Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 12-09-2010, 09:36   #1 (permalink)
crackp0d's Avatar
Member: 571377
Sonork: 100.1608017
Nokia 5130Xm Dead [ Solved ]
My friends
I have 1 Nokia 5130 dead Flashing ok but not power on
This is log
Super DCT4 Activation: TRUE
Initializing FBUS...
All initialized - Ready to work
Sending User Abort Signal...
CBUS Request Error -> User abort
Failed to read info -> Phone not detected
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\...
Found 55 products, Filtering BB5 Products - wait...
21 Products left after filtering. Ready.
Retrieving Variants for Product RM-495 (Nokia 5130 XpressMusic) - wait...
105 Variants Retrieved
Processing pre flash tasks...
Backing up RPL...
RPL Creation started...
Processing CMT Part...
Warning: Phone not detected, using Rap Public ID in FileName and reading Certificates Only
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000
CMT_EM_ASIC_ID: 00000296
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 10B0001249CB8C560824D28CB84AB7857FFFF791
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT_BOOT_ROM_CRC: 273F6D55
CMT_SECURE_ROM_CRC: DFAAF68F
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.6.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
FlashChip[0,CMT]: 0x00EC240000008A31, Samsung, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x00EC2400 (Samsung), Size: 64MBytes, VPP: 9V
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.6.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 0C917F11196FDB7378C18EF7260698CA4489DCA0
APE Subsystem Not Found
Flashbus Write baud set to 5.0Mbits
Storing NPC...
Storing CCC...
Storing HWC...
CMT VARIANT Not Found
Restarting MCU...
RPL Saved OK
RPL backup thread finished, continuing...
Backing up simlock...
Simlock backup problem -> Phone not detected
Backup simlock thread finished, continuing...
Pre flash tasks finished, continuing...
Processing rm495__07.97.mcusw (CMT)...
Booting CMT...
CMT Ready!
rm495__07.97.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
Sending Certificates...
Certificates OK
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR
EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR
EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR
EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR
EraseArea[0,CMT]: 0x01380000-0x0151FFFF, NOR
Waiting 320s for erasure finish...
Erase taken 72.594s
Writing all blocks...
Initializing TurboCache...
TurboCache Loaded!
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PASUBTOC Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Programming Status OK!
All blocks written OK! Time taken 66.187s
Flashing Speed: 2306.30 kBit/S
Restarting MCU...
Processing rm495__07.97.mcusw (APE)...
Processing rm495__07.97.ppm_qa (CMT)...
Booting CMT...
CMT Ready!
rm495__07.97.ppm_qa, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01520000-0x01DBFFFF, NOR
Erase taken 24.937s
TurboCache Loaded!
All blocks written OK! Time taken 26.734s
Flashing Speed: 2308.04 kBit/S
Restarting MCU...
Processing rm495__07.97.ppm_qa (APE)...
Processing rm495__07.97.image_qa_red (CMT)...
Booting CMT...
CMT Ready!
rm495__07.97.image_qa_red, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01DC0000-0x0215FFFF, NOR
EraseArea[0,CMT]: 0x02160000-0x03FBFFFF, NOR
Erase taken 46.797s
TurboCache Loaded!
All blocks written OK! Time taken 39.218s
Flashing Speed: 2409.17 kBit/S
Restarting MCU...
Processing rm495__07.97.image_qa_red (APE)...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
plz help meeeee
Old 12-09-2010, 09:55   #2 (permalink)
Dooha_Bd's Avatar
Member: 1427033
Sonork: 100.1596688
Originally Posted by i.anas View Post
My friends
This is log
Backing up RPL...
Booting CMT...
CMT Ready!
Box VPP disabled
Storing NPC...
Storing CCC...
Storing HWC...
Restarting MCU...
RPL Saved OK
Booting CMT...
CMT Ready!
Box VPP disabled
Certificates OK
Erase taken 72.594s
TurboCache Loaded!
Restarting MCU...
Booting CMT...
CMT Ready!
Box VPP disabled
Erase taken 24.937s
TurboCache Loaded!
Restarting MCU...
Booting CMT...
CMT Ready!
Box VPP disabled
Erase taken 46.797s
TurboCache Loaded!
Restarting MCU...
plz help meeeee
Try to replace LCD.If you have original backup.
Old 12-09-2010, 10:12   #3 (permalink)
crackp0d's Avatar
Member: 571377
Sonork: 100.1608017
No progress after replacing display
yes i have original back op
Old 12-09-2010, 10:17   #4 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: ( Protected )
what was problem before flash?
Old 12-09-2010, 10:19   #5 (permalink)
Member: 1317020
Sonork: 100.1616949
did you see anything when you on your phone with charger connected to your phone.if it give any sign then check on off switch what was the actual problem when it come to you?
Old 12-09-2010, 10:19   #6 (permalink)
crackp0d's Avatar
Member: 571377
Sonork: 100.1608017
Still dead ...................
Old 12-09-2010, 17:40   #7 (permalink)
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
reball or replace avilma then check.
post result
Old 12-11-2010, 10:44   #8 (permalink)
crackp0d's Avatar
Member: 571377
Sonork: 100.1608017
My problem solved
This is hardware problem
After changing AVILMAS N2200 my phone is ok
My friends
This is log
Backing up RPL...
Booting CMT...
CMT Ready!
Box VPP disabled
Storing NPC...
Storing CCC...
Storing HWC...
Restarting MCU...
RPL Saved OK
Booting CMT...
CMT Ready!
Box VPP disabled
Certificates OK
Erase taken 72.594s
TurboCache Loaded!
Restarting MCU...
Booting CMT...
CMT Ready!
Box VPP disabled
Erase taken 24.937s
TurboCache Loaded!
Restarting MCU...
Booting CMT...
CMT Ready!
Box VPP disabled
Erase taken 46.797s
TurboCache Loaded!
Restarting MCU...
plz help meeeee
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.39968 seconds with 11 queries
