Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 03-28-2010, 03:25   #1 (permalink)
Member: 703800
Smile N95 vibrate then cutoff after flash [SOLVED - Thanks Crazy Ratata]
First time flash for nme using CYLBOX
Before flashing phone was starting to Nokia on first screen, then starting over
After following the flashing procedure, phone attempting to startby vibrating then cutting off
I used the correct cables sequence and the following image files
RM421_20.2.005_003_xxx_U07_uda.fpsx
RM-421_20.2.005_PR.C0R
V2RM-421_20.2.005_PR.vA6
Please help
Old 03-28-2010, 10:02   #2 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Flash it with the eno firmware and then flash it again
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 03-28-2010, 18:23   #3 (permalink)
Member: 146369
you have downgradet the unit... That's why it only vibrates then turn off... Newest version is V35
The Following User Says Thank You to Crazy_ratata For This Useful Post:
Old 03-28-2010, 19:26   #4 (permalink)
Member: 703800
I don't understand what is meant by 'eno' or V35 software.
Also, I forgot to mention that near the of the flashing process, i get the message that the software cannot detect the phone- to switch it on manually. I tried to do this but it does not turn on (I think?), but I click retry anyway and the process continues. At the end it says successful flash.
Please help.
Old 03-28-2010, 19:28   #5 (permalink)
Member: 904809
Sonork: 100.1615464
man simple,,,eno files,,u can find on support area,,download it and flash with eno,,then reflash with latest fermware,
post result plz ok,
The Following User Says Thank You to alkhaleejmobile For This Useful Post:
Old 03-28-2010, 19:33   #6 (permalink)
Member: 904809
Sonork: 100.1615464
go to support area,,click on enofiles,,,and sellect eno files for rm-491,,,,,,to flash this eno,go to bb5 tab and sellect the eno files that u downloaded ,and instaled,,,then flash,,,must unthick,bb5 simlock,and bb5 rpl,,after flash eno,,,reflash with latest fermware
Old 03-28-2010, 19:39   #7 (permalink)
Member: 703800
I'll try it and let u know. Thanx much!
Old 03-28-2010, 19:43   #8 (permalink)
Member: 703800
In the USA support area the only files available for N95 RM-421 are the ones I used. I can't get the Phoenix software and hence cannot use the stuff from the German support site.... any suggestions...
Old 03-28-2010, 19:57   #9 (permalink)
Member: 904809
Sonork: 100.1615464
ok,go to this link and download the yr flash latest fermware,,and post result..
Blue-Nokia.com by Obnoxy
Old 03-28-2010, 20:00   #10 (permalink)
Member: 703800
Ok I saw the eno file in the German support area.
Previously I had downloaded- Nokia_firmware_RM-320_EURO_20[1].0.016_v4.03 and RM-320_EURO_31.0.015_v6.11 but when I try to install them I get the messages- Nokia Firmware RM-320 EURO 4.0 must be installed first and Nokia Firmware RM-320 EURO 6.0 must be installed first respectfully. Then the install aborts.
Old 03-28-2010, 20:03   #11 (permalink)
Member: 904809
Sonork: 100.1615464
but yr phone fermware, RM-421
ook,,,leave this,,,download the latest fermware from,,,link ,
Old 03-28-2010, 20:12   #12 (permalink)
Member: 703800
Ok I will. And I will post he result. Thanks.
Old 03-28-2010, 20:29   #13 (permalink)
Member: 703800
The German support site dont have 'eno' files for RM-421. Do I still need to flash this before the software I am downloading from blue-nokia.
Old 03-28-2010, 20:32   #14 (permalink)
Member: 904809
Sonork: 100.1615464
no,,problem,,download the files,,and flash it ,,,,,then post result,,,,
Old 03-28-2010, 22:27   #15 (permalink)
Member: 146369
else you can use navifirm... But blue-nokia is an okay place to download firmwares...
If you still experience problems, then just add me on MSN, and I will help you out using teamviewer
nokia 2600c No power on after unlock [ Solved, thanks alkhaleejmobile ] defcon2 Cyclonebox 2 03-13-2010 10:45
need help 3110c phone restricted after flashing [SOLVED - Thanks Everybody] kevin10 Cyclonebox 6 02-22-2010 07:27
LG cu515 white screan after flash,....help. thanks urecel VygisToolbox 3 08-07-2009 00:10
Samsung distorted screen then reboots after flash vistar86 Trident/AGERE Platform 1 09-13-2008 15:31
Page generated in 0.34358 seconds with 11 queries
