Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 07-13-2011, 21:04   #1 (permalink)
Member: 683750
Thanks Meter: 2
NOKIA 2330c-2 FLASHING ERROR (HELP)
I HAVE A DEAD NOKIA 2330c-2 WHICH I TRIED TO FLASH. FLASHING STARTS NORMALLY TILL IT GOT TO A POINT WHERE IT STOPS. PLEASE BRO, WHAT SHOULD I DO? HERE IS THE FLASHING LOG:
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia/Blackberry Application v01.64, (Jun 30 2011 15:31:22, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: ******
HW Revision: B, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk23
Initializing security card...
Card Serial Number: ******
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage	5.03v	PASSED
MCU Voltage	3.30v	PASSED
Core Voltage	1.76v	PASSED
VBAT Voltage	0.01v	PASSED
VBAT Voltage	5.02v	PASSED
Box VPP disabled
VPP Voltage	0.02v	PASSED
Internal Box VPP Enabled
VPP Voltage	5.01v	PASSED
Box VPP disabled
VPP Voltage	0.04v	PASSED
External Box VPP Enabled
VPP Voltage	0.02v	FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
Initializing FBUS...
All initialized - Ready to work
Processing pre-flash tasks...
Pre-flash tasks finished
Booting UPP...
UPP ID: 3168 [HW_UNKNOWN]
rm512__09.85.mcusw, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Flashbus Write baud set to 100Kbits
u3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4
Box VPP disabled
Internal Phone VPP Selected
PLL Factor: 3
FlashChip[0]: 0x00EC2600 @ 0x01000000, Samsung, SectorSize: 128kB, Ext: 00009221
FlashChip[1]: 0x00EC2600 @ 0x02000000, Samsung, SectorSize: 128kB, Ext: 00009221
Signature: AD7EB61B23100340C605E40120A20000
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 51Kbits
u3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00EC2600 (256Mbits), Rev: 7.4.79.0, Algo: DCT4 ALGORITHM
Nominal VPP Voltage: 9V, Detected: 0.02V
MSID-Crypted: 84EA90FDAE36DDDAFB57802ECD
MSID-Plain: 2C40BAE900D5C0EBA8000000
FAID-Crypted: B088AE16094AE35A190BC2D6
Flashbus Write baud set to 6.50Mbits
2 Region(s) to erase
Erasing NOR Region [0x01000000-0x0101FFFF]
Erasing NOR Region [0x01020000-0x01CFFFFF]
Erase taken 51.766s
Writing 191 blocks...
All blocks written OK! Time taken 495.844s
Terminating flash session
Box VPP disabled
Booting UPP...
rm512__09.85.image_ej_uk_red, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM
Box VPP disabled
PLL Factor: 3
MSID-Crypted: 8481E3F8E73D23E00AC8C21F4B
MSID-Plain: D26EBAF100D5C0EBAA000610
FAID-Crypted: 2F4A0341CE2A2EFB3F1F3553
Erasing NOR Region [0x02180000-0x02E7FFFF]
Erasing NOR Region [0x02E80000-0x02FBFFFF]
Erase taken 60.625s
File Sector Size: 128kB, Flash Chip Sector Size: 128kB
CNT Convertion not needed
Writing 296 blocks...
CBUS Request Error -> CBUS Problem, Lost handle (Write Pipe)
Block Write Failed -> Block write failed (1), Offset 84228, Write Method 0x14
Failed to disable VPP -> No answer from CBUS
Processing Flash Image Failed -> Failed to disable box VPP
Failed to Flash -> Problem with processing PPM Image file
Old 07-13-2011, 23:02   #2 (permalink)
GSM boy's Avatar
Member: 1375690
Thanks Meter: 92
dear friend
first open the phone check pcb ,clean re hot uem, upp then flash the phone
and always use easy cable for flash
Old 07-14-2011, 06:56   #3 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,177
chk with full erasing phone first and flash ...if that works?
Old 07-14-2011, 16:39   #4 (permalink)
Member: 683750
Thanks Meter: 2
bro, is it possible to write flash (2330c) without inserting battery?. Phone cannot flash if battery is inserted. but flash (not complete) without battery.
I tried to full erase chips but erasing fail.
Old 07-14-2011, 16:42   #5 (permalink)
Member: 683750
Thanks Meter: 2
what should i do again
Old 07-14-2011, 18:08   #6 (permalink)
Member: 575900
Thanks Meter: 3,177
flash with fbus cable or with easy cable with + line cable ..attach it ..
and whats phone history
Old 08-28-2011, 15:13   #7 (permalink)
Member: 741012
Thanks Meter: 20
nokia 2330c Alg Boot Error: 2 Error Data1:
please help nokia 2330c
1st Boot: Ok, DCT4, UPP: 3168 [Rm-512] [2.2.0.1]
2nd Boot: u3_2nd.fia, Ver: 4.79.0
Fl0: 0x01000000-0x04FFFFFF,00EC2600,Sam K8x1259ET
Algorithm: u3_amd.fia, Ver: 4.79.0
Alg Boot Error: 2
Error Data1:
00000000: 9F 03 02 01 00 EC 26 00 00 00 92 21 11 00 02 00 ......&....!....
00000010: EC 26 00 00 00 92 21 11 00 AD 7E B6 1B 23 10 03 .&....!...~..#..
00000020: 40 C6 05 E4 01 20 A2 00 00 67 00 00 00 00 00 00 @.... ...g......
00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Error Data2:
00000000: F3 72 11 11 00 00 00 00 00 00 00 00 00 00 00 00 .r..............
00000010: 00 00 92 21 11 00 AD 7E B6 1B 23 10 03 40 C6 05 ...!...~..#..@..
00000020: E4 01 20 A2 00 00 67 D3 72 00 00 00 00 00 00 00 .. ...g.r.......
Before taking screenshot, expand this window !
Process Failed, Repowering Mobile
** User Break **
Page generated in 0.20349 seconds with 9 queries
