nokia 5610d-1 rm 242 unlock error [SOLVED] have some problems when i try unlock this phone, allways recvie this error: All initialized - Ready to work MCU Version V 04.81 MCU Date 22-11-07 Product RM-242 Manufacturer (c) Nokia IMEI 354850021xxxxxx Mastercode 6047766645 IMEI Spare 3A455800126xxxxx IMEI SV 3345580012654918F6000000 PPM V 04.81, 22-11-07, RM-242, (c) Nokia , CVF CNT Content: vg_es2_red, V 04.81, 22-11-07, RM-242, (c) Nokia , , PSN CXA918824 Product Code 0566499 Module Code 0203378 Basic Product Code 0515121 PSD 0000000000000000 LPSN 0 RETU 15 TAHVO 22 AHNE 30 HW 1201 RFIC 17141715 DSP ICPR71_07w43 LCD SHARP BT 2222-101B Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F BB5 Unlock Started... MCU Version V 04.81 MCU Date 22-11-07 Product RM-242 Manufacturer (c) Nokia IMEI 354850021xxxxxx Mastercode 6047766645 Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... BB5 Unlock Failed -> Failed to Boot / Prepare Phone phone is connected via yellow adaptor |
if the mobile when you get the error is on like under battery, you need to increse the BSI value (if you are using ufc select a value higher and retry, if you use an fbus cable connect a tma adapter and select all the switches off apart the n.2 or the n.3) If the mobile blinks and goes off is power problem.. use tma or any other tool for the power problem if the mobile is in local mode or does nothng, go in the tab bb5/flash and thick where says skip repower boot and after retry the unlock. Do all the back-ups BR Alex |
Ja has the flash device? When this error here, update the device software, and then do the unlock. |
problem soleved : phone connected via yellow adaptor - tma v1 (dip 7 value set on) - bb5 jungle cable => phone unlocked bellow log BB5 Unlock Started... MCU Version V 04.81 MCU Date 22-11-07 Product RM-242 Manufacturer (c) Nokia IMEI 354850021xxxxx Mastercode 6047766645 Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Reading Security Block... Security block OK! Determining PA Simlock... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1E200110958C02542185AF9B580771F561779A53 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: EE7EB2973C70788F43BFADFB1AD46A77E51DF8DB APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Determined PA Simlock: PA_SL2 Checking for Rootkey Hash support... Booting RAP... when say this i short pressed power button CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1E200110958C02542185AF9B580771F561779A53 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Received Security Block OK ! Writing Security Block... Writing Simlock Key... SP Accepted, doing reset to update block... MCU Version V 04.81 MCU Date 22-11-07 Product RM-242 Manufacturer (c) Nokia IMEI 354850021xxxxx Mastercode 6047766645 Simlock Server SIMLOCK SERVER Simlock Key 0010100000000000 Simlock Profile 8000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: 00101F Unlock finished! thansk for all replyes best regards |
