Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 05-19-2012, 09:14   #1 (permalink)
Member: 233142
Sonork: 100.1595099
Nokia 5800 vibrat only can't power on [Solved]
Dear!
first i flash with eno and then reflash with latest firmware,,but same,,vibrate,,but when connected with box,can see locale mode ,tested mode.
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic]
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.01, (Apr 29 2012 16:16:15, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C0001AC9
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk19
Initializing security card...
Card Serial Number: D200035A
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage    5,04v    PASSED
MCU Voltage    3,27v    PASSED
Core Voltage    1,76v    PASSED
VBAT Voltage    1,31v    PASSED
VBAT Voltage    4,99v    PASSED
Box VPP disabled
VPP Voltage    0,04v    PASSED
Internal Box VPP Enabled
VPP Voltage    5,01v    PASSED
Box VPP disabled
VPP Voltage    0,02v    PASSED
External Box VPP Enabled
VPP Voltage    0,04v    FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 1.18GB
Avaiable Virtual Memory: 1.366GB
Avaiable Pagefile: 2.938GB
Initializing FBUS...
All initialized - Ready to work
Booting CMT...
CMT_SYSTEM_ASIC_ID:    000000010000022600010006400C192101031103
CMT_EM_ASIC_ID:        00000295
CMT_EM_ASIC_ID:        00000B22
CMT_PUBLIC_ID:        0C1001122A7A0052C7CE6E5348A7D6DDB5B5023D
CMT_ASIC_MODE_ID:    00
CMT_ROOT_KEY_HASH:    CAEEBB65D3C48E6DC73B49DC5063A2EE
CMT_BOOT_ROM_CRC:    4B9B7510
CMT_SECURE_ROM_CRC:    3E691FF8
CMT Ready!
Searching for BootCode: DualLine 32Bit (Forcing OLD Protocol)
RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.37.1, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
Using OLD BB5 FLASHING PROTOCOL
If software STUCK HERE with box TX LED lit, that means:
1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!)
2. Your cable is not TX2 Enabled!
3. Transmission error occured, try again
In either cases, you need to reconnect your box from USB.
FlashChip[0,CMT]: 0x00EC004000400121, Samsung, ONENAND
FlashContent[0,CMT]: 00000000000000000000000000000000, ONENAND
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported
RAPIDOv11_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: XSR 1.5
Flashbus Write baud set to 2.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61
APE Boot skipped on user request
Flashbus Write baud set to 5.0Mbits
Restarting MCU...
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing rm356_ENO_x_2008wk42v0.033.fpsx (CMT)...
Booting CMT...
CMT Ready!
rm356_ENO_x_2008wk42v0.033.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5
Flashbus Write baud set to 650Kbits
Box VPP disabled
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00040000-0x00082FFF, ONENAND
EraseArea[0,CMT]: 0x00083400-0x003FFFFF, ONENAND
EraseArea[0,CMT]: 0x00400000-0x007FFFFF, ONENAND
EraseArea[0,CMT]: 0x00800000-0x00D5FFFF, ONENAND
EraseArea[0,CMT]: 0x00D60000-0x0A81FFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 1.14s
Writing all blocks...
Initializing TurboCache...
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT PASUBTOC Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT SOS*ENO Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT SOS*ISASW Certificate...
Programming Status OK!
All blocks written OK! Time taken 11.357s
Flashing Speed: 4729,74 kBit/S
Restarting MCU...
Processing rm356_ENO_x_2008wk42v0.033.fpsx (APE)...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Factory defaults OK
Reading info...
MCU Version    V ICPR72_08w41
MCU Date    10-10-08
Product        RM-356 (Nokia 5800 XpressMusic)
Manufacturer    (c) Nokia
IMEI        354216035113269
Mastercode    42116613
IMEI Spare    3A45120653112306
IMEI SV        3345120653112336F2000000
PSN        CCI701393
Product Code    0578174
Basic Product Code    0552692
PSD        0000000000000000
LPSN        0
WLAN MAC    002548F8E8B9
APE Test        rm356_ENO_x_2008wk42v0.033
APE HW        256
APE ADSP    256
RETU        15
TAHVO        22
AHNE        11
HW        1101
RFIC        17141715
DSP        ICPR72_08w41
Failed to read info -> Failed to read SP info
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
MCU Date    10-10-08
Mastercode    42116613
CNT        v 40.0.002_023_xxx_U01, 27-11-09, vanilla, RM356
PSN        CCI701393
LPSN        0
APE HW        256
APE ADSP    256
RETU        15
TAHVO        22
AHNE        11
HW        1101
RFIC        17141715
DSP        ICPR72_08w41
BB5 Unlock Started...
MCU Date    10-10-08
Mastercode    42116613
Warning: Failed to read SP Info, Assuming defaults
Simlock Server    SIMLOCK SERVER
Simlock Key    0000000000000000
Simlock Profile
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Reading Security Block...
Security block OK and saved to "RM-356_354216035113269_19052012_093715.SecurityBlock.PM"
"0C1001122A7A0052C7CE6E5348A7D6DDB5B5023D.C0001AC9" Exists, That is good...
Checking for Rootkey Hash support with selected Unlock Method...
Selected Unlock Method: RPL Calculation
Asking box to calculate RPL...
Received RPL from Box OK!
Writing Simlock...
Simlock ACCEPTED OK !
MCU Date    10-10-08
Mastercode    42116613
Simlock Key    2440700000000000
Simlock Profile    8000000000000006
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Simlock [1,1]    State: OPENED    Type: MCC-MNC    Data: FFFFFF
Simlock [1,2]    State: OPENED    Type: GID    Data: FFFF
Simlock [1,3]    State: OPENED    Type: GID    Data: FFFF
Simlock [1,4]    State: OPENED    Type: IMSI    Data: FFFFFFFFFFFFFFFF
Simlock [1,5]    State: OPENED    Type: IMSI    Data: FFFFFFFFFFFFFFFF
Simlock [2,1]    State: OPENED    Type: MCC-MNC    Data: FFFFFF
Simlock [2,2]    State: OPENED    Type: GID    Data: FFFF
Simlock [2,3]    State: OPENED    Type: GID    Data: FFFF
Simlock [2,4]    State: OPENED    Type: IMSI    Data: FFFFFFFFFFFFFFFF
Simlock [2,5]    State: OPENED    Type: IMSI    Data: FFFFFFFFFFFFFFFF
Simlock [3,1]    State: OPENED    Type: MCC-MNC    Data: FFFFFF
Simlock [3,2]    State: OPENED    Type: GID    Data: FFFF
Simlock [3,3]    State: OPENED    Type: GID    Data: FFFF
Simlock [3,4]    State: OPENED    Type: IMSI    Data: FFFFFFFFFFFFFFFF
Simlock [3,5]    State: OPENED    Type: IMSI    Data: FFFFFFFFFFFFFFFF
Simlock [4,1]    State: OPENED    Type: MCC-MNC    Data: FFFFFF
Simlock [4,2]    State: OPENED    Type: GID    Data: FFFF
Simlock [4,3]    State: OPENED    Type: GID    Data: FFFF
Simlock [4,4]    State: OPENED    Type: IMSI    Data: FFFFFFFFFFFFFFFF
Simlock [4,5]    State: OPENED    Type: IMSI    Data: FFFFFFFFFFFFFFFF
Simlock [5,1]    State: OPENED    Type: MCC-MNC    Data: FFFFFF
Simlock [5,2]    State: OPENED    Type: GID    Data: FFFF
Simlock [5,3]    State: OPENED    Type: GID    Data: FFFF
Simlock [5,4]    State: OPENED    Type: IMSI    Data: FFFFFFFFFFFFFFFF
Simlock [5,5]    State: OPENED    Type: IMSI    Data: FFFFFFFFFFFFFFFF
Simlock [6,1]    State: OPENED    Type: MCC-MNC    Data: FFFFFF
Simlock [6,2]    State: OPENED    Type: GID    Data: FFFF
Simlock [6,3]    State: OPENED    Type: GID    Data: FFFF
Simlock [6,4]    State: OPENED    Type: IMSI    Data: FFFFFFFFFFFFFFFF
Simlock [6,5]    State: OPENED    Type: IMSI    Data: FFFFFFFFFFFFFFFF
Simlock [7,1]    State: OPENED    Type: MCC-MNC    Data: FFFFFF
Simlock [7,2]    State: OPENED    Type: GID    Data: FFFF
Simlock [7,3]    State: OPENED    Type: GID    Data: FFFF
Simlock [7,4]    State: OPENED    Type: IMSI    Data: FFFFFFFFFFFFFFFF
Simlock [7,5]    State: OPENED    Type: IMSI    Data: FFFFFFFFFFFFFFFF
Unlock finished! Time taken 4.836s
latest firmware flash
Initializing box...
Card is activated
Box is activated
USB Voltage    4,95v    PASSED
VBAT Voltage    1,46v    PASSED
Box VPP disabled
Box VPP disabled
Box VPP disabled
Avaiable Physical Memory: 1.25GB
Avaiable Virtual Memory: 1.361GB
Avaiable Pagefile: 2.941GB
Failed to read info -> Phone not detected
Booting CMT...
CMT Ready!
Box VPP disabled
Restarting MCU...
MCU Date    10-10-08
Mastercode    42116613
PSN        CCI701393
LPSN        0
APE HW        256
APE ADSP    256
RETU        15
TAHVO        22
AHNE        11
HW        1101
RFIC        17141715
DSP        ICPR72_08w41
Simlock Key Cnt    0
Simlock FBUS Cnt    0
Auto Selecting Flash Files on User Request...
Product Code: 0578174
Scanning avaiable products...
Processing C:\Program Files\Nokia\Phoenix\Products\...
Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\...
Found 68 products, Filtering DCT4 Products - wait...
14 Products left after filtering. Ready.
This is Valid BB5 Product
Retrieving Variants for Product RM-356 - wait...
1 Variants Retrieved
No variant found with given Product Code, selecting first one
Processing RM-356_60.0.003_prd.core.C00 (CMT)...
Booting CMT...
CMT Ready!
RM-356_60.0.003_prd.core.C00, Type: Flash Image, Algo: XSR 1.5, BB5
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x00D60000-0x09E5FFFF, ONENAND
Erase taken 0.936s
TurboCache Loaded!
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
All blocks written OK! Time taken 175.205s
Flashing Speed: 5288,00 kBit/S
Restarting MCU...
Processing RM-356_60.0.003_prd.core.C00 (APE)...
Processing RM-356_60.0.003_prd.rofs2.V01 (CMT)...
Booting CMT...
CMT Ready!
RM-356_60.0.003_prd.rofs2.V01, Type: Flash Image, Algo: XSR 1.5, BB5
Box VPP disabled
EraseArea[0,CMT]: 0x07180000-0x0915FFFF, ONENAND
Erase taken 0.203s
TurboCache Loaded!
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 39.125s
Flashing Speed: 5162,44 kBit/S
Restarting MCU...
Processing RM-356_60.0.003_prd.rofs2.V01 (APE)...
Processing RM-356_60.0.003_C01_prd.rofs3.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM-356_60.0.003_C01_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5
Box VPP disabled
EraseArea[0,CMT]: 0x09160000-0x09E5FFFF, ONENAND
Erase taken 0.93s
TurboCache Loaded!
Writing CMT SOS+ROFS3 Certificate...
All blocks written OK! Time taken 2.75s
Flashing Speed: 4963,11 kBit/S
Restarting MCU...
Processing RM-356_60.0.003_C01_prd.rofs3.fpsx (APE)...
Processing RM-356_60.0.001_026_000_U01.uda.fpsx (CMT)...
Booting CMT...
CMT Ready!
RM-356_60.0.001_026_000_U01.uda.fpsx, Type: Flash Image, Algo: XSR 1.5, BB5
Box VPP disabled
EraseArea[0,CMT]: 0x09E60000-0x0F71FFFF, ONENAND
Erase taken 0.514s
TurboCache Loaded!
All blocks written OK! Time taken 12.683s
Flashing Speed: 4692,35 kBit/S
Restarting MCU...
Processing RM-356_60.0.001_026_000_U01.uda.fpsx (APE)...
Factory defaults OK
Reading info...
MCU Version    V ICPR72_10w29_tube1
MCU Date    24-05-11
Mastercode    42116613
IMEI SV        3345120653112376F4000000
PSN        CCI701393
LPSN        0
APE SW        V 60.0.003
APE Variant    V 60.0.003V 60.0.003 V 60.0.003
APE Test        eno_version
APE HW        256
APE ADSP    256
RETU        15
TAHVO        22
AHNE        11
HW        1101
RFIC        17141715
DSP        ICPR72_10w26p1
Simlock Key Cnt    0
Simlock FBUS Cnt    0
selftest stop at 52%
Passed        ST_TAHVOINT_TEST
Passed        ST_UEM_CBUS_IF_TEST
Passed        ST_EAR_DATA_LOOP_TEST
Passed        ST_SIM_CLK_LOOP_TEST
Passed        ST_SIM_IO_CTRL_LOOP_TEST
Passed        ST_SIM_LOCK_TEST
Passed        ST_SECURITY_TEST
Passed        ST_PWR_KEY_TEST
Passed        ST_CURRENT_CONS_TEST
Passed        ST_BACKUP_BATT_TEST
Failed        ST_RADIO_TEST
Passed        ST_HOOKINT_TEST
Failed        ST_BTEMP_TEST
Passed        ST_MBUS_RX_TX_LOOP_TEST
Passed        ST_AMB_LIGHT_SENSOR_TEST
Passed        ST_IIC_TEST
Passed        ST_EXT_DEVICE_TEST
Passed        ST_CDSP_SLEEPCLK_FREQ_TEST
Passed        ST_CDSP_SLEEPCLOCK_FREQ_TEST
Passed        ST_CDSP_RF_BB_IF_TEST
Passed        ST_CDSP_RF_SUPPLY_TEST
Passed        ST_CDSP_TX_IQ_TEST
Passed        ST_CDSP_TXC_DATA_TEST
Passed        ST_CDSP_PWR_DETECTOR_BIAS_TEST
Passed        ST_CDSP_RX_PLL_PHASE_LOCK_TEST
Failed        ST_CDSP_TX_PLL_PHASE_LOCK_T
Failed to make Selftests -> Phone is not responding for Selftest Request
Help please
Old 05-19-2012, 09:16   #2 (permalink)
Member: 1346863
try change lcd sir...........
Old 05-19-2012, 09:19   #3 (permalink)
MALIK886's Avatar
Member: 1617868
Sonork: 100.1625996
chcke here dear
1 image
2 image
Old 05-19-2012, 12:57   #4 (permalink)
Absar_Global's Avatar
Member: 1442705
Sonork: 100.1623965
bro......check bsi...........................
Old 05-19-2012, 14:00   #5 (permalink)
nongmobile's Avatar
Member: 716581
1.Full backup rpl and pm
2.Full erase
3.Flash with any version
4.Restore form back up.
Old 05-19-2012, 17:46   #6 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: ( Protected )
Did u flash blank PMM file?
Old 05-20-2012, 09:00   #7 (permalink)
Member: 233142
Sonork: 100.1595099
I download file from Navifirm
please can you share PMM file here
tell me step by step about
Thanks
Old 05-21-2012, 09:07   #8 (permalink)
Member: 478535
2.Full erase
I wold do as this friend says.
looks like that phone had a custom firmware with a version higher than the original for 5800. full backup of pm, certs and rpl, full erase and then put back latest version, rpl, sx4 authorize/pm write! or do the "new downgrade" that automatizes all this process!
Old 05-21-2012, 09:22   #9 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
I would as well flash the eno firmware (http://www.moulnisky.com/downloads/rm356_ENO_x_2008wk42v0.033.fpsx) between the point 2 and 3
Alex
Old 05-21-2012, 14:52   #10 (permalink)
Member: 233142
Sonork: 100.1595099
Alex
Thanks
will try and will post the resultat
Old 06-04-2012, 18:17   #11 (permalink)
Member: 233142
Sonork: 100.1595099
Problem solved
1 backup RPL,PM
2 Full erase
3 write Eno firmware
4 write flash with same product code in phone from navifirm
5 write backup rpl
6 SX4
7 write backup pm
phone working
Thanks for all who have help me
Thanks
The Following User Says Thank You to said4 For This Useful Post:
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.42595 seconds with 12 queries
