Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 05-12-2013, 15:19   #1 (permalink)
..:::Gsm india:::..'s Avatar
Member: 380464
Thanks Meter: 141
Nokia 5233 after wrong flash onley vibrate [ Solved ]
after wrong flash phone onley vibrate flash with latest RM-625_51.9.002 version same
flash eno firmware same plz help ............. me
Booting CMT...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051105
CMT_EM_ASIC_ID: 00000296
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 1920020FE6A000523B0F59559E8021330A41EA30
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
CMT_BOOT_ROM_CRC: 4B9B7510
CMT_SECURE_ROM_CRC: 3E691FF8
CMT Ready!
Searching for BootCode: DualLine 32Bit
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.12.8.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using NEW BB5 FLASHING PROTOCOL
Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x00EC004000000231, Samsung, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported
RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.12.8.0, Algo: XSR 1.5
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 7DC72D3FDC552426A4479BC820097D304CFB6C15
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Old 05-13-2013, 07:01   #2 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,127
tick new downgrade and flash the phone again with correct firmware
Old 05-13-2013, 11:12   #3 (permalink)
Member: 380464
Thanks Meter: 141
my phone is dead onley vibrate ..................
Old 05-13-2013, 11:13   #4 (permalink)
Member: 380464
Thanks Meter: 141
select new downgrade ......... and flash ............
Step 1, Dumping Unique Data
WARNING: Failed to read RAP Public ID
Reading CYC file from phone...
Booting CMT...
CMT Ready!
New_RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.11.16.0, Algo: BB5
Sending Auxiliary Loader...
Auxiliary Loader Sent!
Loader: RAPxx CommonBoot v1.06 (C) 2011 KarwosLabs
Custom loader running OK! Working...
Readed OK, Saving to "1920020FE6A000523B0F59559E8021330A41EA30.C0000BC0 "
Setting phone to Local Mode
Booting CMT...
CMT Ready!
TurboCache Loaded!
CMT FUR Ready!
Box VPP disabled
Restarting MCU...
Step 2, Reading Full PM
Starting PM read in range 0-512...
Failed to read PM -> Phone not detected
Failed to Proceed with New Downgrade -> Failed to Read PM
Old 05-13-2013, 11:20   #5 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,127
read certs
erase npc only
backup full pm
erase the phone
flash with correct version
restore backups and repair sd with 1-309 pm
Old 05-13-2013, 11:58   #6 (permalink)
Member: 380464
Thanks Meter: 141
thanks cyclone team my phone is alive now.................
Page generated in 0.14836 seconds with 8 queries
