Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 09-11-2012, 14:23   #1 (permalink)
mfeliu07's Avatar
Member: 517318
Thanks Meter: 79
Nokia 1208 dead after flash
Hello
Nokia 1208 dead after flash, I flashed with different versions and not with any, although the process ends and no flashing turn on,
Any solution?
Thanks in advance
Processing pre-flash tasks...
Pre-flash tasks finished
Booting UPP...
UPP ID: 2292 [HW_UNKNOWN]
rh105_05.710, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Flashbus Write baud set to 100Kbits
u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4
Box VPP disabled
Internal Phone VPP Selected
PLL Factor: 3
FlashChip[0]: 0x00EC2606 @ 0x01000000, Samsung, SectorSize: 64kB, Ext: 00000222
Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 51Kbits
u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2606 (32Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM
Nominal VPP Voltage: 9V, Detected: 0,04V
MSID-Crypted: 84F54FD86D7CF8BBD53884BF60
Using MSID-FAID Cache, Not wasting card
FAID-Crypted: C4DC45319C96E579D1D4B2F3
Flashbus Write baud set to 6.50Mbits
5 Region(s) to erase
Erasing NOR Region [0x01000000-0x0100FFFF]
Erasing NOR Region [0x01010000-0x013AFFFF]
Erasing NOR Region [0x013B0000-0x013EFFFF]
Erasing NOR Region [0x017C0000-0x017EFFFF]
Erasing NOR Region [0x01FC0000-0x01FEFFFF]
Erase taken 21.844s
Writing 147 blocks...
All blocks written OK! Time taken 13.875s
Terminating flash session
Box VPP disabled
Booting UPP...
rh1050_nai5.71ag, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
MSID-Crypted: 841303823427526204F01D1DB6
FAID-Crypted: A764A6B1CAE4465E8D1AF203
1 Region(s) to erase
Erasing NOR Region [0x01380000-0x013AFFFF]
Erase taken 1.47s
Writing 8 blocks...
All blocks written OK! Time taken 0.703s
Extracting Content Package...
CP Server: File Server fake reply for CUI phone.
CP Extract Failed -> CP Not Extracted, Code: 1
WARNING: Failed to extract CP
Box VPP disabled
Booting UPP...
rh105_05.71ag, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
Nominal VPP Voltage: 9V, Detected: 0,00V
2 Region(s) to erase
Erasing NOR Region [0x01240000-0x0124FFFF]
Erasing NOR Region [0x01250000-0x0137FFFF]
Erase taken 7.0s
Writing 74 blocks...
All blocks written OK! Time taken 7.31s
Box VPP disabled
Processing post-flash tasks...
Setting Factory Defaults...
Factory defaults OK
Post-flash tasks finished...
Flash successfully finished!
Selftests to proceed: 12
Passed ST_UEM_CBUS_IF_TEST
Passed ST_SLEEP_X_LOOP_TEST
Passed ST_EAR_DATA_LOOP_TEST
Passed ST_SIM_CLK_LOOP_TEST
Passed ST_SIM_IO_CTRL_LOOP_TEST
Passed ST_WARRANTY_TEST
Passed ST_SIM_LOCK_TEST
Passed ST_PPM_VALIDITY_TEST
Passed ST_LCD_TEST
Passed ST_FLASH_CHECKSUM_TEST
Failed ST_RF_CHIP_ID_TEST
Passed ST_KASUMI_TEST
Selftests done, Tests total: 12, Tests passed: 11, Tests not passed: 1
Old 09-11-2012, 14:25   #2 (permalink)
Momin_Telecom's Avatar
Member: 1478271
Sonork: 100.1608386
Thanks Meter: 1,706
flash with latest version 6.00 your problem solve 1000%
br
sarfraz husain
The Following User Says Thank You to Momin_Telecom For This Useful Post:
Old 09-11-2012, 14:32   #3 (permalink)
mfeliu07's Avatar
Member: 517318
Thanks Meter: 79
br
sarfraz husain
Unchanged, flashes completely and does not turn on
Old 09-11-2012, 14:34   #4 (permalink)
mfeliu07's Avatar
Member: 517318
Thanks Meter: 79
Flashing with version 6.00
Booting UPP...
rh105_06.000, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
Erase taken 21.844s
All blocks written OK! Time taken 13.828s
Box VPP disabled
Booting UPP...
rh1050_nai6.00ag, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
Erase taken 1.47s
Writing 8 blocks...
Box VPP disabled
Booting UPP...
rh105_06.00ag, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
MSID-Crypted: 8444E05787ED9D0645C7A21AB7
MSID-Plain: 3E4EBAE900211FAAA9000000
FAID-Crypted: 25EBCC8FA653BF3A85FFA0D6
Erase taken 6.984s
Box VPP disabled
Factory defaults OK
Old 02-13-2017, 15:31   #5 (permalink)
Member: 2477331
Sonork: 100.1676088
Thanks Meter: 25
Flashing with version 6.00 but phone nothing on please give solution ATF team i m waiting your responce!!!!
Page generated in 0.25362 seconds with 7 queries
