05-31-2011, 14:20 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Middle East
Member: 950386 Status: Offline Thanks Meter: 114 | Nokia 1616 supported for unlock by cyclone? Is this phone 1616 supported for unlock by cyclone? If not what is the solution for this old phone that came out over a Year ago? Kind Regards |
The Following User Says Thank You to LOCKED4EVER For This Useful Post: |
05-31-2011, 15:30 | #5 (permalink) | |
Member: 950386 Status: Offline Thanks Meter: 114 | Quote:
Also do you know why cyclone is failing to read the phone when i click check fbus button? Im using a 5 pin cable and they are on the correct pin outs but cyclone isn't picking it up? KR | |
05-31-2011, 16:08 | #6 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | If you get error doing it do these steps a1) unitick Extract PM and save RPL then click on read lbf data. if still error then a2) backup imie b2) restore imei c2) unplug and replug the fbus cable d2) go to point a1 BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
05-31-2011, 17:15 | #7 (permalink) | |
Hi, i untick PM and RPL box but where is read ibf data button in cyclone? KR | |
05-31-2011, 17:55 | #8 (permalink) |
Member: 950386 Status: Offline Thanks Meter: 114 | When i click on Read Log2cod File on cyclone i get this message.... [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x002088C0, ST, Size: 8MBytes Certificates Block not found in TOC, Skipping Backup Simlock Block not found in TOC, Skipping Backup Reading Plain PMM... 38 Records marked as Deleted (Plain PMM) Reading Protected PMM... 8 Records marked as Deleted (Protected PMM) Failed to Read X-Gold LOG2COD File -> Simlock Table not found in Protected PMM! |
05-31-2011, 18:09 | #9 (permalink) |
Member: 950386 Status: Offline Thanks Meter: 114 | Ok it seems as tho i can do it with another 1616 but i cant read log file from the other. Is reading a log file from a phone difficult with some firmware versions? |
05-31-2011, 18:29 | #10 (permalink) |
Member: 950386 Status: Offline Thanks Meter: 114 | Flashed it to 6.20 (the same as the other phone that recorded log and worked) but cyclone will not read log from this other 1616 even after flashing to 6.20. Solution? Also where is ibf data in cyclone? KR |
06-06-2011, 10:57 | #12 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Romania, The Bla Bla Country Age: 44
Member: 14279 Status: Offline Thanks Meter: 35 | hi. none of the suggestions above worked on this phone: back-up restore IMEI, upgrade/downgrade. initial firmware version was 4.65. i've upgraded to 6.20 than could not read LBF data. it seems that upgrading the firmware prior to reading lbf data can get us in troble. here is the attachment. |
The Following User Says Thank You to Alinus For This Useful Post: |
