Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 09-29-2010, 13:45   #1 (permalink)
Registered User
Member: 247893
Thanks Meter: 82
Nokia 5130 RM-495 CONTACT SERVICE SOLVED
Amazingly i have repaired two pcs of Nokia 5130 10 minutes ago
with Cyclone Box.
Procedure :
1. i used TX2 adaptor
click on Downgrade ( Fast Repair )
this is the first reults
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v01.46, (Jul 24 2010 23:54:36, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2010 wk27
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C00037FA
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk40
Initializing security card...
Card Serial Number: D800012C
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5.00v PASSED
MCU Voltage 3.28v PASSED
Core Voltage 1.78v PASSED
VBAT Voltage 1.39v PASSED
VBAT Voltage 4.87v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
Internal Box VPP Enabled
VPP Voltage 4.92v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
External Box VPP Enabled
VPP Voltage 0.00v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
Initializing FBUS...
All initialized - Ready to work
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000
CMT_EM_ASIC_ID: 00000296
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 22000115E5667D56ADB5F309727DFC5CA9A0D5DC
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT_BOOT_ROM_CRC: 273F6D55
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
CMT NPC Ok
CMT NPC Erased
Restarting MCU...
Backing up simlock...
MCU Version V 05.80
MCU Date 18-12-08
Product RM-495
Manufacturer (c) Nokia
IMEI 12345610654321?
Simlock backup OK, saved to RM-495_12345610654321_9292010_120325 PM.SLBackup.PM
Backup simlock thread finished, continuing...
Applying downgrade patch...
Apply downgrade patch failed -> Failed to write patched PM 308
Failed to BB5 Downgrade Repair -> Failed to Patch PM 308
2. Click on SX4 ( Authorized / Repair SD Keys )
after this the results is
SX4 Authorization / SD Repair Procedure Started....
WARNING: "22000115E5667D56ADB5F309727DFC5CA9A0D5DC.C00037FA " Not Exists, Will read it...
Reading CYC file from phone...
Booting CMT...
CMT Ready!
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Readed OK, Saving to "22000115E5667D56ADB5F309727DFC5CA9A0D5DC.C00037FA "
MCU Version V 05.80
MCU Date 18-12-08
Product RM-495
Reading Security Block...
Security block OK and saved to "RM-495_12345610654321_9292010_120402 PM.SecurityBlock.PM"
SX4 Status: Authorized
MCU Version V 05.80
MCU Date 18-12-08
Product RM-495
IMEI Spare 1A32541660452301
IMEI SV 1332541660452321F6000000
PPM V 05.80, 18-12-08, RM-495, (c) Nokia , EL
CNT Content: el_blu, V 05.80, 18-12-08, RM-495, (c) Nokia ,
PSN HEC292704
Module Code 0204024
Basic Product Code 0567773
PSD 0000000000000000
LPSN 0
RETU 16
TAHVO 22
AHNE 30
HW 1000
RFIC 064c0601
DSP ICPR72_08w50
LCD SEIKO
BT 2222-143C
Failed to read info -> Failed to read SP info
"22000115E5667D56ADB5F309727DFC5CA9A0D5DC.C00037FA " Exists, That is good...
MCU Version V 05.80
MCU Date 18-12-08
Product RM-495
Security block OK and saved to "RM-495_12345610654321_9292010_120505 PM.SecurityBlock.PM"
Failed to Write RPL File -> RPL File invalid, not begins with `REBUILD DATA` Magic, Maybe it is PLAIN ONE ?
[308,1] Written, Length: 8192 bytes, Status: Not accepted, Code: 19
Write PM Finished, Record written OK: 0, Record written NOT OK: 1
Booting CMT...
CMT Ready!
Box VPP disabled
Failed to BB5 Downgrade Repair -> Invalid NPC Found! Magic is BAD!
MCU Version V 05.80
MCU Date 18-12-08
Product RM-495
Security block OK and saved to "RM-495_12345610654321_9292010_121246 PM.SecurityBlock.PM"
3. Last step is to click on Info and go to Write PM
this is the results ,
MCU Version V 05.80
MCU Date 18-12-08
the pm is selected from the saved Pm Security Block from Server.
After this your Nokia 5130 is repaired from RED Contact Service.
Regards
The Following User Says Thank You to francogsm For This Useful Post:
Old 09-29-2010, 14:06   #2 (permalink)
Member: 961700
Thanks Meter: 27
but the imei is 1234567 bro
unit auto off when playin mp3 music
Old 09-29-2010, 14:45   #3 (permalink)
Member: 823633
Thanks Meter: 1,640
bro u r phone imei is damage here
phone power on few secand working after power off
or music play after power off
only solu nokia rpl here
Old 09-29-2010, 14:52   #4 (permalink)
Registered User
Member: 247893
Thanks Meter: 82
Bro phone is working fine and return to customer.
Old 09-29-2010, 15:16   #5 (permalink)
him82's Avatar
Member: 646646
Sonork: 100.1664464
Thanks Meter: 221
dear sl3 server is not open 123456654321 not solution at this time
Old 09-29-2010, 15:56   #6 (permalink)
Member: 504557
Thanks Meter: 20
u are playing brother.......
Old 09-29-2010, 21:05   #7 (permalink)
Rey_negro's Avatar
Member: 417512
Thanks Meter: 46
now you need a RPL nokia original, even when solution for unlock be ready
Old 09-29-2010, 23:09   #8 (permalink)
leonize's Avatar
Member: 1096162
Thanks Meter: 413
Thumbs down Lol
with Cyclone Box.
Procedure :
this is the first reults2. Click on SX4 ( Authorized / Repair SD Keys )
after this the results is 3. Last step is to click on Info and go to Write PM
this is the results , the pm is selected from the saved Pm Security Block from Server.
Regards
THIS IS WHAT I THINK :
:DHAHAHAHAHAHAHAHAHA:D
These crazy?
Imei BAD 12345654321?.. solucion is RPL of NOKIA .
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.30801 seconds with 8 queries
