Nokia 1616 before flash was working fine i upgrade it but after flash is dead i have nokia 1616 before flash he was working fine i upgrade it but after flash dead here is log Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Found 3 products, Filtering DCT4 Products - wait... 1 Products left after filtering. Ready. Booting UPP... Failed to Check DCT4 Flashing Bus -> UPP Not Responding Processing pre-flash tasks... Pre-flash tasks finished Checking rh125_006.510... Flash file sorted Okay. 1 file(s) embedded into image. Booting X-Gold via ASC (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x002088C0, ST, Size: 8MBytes Processing "hw_f11_rh125_r06.510.fls"... Sending Certificate... Certificate Accepted Erasing 0x00800000-0x00A0FFFF... Flashing at 0x00800000... Flashed 2162688 bytes OK Erasing 0x00C60000-0x00EAFFFF... Flashing at 0x00C60000... Flashed 2174080 bytes OK Erasing 0x00FFC000-0x00FFFFFF... Flashing at 0x00FFC000... Flashed 64 bytes OK Box VPP disabled Checking rh1250_nai06.51ae... Flash file sorted Okay. 1 file(s) embedded into image. Booting X-Gold via ASC (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x002088C0, ST, Size: 8MBytes Processing "hw_f11_rh1250_nai06.51ae.fls"... Sending Certificate... Certificate Accepted Erasing 0x00EB0000-0x00F7FFFF... Flashing at 0x00EB0000... Flashed 329088 bytes OK Box VPP disabled Checking rh125_006.51ae... Flash file sorted Okay. 1 file(s) embedded into image. Booting X-Gold via ASC (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x002088C0, ST, Size: 8MBytes Processing "hw_f11_rh125_006.51ae.fls"... Sending Certificate... Certificate Accepted Erasing 0x00210000-0x0045FFFF... Flashing at 0x00210000... Flashed 1801152 bytes OK Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... |
plz all gsm master i need your help i m waiting your answer how to alive it |
you need to flash back the original version of your phone bro.................. |
6.51 is not latest firmware Quote:
DOWNLOAD |
ok i will try and post result |
