06-29-2012, 21:50 | #1 (permalink) |
Freak Poster Join Date: Sep 2010 Location: VeneZueLa
Member: 1391333 Status: Offline Sonork: 100.1646233 Thanks Meter: 19 | Nokia 5800d RM-428 in SECURITY_TEST is FAILED! [Solved] This time I have a Nokia 5800d RM-428 with the problem of SECURITY_TEST is FAILED! I present here the log of "Read info"..... Code: MCU Version V ICPR72_08w47 MCU Date 24-11-08 Product RM-428 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI xxxxxxxxxxxxxxx Mastercode 47407142 IMEI Spare 3A95430802210402 IMEI SV 3395430802210402F2000000 PSN CZB781641 Product Code 0577218 Basic Product Code 0559231 PSD 0000000000000000 LPSN 0 WLAN MAC 00247C1D9206 RETU 16 TAHVO 22 AHNE 11 HW 1101 RFIC 17141715 DSP sangalo_wmps.ICPR72_08w47 Simlock Server SIMLOCK SERVER Simlock Key 2440700000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [1,2] State: OPENED Type: GID Data: FFFF Simlock [1,3] State: OPENED Type: GID Data: FFFF Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [2,2] State: OPENED Type: GID Data: FFFF Simlock [2,3] State: OPENED Type: GID Data: FFFF Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [3,2] State: OPENED Type: GID Data: FFFF Simlock [3,3] State: OPENED Type: GID Data: FFFF Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [4,2] State: OPENED Type: GID Data: FFFF Simlock [4,3] State: OPENED Type: GID Data: FFFF Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [5,2] State: OPENED Type: GID Data: FFFF Simlock [5,3] State: OPENED Type: GID Data: FFFF Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [6,2] State: OPENED Type: GID Data: FFFF Simlock [6,3] State: OPENED Type: GID Data: FFFF Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF Simlock [7,2] State: OPENED Type: GID Data: FFFF Simlock [7,3] State: OPENED Type: GID Data: FFFF Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF searching the web tell me a PM is solved turnin 'it up ... but I miss with distindos PM and the problem persists ... I can do to solve the problem? since I've written about 3 PM and nothing ..... I can do ... thanks ... |
06-29-2012, 22:49 | #2 (permalink) |
No Life Poster Join Date: Sep 2006 Location: RETIRED ! Age: 47
Member: 348680 Status: Offline Thanks Meter: 1,273 | Just Go to "BB5 / Security" use the "Analize Security" function and FOLLOW the Instructions given by the soft. You can get te Needed PM (with 1&309 Fields) & RPL (with HWC & CCC) from here: http://ptt.4mg.com/Gsmforum/PM/ Just Download the RM-428.zip and extract the Contents to Cyclone Box\SX4 folder BR Last edited by ptt; 06-29-2012 at 23:08. |
06-29-2012, 23:07 | #3 (permalink) | |
Member: 1391333 Status: Offline Sonork: 100.1646233 Thanks Meter: 19 | Quote:
below the log of "Analyze Security" Code: Started Phone Security Analysis... MCU Version V ICPR72_08w47 MCU Date 24-11-08 Product RM-428 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI xxxxxxxxxxxxxxxx Mastercode 47407142 Reading Security Block... Security block OK and saved to "RM-428_359348020124020_29062012_053321 p.m..SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY -- SECURITY PROBLEM -- Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically) Additionaly, Checking HWC/CCC Certs... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101031103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0B500105E2740052EA8B036B43EFEE3299D8A586 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 CMT Ready! Searching for BootCode: DualLine 32Bit RAPIDOv11_2nd.fg, Type: 2nd Boot Loader, Rev: 512.12.8.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0400000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC004000000121, Samsung, ONENAND Requested Algorithm: XSR 1.5 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0040 (Samsung), Size: 256MBytes, VPP: Not Supported RAPIDOv11_XSR15_alg.fg, Type: Algorithm, Rev: 512.12.8.0, Algo: XSR 1.5 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 76A20187051C30162EE91C77AE5E6011F5F1BA61 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits HWC Looks OK! CCC Looks OK! Restarting MCU... -- SECURITY PROBLEM -- Step 3 : Analyzing Security Block "0B500105E2740052EA8B036B43EFEE3299D8A586.C0006FA2" Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... SIMLOCK FOUND AND CHECKSUM OK! PASSED! Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Analyze finished! I should do? sorry, I'm newbie to this box | |
06-29-2012, 23:10 | #4 (permalink) | |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Do as indicated: Quote:
BR | |
06-29-2012, 23:12 | #5 (permalink) |
Member: 1391333 Status: Offline Sonork: 100.1646233 Thanks Meter: 19 | I think the solution is as follows ..... Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 (if SW don't do this automatically) but in the folder C: \ Program Files \ Cyclone Box \ SX4 is not that of my model is RM-482 ... I can do? |
06-29-2012, 23:18 | #8 (permalink) | |
here gave me the error when trying to write the PM....... Code: SX4 Authorization / SD Repair Procedure Started.... "0B500105E2740052EA8B036B43EFEE3299D8A586.C0006FA2" Exists, That is good... MCU Version V ICPR72_08w47 MCU Date 24-11-08 Product RM-428 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI xxxxxxxxxxxxxxxx Mastercode 47407142 Reading Security Block... Security block OK and saved to "RM-428_359348020124020_29062012_054604 p.m..SecurityBlock.PM" SX4 Status: Not authorized (74) Started mutual authenthication with card... Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! Looking for Virgin PM In Database... Found, writing... [1,0] Written, Length: 114 bytes, Status: OK [1,2] Written, Length: 98 bytes, Status: OK [1,4] Written, Length: 110 bytes, Status: OK [1,6] Written, Length: 98 bytes, Status: OK [1,8] Written, Length: 110 bytes, Status: OK [1,13] Written, Length: 98 bytes, Status: OK [1,16] Written, Length: 98 bytes, Status: OK [1,18] Written, Length: 98 bytes, Status: OK [1,20] Written, Length: 98 bytes, Status: OK [1,24] Written, Length: 84 bytes, Status: OK [1,25] Written, Length: 4 bytes, Status: OK [1,26] Written, Length: 110 bytes, Status: OK [1,28] Written, Length: 98 bytes, Status: OK [1,29] Written, Length: 10 bytes, Status: OK [1,31] Written, Length: 98 bytes, Status: OK [1,34] Written, Length: 80 bytes, Status: OK [1,35] Written, Length: 16 bytes, Status: OK [1,37] Written, Length: 4 bytes, Status: OK [1,39] Written, Length: 36 bytes, Status: OK [1,40] Written, Length: 16 bytes, Status: OK [1,41] Written, Length: 182 bytes, Status: OK [1,42] Written, Length: 4 bytes, Status: Not accepted, Code: 20 [1,43] Written, Length: 36 bytes, Status: Not accepted, Code: 20 [1,45] Written, Length: 182 bytes, Status: Not accepted, Code: 20 [309,0] Written, Length: 4 bytes, Status: Not accepted, Code: 20 [309,1] Written, Length: 2 bytes, Status: Not accepted, Code: 20 [309,2] Written, Length: 12 bytes, Status: Not accepted, Code: 20 Failed to Write PM -> [309,4] Critical Error -1 occured is due to this error? | |
06-29-2012, 23:43 | #11 (permalink) |
Member: 348680 Status: Offline Thanks Meter: 1,273 | Close the Soft, download the Zip file again, extract the contents to SX4 folder (overwrite / delete the 2 previously downloaded files, RM-428.pm & RM-428.rpl) repeat the process |
06-30-2012, 00:11 | #13 (permalink) | |
Member: 348680 Status: Offline Thanks Meter: 1,273 | I dont think so.... Check this post from Alex: http://forum.gsmhosting.com/vbb/4832326-post3.html Quote:
The Following User Says Thank You to ptt For This Useful Post: |
06-30-2012, 00:18 | #14 (permalink) |
Member: 1391333 Status: Offline Sonork: 100.1646233 Thanks Meter: 19 | achieved and friends solve the problem!! I explain ... the trick was to place a backup of the RPL of the cell and replace it on the. rar you sent me and copy the folder with the name SX4 RM-408 and I am super good ... and on and normal ... thank you very much for the help mates .. experience and stay there hehehehe Code: SX4 Authorization / SD Repair Procedure Started.... "0B500105E2740052EA8B036B43EFEE3299D8A586.C0006FA2" Exists, That is good... MCU Version V ICPR72_08w47 MCU Date 24-11-08 Product RM-428 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI xxxxxxxxxxxxxxxxxxxxxx Mastercode 47407142 Reading Security Block... p.m..SecurityBlock.PM" SX4 Status: Not authorized (74) Started mutual authenthication with card... Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! Looking for Virgin PM In Database... Found, writing... [1,0] Written, Length: 114 bytes, Status: OK [1,2] Written, Length: 98 bytes, Status: OK [1,4] Written, Length: 110 bytes, Status: OK [1,6] Written, Length: 98 bytes, Status: OK [1,8] Written, Length: 110 bytes, Status: OK [1,13] Written, Length: 98 bytes, Status: OK [1,16] Written, Length: 98 bytes, Status: OK [1,18] Written, Length: 98 bytes, Status: OK [1,20] Written, Length: 98 bytes, Status: OK [1,24] Written, Length: 84 bytes, Status: OK [1,25] Written, Length: 4 bytes, Status: OK [1,26] Written, Length: 110 bytes, Status: OK [1,28] Written, Length: 98 bytes, Status: OK [1,29] Written, Length: 10 bytes, Status: OK [1,31] Written, Length: 98 bytes, Status: OK [1,34] Written, Length: 80 bytes, Status: OK [1,35] Written, Length: 16 bytes, Status: OK [1,37] Written, Length: 4 bytes, Status: OK [1,39] Written, Length: 36 bytes, Status: OK [1,40] Written, Length: 16 bytes, Status: OK [1,41] Written, Length: 182 bytes, Status: OK [1,42] Written, Length: 4 bytes, Status: OK [1,43] Written, Length: 36 bytes, Status: OK [1,45] Written, Length: 182 bytes, Status: OK [309,0] Written, Length: 4 bytes, Status: OK [309,1] Written, Length: 2 bytes, Status: OK [309,2] Written, Length: 12 bytes, Status: OK [309,4] Written, Length: 12 bytes, Status: OK [309,5] Written, Length: 12 bytes, Status: OK [309,7] Written, Length: 12 bytes, Status: OK [309,8] Written, Length: 12 bytes, Status: OK [309,17] Written, Length: 12 bytes, Status: OK Write PM Finished, Record written OK: 32, Record written NOT OK: 0 Started Phone Security Analysis... MCU Version V ICPR72_08w47 MCU Date 24-11-08 Product RM-428 (Nokia 5800 XpressMusic) Manufacturer (c) Nokia IMEI xxxxxxxxxxxxxx Mastercode 47407142 Reading Security Block... p.m..SecurityBlock.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block "0B500105E2740052EA8B036B43EFEE3299D8A586.C0006FA2" Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... SIMLOCK FOUND AND CHECKSUM OK! PASSED! Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! |
The Following User Says Thank You to kardel For This Useful Post: |
