Need urgently help - 3600s show contact service after flash Hi bro, i've a 3600slide which shows contact service after unsuccessfull flash. In the middle of the flash procedure tthe software says no data card found and the flash was stopped. After this i've flashed again the phone successfully but now it says contact service. I've testet to write the rplīmade from cyclone befor flashing, but no success. The imei is 1234560..... Please nedd help what to do!!! Thanks in advance Jomafi:D |
No solution for my problem. Phone shows contact service. Another idea? B.R. Jomafi:D |
You flashing your phone with same or major version ? |
What do you mean? The version flashed before fault flash? I've flashed with newer version. B.R. Jomafi:D |
hi try to flash ur phone with the same vesion was in or the laste plz make result |
i think yur solution is only to calculate the rpl then after calculate write in cyclone BR RyanMuslim |
Hi, Downgrad this phone is not possible. Ends with an IMEI Error and Phoen is dead. Revive with newest version all seems ok, but IMEI shows 12345610654321 and Contact service. Write back the certificate will end with an error on one Block. Write back RPL made automatically by cyclone doesn't solve my problem:( I do not hope that calculate an RPL-File will be the only solution, becaus i've the rpl File written by cyclone. Anyone another idea? Greats Jomafi:D |
good just write for certivicate..... to write rpl, try using jaf. check my reported here http://forum.gsmhosting.com/vbb/showthread.php?t=825448 |
write rpl with mt-box |
No need to write RPL cert. etc.. you had flash PA_SL2 phone with PA_SL3 Fimrware and the result is corrupted SIMLOCK and IMEI, there is two new firmware in 3600s V56.26 and v57.23 . If you upgrade it with latest version make downgrade it same version, or if you downgrade phone before, so flash with same grater version . Regards. |
this is somthing new for me...........thanks ANGEL |
