Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 03-13-2012, 15:50   #1 (permalink)
Member: 137980
Thanks Meter: 155
nokia 3110 contact service
nokia 3110 contact service please help
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Nokia/Blackberry Application v01.88, (Feb 14 2012 01:59:38, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C0001BF1
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk23
Initializing security card...
Card Serial Number: D60000A4
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage	5.06v	PASSED
MCU Voltage	3.30v	PASSED
Core Voltage	1.77v	PASSED
VBAT Voltage	1.37v	PASSED
VBAT Voltage	4.99v	PASSED
Box VPP disabled
VPP Voltage	0.02v	PASSED
Internal Box VPP Enabled
VPP Voltage	5.01v	PASSED
Box VPP disabled
VPP Voltage	0.04v	PASSED
External Box VPP Enabled
VPP Voltage	0.04v	FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Credits Left: 100
Avaiable Physical Memory: 1.1023GB
Avaiable Virtual Memory: 1.494GB
Avaiable Pagefile: 3.893GB
Initializing FBUS...
All initialized - Ready to work
Setting factory defaults of: Factory set full
Factory defaults set OK
Started Phone Security Analysis...
MCU Version	V 07.21
MCU Date	05-11-08
Product		RM-237 (Nokia 3110c)
Manufacturer	(c) Nokia.
IMEI		359343028665769
Mastercode	641045211
Reading Security Block...
Security block OK and saved to "RM-237_359343028665769_3132012_71741 PM.SecurityBlock.PM"
Step 1 : Testing SIMLOCK
SIMLOCK SEFLTEST PASSED OK!
Step 2 : Testing SECURITY
-- SECURITY PROBLEM --
Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED!
To repair it, simply slick "SX4 Authorization / SD Repair" button.
After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically)
Additionaly, Checking HWC/CCC Certs...
Booting CMT...
CMT_SYSTEM_ASIC_ID:	000000010000022600010006010C192101001101
CMT_EM_ASIC_ID:		00000232
CMT_EM_ASIC_ID:		00000353
CMT_PUBLIC_ID:		0DA000122B327E561D9DB9404D1654C2E63F30DC
CMT_ASIC_MODE_ID:	00
CMT_ROOT_KEY_HASH:	BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_BOOT_ROM_CRC:	191EC665
CMT_SECURE_ROM_CRC:	DFAAF68F
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0089898100006A21, Intel, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x00898981 (Intel), Size: 32MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: C0E691EA16A7593A9BB28832D7312A39F7ED668D
APE Subsystem Not Found
Flashbus Write baud set to 5.0Mbits
HWC Looks OK!
CCC Looks OK!
Restarting MCU...
Step 3 : Analyzing Security Block
"0DA000122B327E561D9DB9404D1654C2E63F30DC.C0001BF1" Exists, That is good...
Checking SUPERDONGLE...
SUPERDONGLE FOUND AND CHECKSUM OK! PASSED!
Checking SIMLOCK...
SIMLOCK FOUND AND CHECKSUM OK! PASSED!
Checking MCU&DSP TIMESTAMPS...
MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED!
Checking CMLA KEYS...
CMLA KEYS FOUND AND CHECKSUM OK! PASSED!
Checking ECC KEYS...
ECC KEYS FOUND AND CHECKSUM OK! PASSED!
Checking DIV KEYS...
Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?)
Analyze finished!
Old 03-13-2012, 16:50   #2 (permalink)
wiro_cool's Avatar
Member: 820104
Sonork: 100.1606814
Thanks Meter: 108
Sir,U Problem is In Red Color and U Solution in Green Colour,,,,,,,,,
The Following User Says Thank You to wiro_cool For This Useful Post:
Old 03-13-2012, 17:35   #3 (permalink)
richard26's Avatar
Member: 533419
Thanks Meter: 79
it's security test failed problem, follow wiro_cool say..,
the answer to your problem in your logs...
The Following User Says Thank You to richard26 For This Useful Post:
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
Page generated in 0.25761 seconds with 8 queries
