Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Dec 2002
Member: 19271 Status: Offline Thanks: 40
| Nokia 201 can't read ASK Flashing & reading LBF ok, but can't read ASK ;-) " [Nokia USB Phonet]: Port opened OK! MCU Version V 11.21 MCU Date 16-01-12 Product RM-799 (Nokia RM-799) Manufacturer (c) Nokia IMEI 358260042119634 Mastercode 727211145 IMEI Spare 3A85620024116903 IMEI SV 3385620024116903F3000000 PPM V 11.21, 16-01-12, RM-799, (c) Nokia , C1 CNT Content: ctv GB v2, V 11.21, 16-01-12, RM-799, (c) Nokia PSN 03D754ABI Product Code 059N286 Module Code 0205022 Basic Product Code 059K0F8 PSD 0000000000000000 LPSN 0 HW 2200 RFIC Dummy RFIC version LCD TPO BT 19e2-47026 Failed to read info -> Failed to read SP info [Nokia USB Phonet]: Port opened OK! MCU Version V 11.21 MCU Date 16-01-12 Product RM-799 (Nokia RM-799) Manufacturer (c) Nokia IMEI 358260042119634 Mastercode 727211145 IMEI Spare 3A85620024116903 IMEI SV 3385620024116903F3000000 PPM V 11.21, 16-01-12, RM-799, (c) Nokia , C1 CNT Content: ctv GB v2, V 11.21, 16-01-12, RM-799, (c) Nokia PSN 03D754ABI Product Code 059N286 Module Code 0205022 Basic Product Code 059K0F8 PSD 0000000000000000 LPSN 0 HW 2200 RFIC Dummy RFIC version LCD TPO BT 19e2-47026 Failed to read info -> Failed to read SP info Reading SL3 LOG File... [Nokia USB Phonet]: Port opened OK! MCU Version V 11.21 MCU Date 16-01-12 Product RM-799 (Nokia RM-799) Manufacturer (c) Nokia IMEI 358260042119634 Mastercode 727211145 Warning: Failed to read SP Info, Assuming defaults XGold213 Detected Analyzing Profile Bits... Phone can be NCK unlocked using KEYPAD Phone can be NCK unlocked using FBUS 15 Digits NCK Found Booting X-Gold via USB... If PC Can't detect any new device, probably your phone is erased. Do following if needed: 1. Eject battery 2. Eject cable 3. Insert cable 4. Insert battery 5. Press power-on [Nokia USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Flashing Generic]: Port opened OK! X-Gold: Ready, MCU ID Block: 1FB300020303010100FF [PBL] : Ready [EBL] : Mode CC [EBL] : Quantum_Bootloader_2.5_M1S1 [EBL] : Ready Setting Baudrate to 6500000bps... Baudrate Accepted (6500000bps) Flash Chip 0x00898982, Intel, Size: 64MBytes Success! Booting CMT... [Nokia USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Flashing Generic]: Port opened OK! Failed to Boot CMT -> Failed to get First Boot Block Failed to Read ASK via Flash Bus -> Failed to Boot CMT " |
| | #4 (permalink) |
| Cyclone Box: Common>Read info: " [Nokia USB Phonet]: Port opened OK! MCU Version V 11.56 MCU Date 26-03-12 Product RM-799 (Nokia RM-799) Manufacturer (c) Nokia IMEI 358260042119634 Mastercode 727211145 IMEI Spare 3A85620024116903 IMEI SV 3385620024116903F4000000 PPM V 11.56, 26-03-12, RM-799, (c) Nokia , B1 CNT Content: b1_059K4C4, V 11.56, 26-03-12, RM-799, (c) Nokia PSN 03D754ABI Product Code 059N286 Module Code 0205022 Basic Product Code 059J2K2 PSD 0000000000000000 LPSN 0 HW 2200 RFIC Dummy RFIC version LCD TPO BT 19e2-47026 Failed to read info -> Failed to read SP info " BB5>Check flashing bus " Booting CMT... [Nokia USB Phonet]: Port opened OK! Switching to RAW Mode... [Nokia USB Flashing Generic]: Port opened OK! Failed to Boot CMT -> Failed to get First Boot Block Prepare phone failed with message -> Failed to Boot CMT " Other Box: "Booting Phone via USB... ================================================== ==== ================================================== ==== USB Phone BUSCheck Boot ================================================== ==== ================================================== ==== 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Infineon USB Buscheck Done Phone Restart Mode: TEST MODE Process Done... " |
| | #6 (permalink) |
| Super Moderator ![]() Join Date: Jan 2009 Location: England Age: 48
Member: 947561 Status: Offline Thanks: 2,688
| Anyway had a look at your threads all over the forum in different section about this mobile. You should give me, if you can, the real product code of the mobile (the one on the lable under the battery just to understand, so we should be able to help you about. Load of chances it doesn't need an rpl BR Alex |
| | #7 (permalink) |
| If the Product Code is 059N286 as stated in the logs is enaugh you write this PM in the mobile BR Alex |
| The Following User Says Thank You to moulnisky For This Useful Post: |
| | #8 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: Poland Age: 23
Member: 117496 Status: Offline Sonork: 100.83919 Thanks: 84
| Reading ASK file works only for TI or TI-compatilbe-interface based products. XGold213 don't containt something like "ASIC PUBLIC ID". I am not sure, maybe try reading via FBUS interface (not flashbus). If still not work - ask your RPL provider for VALID rpl FORMAT, so I can know what-to-dump. Maybe they use SCCI ID for identifying chips, but not sure. Example ASK file from any phone would help me very much. |
| The Following User Says Thank You to karwos For This Useful Post: |
| | #10 (permalink) | |
| Quote:
And don't I see clear info about FBUS - no pinout, no schematic diagram... Anyone have FBUS pinout or schematic for RM-799? Unfortunelly - file RM-799_7lines.rar (thx moulnisky!) don't help - still CS... Which PM fields are responsible for the basic product code and product code on this phone (as I know customer "plays" with this value)? Last edited by greg777; 06-11-2012 at 20:30. | |
| | #11 (permalink) |
| No FBUS for this phones as this is XGOLD2 based. Product code or Basic product code wouldn''t cause CS. Cause here is damaged Simlock area. Read PM120-120 and attach here so I can look closer for this. |
| | #13 (permalink) |
| Your PM and PM120 looks good. Product code is 059N286 and this is UNLOCKED variant. So probably someone written PM from other phone, killing simlcok RSA signature. Last option: what is product code under battery? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| New Nokia Software!!!!!!! | Jefferson | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 73 | 05-15-2013 13:07 |
| Need software upgrade for Nokia 5110 | ptkrf | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 26 | 09-25-2012 02:41 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
