Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 11-30-2010, 10:25   #1 (permalink)
RAVI_SINGH's Avatar
Member: 1178981
Sonork: 100.1596342
Arrow N96 Phone Startup Failed Solution
Started Phone Security Analysis...
MCU Version V ICPR72_09w13.2
MCU Date 19-05-09
Product  RM-247
Manufacturer (c) Nokia
IMEI  359320022035199
Mastercode 73745020
Reading Security Block...
Security block OK and saved to "RM-247_359320022035199_11302010_31243 PM.SecurityBlock.PM"
Step 1 : Testing SIMLOCK
SIMLOCK SEFLTEST PASSED OK!
Step 2 : Testing SECURITY
-- SECURITY PROBLEM --
Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED!
To repair it, simply slick "SX4 Authorization / SD Repair" button.
After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically)
Additionaly, Checking HWC/CCC Certs...
Booting CMT...
APE_SYSTEM_ASIC_ID: 008815D3
APE_ASIC_MODE_ID: 00
APE_PUBLIC_ID:  51981138C1481E53DA18EB199C28A1FB9F381929
APE_ROOT_KEY_HASH: 0BBC4203E2D3B82504C75CB65E906A35
APE_BOOT_ROM_CRC: 137A9A3B
APE_SECURE_ROM_CRC: 33259D2C
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103
CMT_EM_ASIC_ID:  00000295
CMT_EM_ASIC_ID:  00000B22
CMT_PUBLIC_ID:  128001126172005296ECA5659385A3A65AC41622
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC: 4B9B7510
CMT_SECURE_ROM_CRC: 3E691FF8
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.16.2, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0020880400006B21, ST, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip 0x00208804 (ST), Size: 8MBytes, VPP: 9V
RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.10.22.0, Algo: XSR 1.5
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
STn8815_2nd.fg, Type: 2nd Boot Loader, Rev: 512.10.22.0, Algo: BB5
Adding FUR Client (APE, State: Start)...
APE FUR Ready!
FlashChip[0,APE]: 0x0000000000000000, Unknown, RAM
FlashChip[0,APE]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,APE]: 0x002000B100000000, ST, ONENAND
FlashChip 0x002000B1 (ST), Size: 8MBytes, VPP: 21V
STn8815_STNFMS_alg.fg, Type: Algorithm, Rev: 512.10.22.0, Algo: N8815 ALG STNFMS
Writing APE KEYS Certificate...
Writing APE PASUBTOC Certificate...
Writing APE ALG Certificate...
APE Algorithm Ready!
Adding FUR Client (APE, State: Ready)...
APE FUR Ready!
Box VPP disabled
Internal APE Phone VPP Enabled
PAPUBKEYS Hash for APE: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
Flashbus Write baud set to 5.0Mbits
HWC Looks OK!
CCC Looks OK!
Restarting MCU...
Step 3 : Analyzing Security Block
"128001126172005296ECA5659385A3A65AC41622.C0000B78" Exists, That is good...
Checking SUPERDONGLE...
Failed to decode Security Section, Box Reported: Security Section Checksum Error (decryption fails?)
Checking SIMLOCK...
Checking MCU&DSP TIMESTAMPS...
Checking CMLA KEYS...
Checking ECC KEYS...
ECC KEYS FOUND AND CHECKSUM OK! PASSED!
Checking DIV KEYS...
DIV KEYS FOUND AND CHECKSUM OK! PASSED!
Analyze finished!
SX4 Authorization / SD Repair Procedure Started....
MCU Date 19-05-09
Product  RM-247
Mastercode 73745020
Security block OK and saved to "RM-247_359320022035199_11302010_31305 PM.SecurityBlock.PM"
Superdongle Key is probably CORRUPTED, Writing custom keys...
Received SD Keys from box, writing to phone...
Superdongle Key ACCEPTED OK !
SX4 Status: Not authorized (74)
Started mutual authenthication with card...
Receiving Phone Seed 1...
Phone Seed 1 Received
Sending calculated Data 1, and expecting Seed 2...
Calculated Data 1 accepted, Phone Seed 2 Received
Sending calculated Data 2
Calculated Data 2 sent, Checking Authorization Status again
Authorization successfully finished!
Looking for Virgin PM In Database...
Found, writing...
[1,0] Written, Length: 114 bytes, Status: OK
[1,2] Written, Length: 98 bytes, Status: OK
[1,4] Written, Length: 110 bytes, Status: OK
[1,6] Written, Length: 98 bytes, Status: OK
[1,8] Written, Length: 110 bytes, Status: OK
[1,13] Written, Length: 98 bytes, Status: OK
[1,16] Written, Length: 98 bytes, Status: OK
[1,18] Written, Length: 98 bytes, Status: OK
[1,20] Written, Length: 98 bytes, Status: OK
[1,22] Written, Length: 16 bytes, Status: OK
[1,23] Written, Length: 4 bytes, Status: OK
[1,24] Written, Length: 84 bytes, Status: OK
[1,25] Written, Length: 4 bytes, Status: OK
[1,26] Written, Length: 110 bytes, Status: OK
[1,28] Written, Length: 98 bytes, Status: OK
[1,29] Written, Length: 10 bytes, Status: OK
[1,31] Written, Length: 98 bytes, Status: OK
[1,33] Written, Length: 36 bytes, Status: OK
[1,34] Written, Length: 80 bytes, Status: OK
[1,35] Written, Length: 16 bytes, Status: OK
[1,37] Written, Length: 4 bytes, Status: OK
[1,39] Written, Length: 36 bytes, Status: OK
[1,44] Written, Length: 182 bytes, Status: OK
[1,45] Written, Length: 182 bytes, Status: OK
[309,0] Written, Length: 4 bytes, Status: OK
[309,1] Written, Length: 2 bytes, Status: OK
[309,2] Written, Length: 12 bytes, Status: OK
[309,4] Written, Length: 12 bytes, Status: OK
[309,5] Written, Length: 12 bytes, Status: OK
[309,7] Written, Length: 12 bytes, Status: OK
[309,8] Written, Length: 12 bytes, Status: OK
[309,17] Written, Length: 12 bytes, Status: OK
[309,22] Written, Length: 12 bytes, Status: OK
Write PM Finished, Record written OK: 33, Record written NOT OK: 0
BB5 Unlock Started...
MCU Date 19-05-09
Product  RM-247
Mastercode 73745020
Simlock Server SIMLOCK SERVER
Simlock Key 2440700000000000
Simlock Profile 8000000000000006
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Security block OK and saved to "RM-247_359320022035199_11302010_31329 PM.SecurityBlock.PM"
Checking for Rootkey Hash support with selected Unlock Method...
Selected Unlock Method: RPL Calculation
Asking box to calculate RPL...
Received RPL from Box OK!
Writing Simlock...
Simlock ACCEPTED OK !
MCU Date 19-05-09
Product  RM-247
Mastercode 73745020
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Unlock finished! Time taken 15.406s
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 10 03-11-2013 15:27
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-16-2010 04:52
Page generated in 0.21941 seconds with 11 queries
