06-29-2012, 06:11 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: manila
Member: 1595088 Status: Offline Thanks Meter: 184 | cant read sha files ce why [Solved] VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.02v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1.1023GB Avaiable Virtual Memory: 1.896GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work [Nokia C3-00 USB Phonet]: Port opened OK! MCU Version V 08.63 MCU Date 25-03-11 Product RM-614 (Nokia C3-00) Manufacturer (c) Nokia IMEI 355366049926989 Mastercode 5673763636 IMEI Spare 3A55630694299608 IMEI SV 3355630694299638F2000000 PPM V 08.63, 25-03-11, RM-614, (c) Nokia , T CNT Content: ctv PH, V 08.63, 25-03-11, RM-614, (c) Nokia PSN 76B1390AI Product Code 059C4Q2 Module Code 0204418 Basic Product Code 059D7N6 PSD 0000000000000000 LPSN 0 WLAN MAC 9420537E9B7E stock only here im try more times |
06-29-2012, 07:08 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Be sure to use the last installer and connect the mobile to a different usb port. BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
06-30-2012, 05:05 | #3 (permalink) |
Member: 1595088 Status: Offline Thanks Meter: 184 | now cant write pm why what happen in cyclone Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.12.8.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Failed to read info -> Phone not detected Failed to read info -> Phone not detected Failed to Write PM -> Phone not detected |
06-30-2012, 05:13 | #4 (permalink) |
Member: 1595088 Status: Offline Thanks Meter: 184 | problem solve why you dont say to update your box frimware Product Code: 0569948 This is Valid BB5 Product No variant found with given Product Code, selecting first one [120,0] Written, Length: 944 bytes, Status: OK [120,1] Written, Length: 80 bytes, Status: OK [120,2] Written, Length: 20 bytes, Status: OK [120,3] Written, Length: 112 bytes, Status: OK Write PM Finished, Record written OK: 4, Record written NOT OK: 0 [120,0] Written, Length: 944 bytes, Status: OK [120,1] Written, Length: 80 bytes, Status: OK [120,2] Written, Length: 20 bytes, Status: OK [120,3] Written, Length: 112 bytes, Status: OK Write PM Finished, Record written OK: 4, Record written NOT OK: 0 |
06-30-2012, 06:48 | #5 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | Cos the basic rule before opening a support thread is to be sure to use the lst software and firmware version As well with partial logs is impossible for us to understand which version of firmware you use. Anyway happy it is sorted BR Alex |
Eeprom reading | KLImax | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-22-2011 15:55 |
5110 ver 5.24 scr file | friendlypirate | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 11-06-1999 05:04 |
how can we use *.scr files to unlock | shadow77 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-27-1999 03:13 |
Silly question!! Why is it impossible to read out the mastercode of Nokia phones???? | MyKe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-26-1999 14:31 |
