Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 07-28-2012, 02:09   #1 (permalink)
kashif_nawaz81's Avatar
Member: 246429
Thumbs up Nokia 2690 Strange Problem
Any body can tell me that my nokia 2690 is flashing successful with only file ver 10.61, while if i put any other version, it stops at end Setting Factory Default. The intresting thing is that befor this, version 10.10 were installed
what is that problem, iam puzzled
The Following User Says Thank You to kashif_nawaz81 For This Useful Post:
Old 07-28-2012, 02:17   #2 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
cos is an sl3 mobile: if you want flash it with a lower version you must tick "new downgrade" to get the mobile alive after the flash
Alex
Note: use the fbus with this mobile
Old 07-28-2012, 14:28   #3 (permalink)
Member: 246429
Arrow
Alex
ok sir when i'll flash the phone and will post the result. by the way please tell me only in sl3 mobile '' new donwgrade'' check will be enable?? and which sets are sl3 catagory
Old 07-28-2012, 15:50   #4 (permalink)
Member: 246429
Alex
SIR WHAT IS DIFFERENCE BETWEEN DOWNGRADE AND NEW DOWNGRADE MENTION IN CYCLONE PREFLASH TASK
Old 07-28-2012, 22:11   #5 (permalink)
ptt
ptt's Avatar
Member: 348680
Please dont be lazy and use the "Search" function of the forum
here just one result: new downgrad
Old 07-29-2012, 01:05   #6 (permalink)
Member: 246429
Yes sir! mobile succesfully flash by version 10.10 when i check new downrage tab using Fbus cable
Thank u very much
Last edited by ptt; 07-29-2012 at 02:28. Reason: CHANGE FONT SIZE & COLOR -- NOBODY IS BLIND HERE
Old 07-29-2012, 01:31   #7 (permalink)
Member: 246429
Is this downgrade is also done by usb metohod??????????
Last edited by ptt; 07-29-2012 at 02:29. Reason: CHANGE FONT SIZE & COLOR -- NOBODY IS BLIND HERE -- USE NORMAL SIZE & COLOR FONT WHEN POST
Old 07-29-2012, 02:30   #8 (permalink)
ptt
ptt's Avatar
Member: 348680
Check the link from post #5
Old 07-29-2012, 22:40   #9 (permalink)
Member: 246429
>>Ok sir i have read the forum as u mentions, but what is the difference between downgrade and new downgrade
>> and what should we do if i flah any mobie with last latest flash file but the set will not yet fully flash and in the end stops flashing at Setting Factory Default......
Checking all version but the result same stop at end of flashing Factory setting defualt, any solution plz
Old 07-29-2012, 23:16   #10 (permalink)
ptt
ptt's Avatar
Member: 348680
Here you have some answers & also some guides about Old & New downgrade...
FAQ about Nokia BB5 and detailed procedures manuals
Downgrade help needed (SOLVED)
Search about the problem using your Phone Model, and If you can not find any thread marked as "solved" related to your problem, then, Open a New Thread & Post the Complete LOG of the Operation....
PS.
Not need to use Big Fonts we can read Normal size fonts
Old 07-29-2012, 23:46   #11 (permalink)
Member: 246429
PS.
Thanks sir i'll see these posts, if u don't mind please give me your yahoo id
Old 07-31-2012, 01:09   #12 (permalink)
Member: 246429
i have read the thread carefully, than sir, i have successfully flash nokia 2690, by new downgrade method it successfully flash, but there were version 10.61 were installed and i have easly create rpl and pm,
my question is that Can we create rpl and pm from any dead phone, if yes then there is no problem and if NO then what is the proceduce to live to mobile again and create rpl and pm
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.32950 seconds with 11 queries
