Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 07-08-2012, 18:47   #1 (permalink)
Member: 1766158
Sonork: 1618330
n95 rm 159 help [ Solved ]
had a n95 that vibrates only when turned on. did a full erase + full flash and write rpl back up then sx4 auth the repair dcc and after that still gets this 2 errors.
Passed ST_UEM_CBUS_IF_TEST
Passed ST_EAR_DATA_LOOP_TEST
Passed ST_SIM_CLK_LOOP_TEST
Passed ST_SIM_IO_CTRL_LOOP_TEST
Passed ST_SIM_LOCK_TEST
Passed ST_SECURITY_TEST
Passed ST_PWR_KEY_TEST
Passed ST_CURRENT_CONS_TEST
Passed ST_BACKUP_BATT_TEST
Failed ST_CMT_APE_WAKEUP_TEST
Passed ST_SLEEPCLK_FREQ_TEST
Passed ST_RADIO_TEST
Passed ST_HOOKINT_TEST
Passed ST_BTEMP_TEST
Passed ST_MBUS_RX_TX_LOOP_TEST
Passed ST_EXT_DEVICE_TEST
Passed ST_CDSP_RF_BB_IF_TEST
Passed ST_CDSP_RF_SUPPLY_TEST
Passed ST_CDSP_TX_IQ_TEST
Passed ST_CDSP_TXC_DATA_TEST
Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST
Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST
Failed ST_CDSP_TX_PLL_PHASE_LOCK_TEST
Passed ST_CDSP_WCDMA_TX_POWER_TEST
Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST
Passed ST_CDSP_GSM_TX_POWER_TEST
Passed ST_IR_LOOP_TEST
Passed ST_KEYBOARD_STUCK_TEST
Passed ST_LPRF_IF_TEST
Passed ST_CAMERA_IF_TEST
Passed ST_CAMERA_ACCELERATOR_TEST
Passed ST_SEC_CAMERA_IF_TEST
Passed ST_CAMERA_AUTOFOCUS_TEST
Passed ST_LPRF_AUDIO_LINES_TEST
Passed ST_MAIN_LCD_IF_TEST
Passed ST_BT_WAKEUP_TEST
Passed ST_WLAN_TEST
Passed ST_BT_WLAN_COEXISTENCE_TEST
Passed ST_ACCEL_IF_TEST
Passed ST_BT_SLEEP_CLK_TEST
Passed ST_APE_EM_ASIC_TEST
Passed ST_TEMP_SENSOR_IF_TEST
Passed ST_VIBRA_TEST
Selftests done, Tests total: 43, Tests passed: 41, Tests not passed: 2
can somebody help me on this? thank you
br,
Old 07-08-2012, 23:55   #2 (permalink)
gulshan-iqbal's Avatar
Member: 388033
Sonork: 100.1624864
by the way which loaders did you use to flash your phone after full erasing,"new Loaders" or "Old Loaders""" always must use "old" with N95 because that is APE Phone
Old 07-09-2012, 00:31   #3 (permalink)
Member: 1766158
Sonork: 1618330
oic i think i have used new loaders will try again thanks.
Old 07-09-2012, 01:12   #4 (permalink)
Member: 1766158
Sonork: 1618330
tried re flashing it bro using old method but still same error on logs. btw i turned it on and still no display.
br,
Old 07-09-2012, 02:55   #5 (permalink)
fortunemobile's Avatar
Member: 1728389
Sonork: 100.1617627
bro might hardware problem check hardware, or post a full flashing logs.
Old 07-09-2012, 03:07   #6 (permalink)
Member: 1766158
Sonork: 1618330
Booting CMT...
APE_SYSTEM_ASIC_ID: 24200705
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID: 3BEB2AB9439FD940A411BD09E26FFF60D1C9789A
APE_ROOT_KEY_HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101021103
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 1EE0010906C10058D45F76681625D5CD4282F6E2
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_SECURE_ROM_CRC: 3E691FF8
CMT Ready!
Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol)
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
If software STUCK HERE with box TX LED lit, that means:
USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0001003500006921, AMD, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x00010035 (AMD), Size: 16MBytes, VPP: 9V
RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89
omap2420_m1_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.41.0, Algo: BB5
FlashChip[0,APE]: 0x00EC004000220000, Samsung, NAND
Requested Algorithm: OMAP2420 UNISTORE-II-1.5.1 ALG (APE)
FlashChip[0,APE]: 0xFFFF000000000000, Unknown, MMC
FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported
Box VPP disabled
Internal APE Phone VPP Enabled
PAPUBKEYS Hash for APE: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89
Flashbus Write baud set to 5.0Mbits
Erasing flash chip...
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x00FFFFFF, NOR
Waiting 640s for erasure finish...
Erase taken 34.953s
Restarting MCU...
BB5 Full Erase Finished!
Processing pre flash tasks...
Read RPL operation not possible for Old USB Flashing Method
Pre flash tasks finished, continuing...
Processing RM-159_35.0.002_PR.C0R (CMT)...
Booting CMT...
CMT Ready!
Flashbus Write baud set to 51Kbits
FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR
Box VPP disabled
Warning: PAPUBKEYS Hash Missing!
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00080000-0x007B1641, NOR
EraseArea[0,CMT]: 0x00000000-0x0005FFFF, NOR
EraseArea[0,CMT]: 0x00880000-0x00FDFFFF, NOR
Waiting 320s for erasure finish...
Erase taken 3.140s
Writing all blocks...
Initializing TurboCache...
TurboCache Loaded!
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PASUBTOC Certificate...
WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Programming Status OK!
All blocks written OK! Time taken 25.313s
Flashing Speed: 23295.83 kBit/S
Restarting MCU...
Processing RM-159_35.0.002_PR.C0R (APE)...
Booting CMT...
CMT Ready!
Box VPP disabled
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,APE]: 0x00000200-0x0000AFFF, NAND
EraseArea[0,APE]: 0x0000B800-0x000AFFFF, NAND
EraseArea[0,APE]: 0x00000000-0x00000FFF, NAND
EraseArea[0,APE]: 0x0000D800-0x0000E9FF, NAND
EraseArea[0,APE]: 0x00080000-0x000BFFFF, NAND
EraseArea[0,APE]: 0x000E0000-0x0045FFFF, NAND
EraseArea[0,APE]: 0x004C0000-0x0073FFFF, NAND
EraseArea[0,APE]: 0x00A40000-0x0633FFFF, NAND
Erase taken 0.375s
TurboCache Loaded!
Writing APE X-LOADER Certificate...
Writing APE KEYS Certificate...
Writing APE PRIMAPP Certificate...
Writing APE SOS+XZIP Certificate...
Writing APE PASUBTOC Certificate...
Writing APE PAPUBKEYS Certificate...
Writing APE SOS+UPDAPP Certificate...
Writing APE SOS+CORE Certificate...
Writing APE SOS+ROFS Certificate...
All blocks written OK! Time taken 92.188s
Flashing Speed: 6396.57 kBit/S
Restarting MCU...
Processing RM-159_35.0.002_PR.v22 (CMT)...
Processing RM-159_35.0.002_PR.v22 (APE)...
Booting CMT...
CMT Ready!
ALG, BB5, XSR 1.5
Flashbus Write baud set to 650Kbits
Box VPP disabled
Box VPP disabled
Partitioning...
Partitioning OK
EraseArea[0,APE]: 0x04C40000-0x0633FFFF, NAND
Erase taken 0.78s
TurboCache Loaded!
Writing APE SOS+ROFX Certificate...
All blocks written OK! Time taken 16.0s
Flashing Speed: 5846.54 kBit/S
Restarting MCU...
Processing RM159_31.0.002_039_U04_uda.fpsx (CMT)...
Processing RM159_31.0.002_039_U04_uda.fpsx (APE)...
Booting CMT...
CMT Ready!
UNISTORE-II-1.5.1 ALG, BB5, XSR 1.5
Box VPP disabled
Box VPP disabled
EraseArea[0,APE]: 0x06340000-0x0FA3FFFF, NAND
Erase Certificate: SOS-USER (APE)
Erase taken 0.750s
TurboCache Loaded!
All blocks written OK! Time taken 84.31s
Flashing Speed: 4180.19 kBit/S
Restarting MCU...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Factory defaults OK
Reading info...
MCU Version V 06wk41v64.23
MCU Date 05-11-09
Product RM-159 (Nokia N95)
Manufacturer (c) Nokia
IMEI 12345610654321?
IMEI Spare 1A32541660452301
IMEI SV 1332541660452321F1000000
Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
PSN 0
PSD 0000000000000000
LPSN 0
APE SW 35.0.002
APE Variant 35.0.00222.01
APE Test rm159_eno_Cust2008wk14updv0
APE HW 1
APE ADSP 256
APE BT HCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.
RETU 15
TAHVO 22
AHNE 11
RFIC 17141715
Failed to read info -> Failed to read SP info
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
Skipping RPL decryption...
Parsing decrypted RPL...
Processing FBUS Part...
Writing Product Code...
Writing PSN...
Writing HWID...
Writing PSN...
Writing HWID...
Writing Superdongle key...
Superdongle Key ACCEPTED OK !
Writing CMLA key...
CMLA Key ACCEPTED OK !
Writing WMDRM PD Data...
WMDRM PD Data ACCEPTED OK !
Processing FLASHBUS Part...
Booting CMT...
CMT Ready!
Box VPP disabled
Box VPP disabled
CMT NPC Erased
CMT NPC Written
CMT HWC Erased
CMT HWC Written
CMT CCC Erased
CMT CCC Written
CMT VARIANT Erased
CMT VARIANT Written
APE NPC Erased
APE NPC Written
APE HWC Erased
APE HWC Written
APE CCC Erased
APE CCC Written
Restarting MCU...
Write RPL Finished!
SX4 Authorization / SD Repair Procedure Started....
"1EE0010906C10058D45F76681625D5CD4282F6E2.B0001DB7 " Exists, That is good...
MCU Date 05-11-09
IMEI 358064011834870
Mastercode 26725416
Reading Security Block...
AM.SecurityBlock.PM"
SX4 Status: Not authorized (76)
Started mutual authenthication with card...
Receiving Phone Seed 1...
Phone Seed 1 Received
Sending calculated Data 1, and expecting Seed 2...
Calculated Data 1 accepted, Phone Seed 2 Received
Sending calculated Data 2
Calculated Data 2 sent, Checking Authorization Status again
Authorization successfully finished!
Looking for Virgin PM In Database...
Found, writing...
[1,0] Written, Length: 114 bytes, Status: OK
[1,2] Written, Length: 98 bytes, Status: OK
[1,4] Written, Length: 110 bytes, Status: OK
[1,6] Written, Length: 98 bytes, Status: OK
[1,8] Written, Length: 110 bytes, Status: OK
[1,13] Written, Length: 98 bytes, Status: OK
[1,16] Written, Length: 98 bytes, Status: OK
[1,18] Written, Length: 98 bytes, Status: OK
[1,20] Written, Length: 98 bytes, Status: OK
[1,22] Written, Length: 16 bytes, Status: OK
[1,23] Written, Length: 4 bytes, Status: OK
[1,24] Written, Length: 84 bytes, Status: OK
[1,25] Written, Length: 4 bytes, Status: OK
[1,26] Written, Length: 110 bytes, Status: OK
[1,28] Written, Length: 98 bytes, Status: OK
[1,29] Written, Length: 10 bytes, Status: OK
[1,31] Written, Length: 98 bytes, Status: OK
[1,33] Written, Length: 36 bytes, Status: OK
[1,34] Written, Length: 80 bytes, Status: OK
[1,44] Written, Length: 182 bytes, Status: OK
[309,0] Written, Length: 4 bytes, Status: OK
[309,1] Written, Length: 2 bytes, Status: OK
[309,2] Written, Length: 12 bytes, Status: OK
[309,4] Written, Length: 12 bytes, Status: OK
[309,5] Written, Length: 12 bytes, Status: OK
[309,7] Written, Length: 12 bytes, Status: OK
[309,8] Written, Length: 12 bytes, Status: OK
[309,17] Written, Length: 12 bytes, Status: OK
[309,22] Written, Length: 12 bytes, Status: OK
Write PM Finished, Record written OK: 29, Record written NOT OK: 0
Analyzing Dynamic Camera Configuration...
--> Primary Camera Not Exists
--> Secondary Camera Not Exists
Dynamic Camera Configuration Analyze/Repair Finished!
Selftests to proceed: 43
Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST
Sending User Abort Signal...
Old 07-09-2012, 03:08   #7 (permalink)
Member: 1766158
Sonork: 1618330
bro full logs cant redo a reflash now im trying it with other box
Old 07-09-2012, 09:17   #8 (permalink)
Member: 1766158
Sonork: 1618330
BB5 Unlock Started...
MCU Version V 06wk41v50.2
MCU Date 28-01-08
Mastercode 26725416
Warning: Failed to read SP Info, Assuming defaults
Simlock Server SIMLOCK SERVER
Simlock Key 0000000000000000
Simlock Profile
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK and saved to "RM-159_358064011834870_792012_41341 PM.SecurityBlock.PM"
Determining PA Simlock...
Booting CMT...
CMT_BOOT_ROM_CRC: A8C1D671
CMT Ready!
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.12.8.0, Algo: BB5
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0x00012C7E00006921, AMD, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip 0x00012C7E (AMD), Size: 16MBytes, VPP: 9V
RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.12.8.0, Algo: XSR 1.5
TurboCache Loaded!
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
APE Boot skipped on user request
Restarting MCU...
Determined PA Simlock: PA_SL
Checking for Rootkey Hash support with selected Unlock Method...
Selected Unlock Method: NCK Calculation (old method)
BB5 Unlock Failed -> Unsupported Rootkey Hash for selected Unlock Method, this is critical
MCU Date 28-01-08
Mastercode 26725416
Simlock Profile
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK and saved to "RM-159_358064011834870_792012_41408 PM.SecurityBlock.PM"
Selected Unlock Method: RPL Calculation
Asking box to calculate RPL...
Received RPL from Box OK!
Writing Simlock...
Simlock ACCEPTED OK !
MCU Date 28-01-08
Mastercode 26725416
Simlock Key 2440700000000000
Simlock Profile 8000000000000006
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Unlock finished! Time taken 4.407s
MCU Date 28-01-08
Mastercode 26725416
IMEI Spare 3A85600411388407
IMEI SV 3385600411388417F4000000
PPM 21.0.016j21.0.01613.01k rm159_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
PSN MAJ302105
Product Code 0546553
LPSN 0
WLAN MAC 0021FC383489
APE SW 21.0.016
APE Variant 21.0.01613.01
APE HW 1
APE ADSP 256
RETU 15
TAHVO 22
AHNE 11
HW 6035i21.0.016j21.0.01613.01k rm159_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
PCI i21.0.016j21.0.01613.01k rm159_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
UEM 21.0.016j21.0.01613.01k rm159_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
UPP 21.0.016j21.0.01613.01k rm159_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
RFIC 17141715
DSP ICPR62_08w02i21.0.016j21.0.01613.01k rm159_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
LCD 21.0.016j21.0.01613.01k rm159_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
BT 21.0.016j21.0.01613.01k rm159_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
ADSP Sw 21.0.016j21.0.01613.01k rm159_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
ADSP DevID 21.0.016j21.0.01613.01k rm159_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
ADSP RevID 21.0.016j21.0.01613.01k rm159_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
AEM 21.0.016j21.0.01613.01k rm159_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
Flip MCUSW 21.0.016j21.0.01613.01k rm159_eno_Cust2008wk14updv0qLGHCI Version 3 (rev. 1740). LMP Version 3 (rev. 1740). Manufacturer 10.n1o256
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Auto Selecting Flash Files on User Request...
Product Code: 0546553
This is Valid BB5 Product
Variant found for readen Product Data
failed sp info done thanks to moulnisky's post.
quoted from moulnisky's post
1. Go to UnlockData\PA_SL2_RPLCALC
2. Rename New_RAPIDOv11_2nd.fg to New_RAPIDOv11.2nd.fgx
3. Unlock your phone
4. Rename fgx back to fg
br,
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 11-29-2010 18:04
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 06-25-1999 08:21
Page generated in 1.44144 seconds with 11 queries
