N95 vibrate then cutoff after flash [SOLVED - Thanks Crazy Ratata] First time flash for nme using CYLBOX Before flashing phone was starting to Nokia on first screen, then starting over After following the flashing procedure, phone attempting to startby vibrating then cutting off I used the correct cables sequence and the following image files RM421_20.2.005_003_xxx_U07_uda.fpsx RM-421_20.2.005_PR.C0R V2RM-421_20.2.005_PR.vA6 Please help |
Flash it with the eno firmware and then flash it again BR Alex |
you have downgradet the unit... That's why it only vibrates then turn off... Newest version is V35 BR |
I don't understand what is meant by 'eno' or V35 software. Also, I forgot to mention that near the of the flashing process, i get the message that the software cannot detect the phone- to switch it on manually. I tried to do this but it does not turn on (I think?), but I click retry anyway and the process continues. At the end it says successful flash. Please help. |
man simple,,,eno files,,u can find on support area,,download it and flash with eno,,then reflash with latest fermware, post result plz ok, |
go to support area,,click on enofiles,,,and sellect eno files for rm-491,,,,,,to flash this eno,go to bb5 tab and sellect the eno files that u downloaded ,and instaled,,,then flash,,,must unthick,bb5 simlock,and bb5 rpl,,after flash eno,,,reflash with latest fermware |
I'll try it and let u know. Thanx much! |
In the USA support area the only files available for N95 RM-421 are the ones I used. I can't get the Phoenix software and hence cannot use the stuff from the German support site.... any suggestions... |
ok,go to this link and download the yr flash latest fermware,,and post result.. Blue-Nokia.com by Obnoxy |
Ok I saw the eno file in the German support area. Previously I had downloaded- Nokia_firmware_RM-320_EURO_20[1].0.016_v4.03 and RM-320_EURO_31.0.015_v6.11 but when I try to install them I get the messages- Nokia Firmware RM-320 EURO 4.0 must be installed first and Nokia Firmware RM-320 EURO 6.0 must be installed first respectfully. Then the install aborts. |
but yr phone fermware, RM-421 ook,,,leave this,,,download the latest fermware from,,,link , Blue-Nokia.com by Obnoxy |
The German support site dont have 'eno' files for RM-421. Do I still need to flash this before the software I am downloading from blue-nokia. |
no,,problem,,download the files,,and flash it ,,,,,then post result,,,, |
else you can use navifirm... But blue-nokia is an okay place to download firmwares... If you still experience problems, then just add me on MSN, and I will help you out using teamviewer BR |
