Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 06-28-2012, 17:47   #1 (permalink)
xavi29's Avatar
Member: 1305009
Exclamation Nokia 2730c down grade not working for me.let logs.[Solved]
Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
Searching for BootCode: DualLine 32Bit
FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 8669C77551AE1280331BBAE6FD0C7CB3D3F44CC1
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Retrieving Variants for Product RM-578 - wait...
1 Variants Retrieved
Step 1, Dumping Unique Data
WARNING: Failed to read RAP Public ID
Reading CYC file from phone...
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101023000
CMT_EM_ASIC_ID: 00000296
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 26600106A37205568A506B3D904AECC1B3F1C8F7
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT_BOOT_ROM_CRC: 273F6D55
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Old Loader Detected
Readed OK, Saving to "26600106A37205568A506B3D904AECC1B3F1C8F7.C0002A6B "
Setting phone to Local Mode
Booting CMT...
CMT Ready!
Searching for BootCode: Single Line 8Bit
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0089898200000000, Intel, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
Prepare phone failed with message -> Not found required CMT Algorithm
Failed to Check BB5 Flashing Bus -> Failed to Boot / Prepare Phone
Failed to Proceed with New Downgrade -> Failed to Boot CMT and set to Local Mode
Processing pre flash tasks...
Applying downgrade patch...
Apply downgrade patch failed -> Phone not detected
Pre flash tasks finished, continuing...
Processing rm578__10.45.mcusw (CMT)...
Booting CMT...
CMT Ready!
rm578__10.45.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5
FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR
Box VPP disabled
Sending Certificates...
Certificates OK
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR
EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR
EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR
EraseArea[0,CMT]: 0x00140000-0x0155FFFF, NOR
EraseArea[0,CMT]: 0x01560000-0x0175FFFF, NOR
Waiting 320s for erasure finish...
Erase taken 147.531s
Writing all blocks...
Initializing TurboCache...
TurboCache Loaded!
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PASUBTOC Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Programming Status OK!
All blocks written OK! Time taken 56.828s
Flashing Speed: 3195,95 kBit/S
Restarting MCU...
Processing rm578__10.45.mcusw (APE)...
Processing rm578__10.45.ppm_ag (CMT)...
Booting CMT...
CMT Ready!
rm578__10.45.ppm_ag, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01760000-0x01FFFFFF, NOR
Erase taken 38.141s
TurboCache Loaded!
All blocks written OK! Time taken 13.390s
Flashing Speed: 3546,20 kBit/S
Restarting MCU...
Processing rm578__10.45.ppm_ag (APE)...
Processing rm578__10.45_006.image_ag_voda_es_91163 (CMT)...
Booting CMT...
CMT Ready!
rm578__10.45_006.image_ag_voda_es_91163, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x02000000-0x0245FFFF, NOR
EraseArea[0,CMT]: 0x02460000-0x03FBFFFF, NOR
Erase taken 136.500s
TurboCache Loaded!
All blocks written OK! Time taken 36.171s
Flashing Speed: 3598,90 kBit/S
Restarting MCU...
Processing rm578__10.45_006.image_ag_voda_es_91163 (APE)...
Processing rm578__10.45_sd_iberia.fpsimage (CMT)...
Booting CMT...
CMT Ready!
rm578__10.45_sd_iberia.fpsimage, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
TurboCache Loaded!
All blocks written OK! Time taken 336.562s
Flashing Speed: 5564,82 kBit/S
Restarting MCU...
Processing rm578__10.45_sd_iberia.fpsimage (APE)...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
SOFT keep stuck here.already tried with new DOWN GRADE method and normal.
with and with out tick tx2 but same result.phone have 10.46 version.and i
want change language to spanish language.so did not find any 10.46 with spanish language,so decided to make downgrade.p`leae guide.thanks
Tutorial - Downgrading all Latest BB5 Mobiles (SL3, RAPIDO, RAPU, RAP4, ...)
follow this thread but not helped.
Old 06-28-2012, 17:49   #2 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
did you make the back-up before doing the downgrade? (RPL from phone and PM)
if you have the back-ups (at least the rpl complete of simlock!!!) just follow the instructions on this post
FAQ about Nokia BB5 and detailed procedures manuals
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 06-28-2012, 19:54   #3 (permalink)
xavi29's Avatar
Member: 1305009
have rpl and pm back up made before doing any thing.i can revive easily
phone again with fenix key with flashing same version.but i want down grade for change language.
how to do?
Old 06-28-2012, 22:09   #4 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
how to do?
Now it is again in fully working state just flash it with "new downgrade" ticked via fbus
Alex
Old 06-29-2012, 08:56   #5 (permalink)
xavi29's Avatar
Member: 1305009
with same version flashed ok.let u both logs.
Old 06-29-2012, 08:59   #6 (permalink)
xavi29's Avatar
Member: 1305009
same version was flashed ok.but new down grade or normal down grade not working.
logs already popsted in my previous post.waiting....for alex or other experts.
Old 06-29-2012, 09:07   #7 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Give me 20 minutes I finish a job on teamviewer with another custmer then, if you are willing to, we can connect via teamviewer to have a look at this mobile together.
Alex
Old 06-29-2012, 09:09   #8 (permalink)
xavi29's Avatar
Member: 1305009
ok np.i will wait alex.thanks for your time.
Old 06-29-2012, 09:27   #9 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Solved via teamviewer
Alex
Old 06-29-2012, 09:42   #10 (permalink)
xavi29's Avatar
Member: 1305009
Alex
thanks alex,you are the best and always ready for help us.feel lucky to be part of cyclone box.
Old 06-29-2012, 09:44   #11 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Always welcome bro
We been the 1st team to use teamviewer for a direct support to the customers and still happy to do it when needed.
Alex
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.38935 seconds with 11 queries
