Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 10-10-2009, 13:41   #1 (permalink)
Member: 178450
Thanks Meter: 53
Thumbs down nokia 5610d-1 rm 242 unlock error [SOLVED]
have some problems when i try unlock this phone, allways recvie this error:
All initialized - Ready to work
MCU Version V 04.81
MCU Date 22-11-07
Product RM-242
Manufacturer (c) Nokia
IMEI 354850021xxxxxx
Mastercode 6047766645
IMEI Spare 3A455800126xxxxx
IMEI SV 3345580012654918F6000000
PPM V 04.81, 22-11-07, RM-242, (c) Nokia , CVF
CNT Content: vg_es2_red, V 04.81, 22-11-07, RM-242, (c) Nokia , ,
PSN CXA918824
Product Code 0566499
Module Code 0203378
Basic Product Code 0515121
PSD 0000000000000000
LPSN 0
RETU 15
TAHVO 22
AHNE 30
HW 1201
RFIC 17141715
DSP ICPR71_07w43
LCD SHARP
BT 2222-101B
Simlock Server SIMLOCK SERVER
Simlock Key 2140100000000000
Simlock Profile 8000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F
BB5 Unlock Started...
MCU Version V 04.81
MCU Date 22-11-07
Product RM-242
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Reading Security Block...
Security block OK!
Determining PA Simlock...
Booting RAP...
BB5 Unlock Failed -> Failed to Boot / Prepare Phone
phone is connected via yellow adaptor
The Following User Says Thank You to the sorrow For This Useful Post:
Old 10-10-2009, 14:11   #2 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,000
if the mobile when you get the error is on like under battery, you need to increse the BSI value (if you are using ufc select a value higher and retry, if you use an fbus cable connect a tma adapter and select all the switches off apart the n.2 or the n.3)
If the mobile blinks and goes off is power problem.. use tma or any other tool for the power problem
if the mobile is in local mode or does nothng, go in the tab bb5/flash and thick where says skip repower boot and after retry the unlock.
Do all the back-ups
Alex
Old 10-10-2009, 14:59   #3 (permalink)
Member: 385838
Sonork: pettersonboeno
Thanks Meter: 3
Ja has the flash device?
When this error here, update the device software, and then do the unlock.
Old 10-10-2009, 15:59   #4 (permalink)
Member: 178450
Thanks Meter: 53
problem soleved :
phone connected via yellow adaptor - tma v1 (dip 7 value set on) - bb5 jungle cable => phone unlocked
bellow log
MCU Version V 04.81
MCU Date 22-11-07
Product RM-242
IMEI 354850021xxxxx
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Security block OK!
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101003000
CMT_EM_ASIC_ID: 00000295
CMT_EM_ASIC_ID: 00000B22
CMT_PUBLIC_ID: 1E200110958C02542185AF9B580771F561779A53
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_ROM_ID: 273F6D55DFAAF68F
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x00EC220C00008921, Samsung, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: EE7EB2973C70788F43BFADFB1AD46A77E51DF8DB
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Determined PA Simlock: PA_SL2
Checking for Rootkey Hash support...
Booting RAP... when say this i short pressed power button
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Exploiting - running preloader...
Preloader running OK, Running Custom Loader...
Custom loader running OK! Working...
Received Security Block OK !
Writing Security Block...
Writing Simlock Key...
SP Accepted, doing reset to update block...
MCU Version V 04.81
MCU Date 22-11-07
Product RM-242
IMEI 354850021xxxxx
Simlock Key 0010100000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: 00101F
Unlock finished!
thansk for all replyes
best regards
5610d RM- 242, flashing error Riteshgpt60 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 10-24-2009 08:10
Nokia 5610d-1 RM-240 china pinouts needed please? dr hape Chinese Models & Cloned Phones 0 06-04-2009 07:35
5610d-1 rm-242 need modify pm ???? jonar23 Nokia Base Band 5 ( BB-5 ) 2 04-08-2009 05:06
Nokia 5610d-2b rm-359 unlocked successfully UNIQUEM MT-BOX 0 03-17-2009 13:48
Nokia 5610d-1 (rm-242 ) settings ? thehelmut TORNADO - SIM 4 08-27-2008 22:31
Page generated in 0.27381 seconds with 8 queries
