Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 11-03-2011, 22:57   #1 (permalink)
Member: 370221
Sonork: 1592059
Thanks Meter: 97
Need help for conect Blackberry
I donīt know how.
I conect the BB to the computer the computer recognize the phone, the BB desktop manager recognize to but the cyclone box donīt recognize the phone.
Any sugestion?
Old 11-03-2011, 23:18   #2 (permalink)
Member: 370221
Sonork: 1592059
Thanks Meter: 97
Originally Posted by crstelefonia View Post
I donīt know how.
Any sugestion?
Now I can conect but only get this log
Waiting for new Blackberry USB Device (timeout 30 seconds)...
New device attached, checking if it's Blackberry...
Blackberry Found!
PIN: 242EBF40
and the soft stays freeze if I unplug the cable the soft saids than the BB has a password but the two BB donīt have any password
Old 11-03-2011, 23:52   #3 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,070
Clcik on read phone and afterward connect the phone to the usb cable
phone must be on, without password
if is prompted on the screen select "no" to mass memory mode
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 11-04-2011, 17:28   #4 (permalink)
Member: 370221
Sonork: 1592059
Thanks Meter: 97
Alex
Not work, I put manually the imei and the mep and then calculate. solve this way
Old 11-04-2011, 22:54   #5 (permalink)
Member: 67562
Sonork: none
Thanks Meter: 88
Bad thing is that other tool can read MEP and IMEI from few Blackberrys and Cyclone BB can not.
I faced this problem today too with BB 8100.
Old 11-05-2011, 01:12   #6 (permalink)
moulnisky's Avatar
Member: 947561
Guys I unlock blackberry almost every day and never had problems.
be sure you have the bb drivers installed and they are necessary, the mobile must be without password and not in mass memory mode.
If you follow these guidelines the tool works 100%
Alex
Old 11-05-2011, 02:30   #7 (permalink)
boucettay's Avatar
Member: 148814
Sonork: 100.1576882
Thanks Meter: 5,008
cyclone work well with BB..unlocked load of BB too
The uniq pb, is when phone readed, Mep is not selected automatically, so, have to select from drop list...But reading phone, it is readed fast an well. and codes r always 100%
if you get pb, check your phone, your pv and install desktop manager, so you r sure you have drivers well installed
WBr
Old 11-13-2011, 11:02   #8 (permalink)
Member: 548443
Thanks Meter: 70
Arrow
WBr
Hi,
Thanks for the info. I am about to work on some 2 Blackberrys and I would like to quote:
"install desktop manager, so you r sure you have drivers well installed"!
How and from where do I install the desktop manager and drivers?
Thanks for a quick response.
Best regards.
Old 11-13-2011, 11:45   #9 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: ( Protected )
Thanks Meter: 3,797
No need install drivers manually it will install automatically when you plug the phone to pc if installed blackberry desktop manager.. As alex said password must be disable and mass storage mode must be off ..
The Following User Says Thank You to Mr.3. For This Useful Post:
Old 11-14-2011, 17:21   #10 (permalink)
Member: 548443
Thanks Meter: 70
Arrow
Hi Mr T,
Thanks again for the quick response. I have managed to read and read accurately unlock codes(MEPS 2) for 2 Blackberrys and both have accepted the codes.
With the third one, there is this problem of PASSWORD being asked by the handset.Even though this password request is present, CYCLONE BLACKBERRY TOOL has managed to read info of the handset including the MEP 2(Network Code). The problem is how to get rid of the password so that I can input the network code.
Has anyone got any idea?
Best Regards.
P/S:
Please find below is the LOG:
Blackberry Found!
PIN: 2339CBA4
"RIM CalTask" Channel open failed, Retrying...
PIN: 2339CBA4
"RIM CalTask" Channel open failed, Trying "Caltask Config" ...
PIN: 2339CBA4
Opened Channel "Caltask Config", Proceeding...
IMEI: fffffffffffffffffffff
HWV-13901-006-8
SVP-17969-001_1
SVP-17970-001_1
SVP-28137-006_1A
ASY-12591-067
MEP-04103-001
VSM-19883-004
CFG-10696-061
SFI-17798-113
APP-33341-001
PRD-26139-007
Calculating Codes using Fetched Data...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Service Tag: Eeeeeeeeeeeeeeeeeeeee
MEP-2: xxxxxxxxxxxxxx
Calculations Left: xx
All Done!
Old 11-30-2011, 23:41   #11 (permalink)
Member: 1358416
Sonork: 4019
Thanks Meter: 15
you must tsek first on my computer then go properties click and search modem unit
Old 12-01-2011, 00:28   #12 (permalink)
Member: 96457
Thanks Meter: 8
same me,
you need update bb software-firmware. with bb destop manager and later unplug with cyclone.
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.37006 seconds with 8 queries
