM_CRC: 3E691FF8
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.12.8.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND
Requested Algorithm: XSR 1.5 (CMT)
FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported
RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.12.8.0, Algo: XSR 1.5
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: B5385A493D2188678E1FD88DA506480F874E2949
APE Subsystem Not Found
Flashbus Write baud set to 5.0Mbits
Looking NPC for 17B000137E8200520F62F35BB9A0C3EE24126015...
Found 17B000137E8200520F62F35BB9A0C3EE24126015.Downgrade Repair.NPC.CMT.crt
Backup current NPC...
Written to "17B000137E8200520F62F35BB9A0C3EE24126015_18072012 _125925.Recovery.NPC.CMT.crt"
Erasing NPC...
Writing NPC...
IMEI Recovery Finished
Old 07-18-2012, 12:18   #14 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Please,
pass me your teamviewer data: we have a look at this mobile together
Alex
Old 07-18-2012, 12:44   #15 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Solved via Teamviewer
Alex
The Following 2 Users Say Thank You to moulnisky For This Useful Post:
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 1.08538 seconds with 11 queries
