Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 02-26-2010, 09:49   #1 (permalink)
aminnovelty's Avatar
Member: 566122
Thanks Meter: 322
Nokia 7210 on contact service [SOLVED]
Dear supporter i have one set 7210 which is on contact service . I never use cyclone before inorder to solve this problem , anybody can guide me HOW TO RESOLVE THIS PROBLEM and as well if it got SUPER DONGLE PROBLEM , HOW TO REPAIR THIS ? Plz guide step by step thanks alot .
Old 02-26-2010, 10:05   #2 (permalink)
Member: 782183
Smile
just tick the SD repair
Old 02-26-2010, 10:13   #3 (permalink)
moulnisky's Avatar
Member: 947561
Thanks Meter: 14,052
a) Unlock it using the RPL method
b) Click on SX4 auth
c) go in the tab common info and click on write PM
d) select a PM 1 and 309 to write
e) Job done
Alex
Old 02-26-2010, 10:22   #4 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
click RPL calculation and press direct unlock
press REPAIR SD KEYS
than write PM1 and PM309
if still contact service
than use Clone RPL with CCC and HWC cert of same model
Old 02-26-2010, 10:24   #5 (permalink)
Member: 803963
Sonork: killer smile
Thanks Meter: 10
pls post logs! to give you the best solution....
Old 02-26-2010, 12:13   #6 (permalink)
Member: 566122
Thanks Meter: 322
e) Job done
Alex
thanks br i got my job donewith very successfully andhopeyou will keep continue your co-operation in future also.
Old 02-26-2010, 12:14   #7 (permalink)
Member: 566122
Thanks Meter: 322
@hasnain thanks a lot br for your kind reply. My job is done.
Old 02-26-2010, 12:15   #8 (permalink)
moulnisky's Avatar
Member: 947561
You are always welcome
Alex
7210s,3110c,5130c....and bb5 contact service solved by this method Dooha_Bd Nokia Hardware & Hardware Repair 15 02-24-2010 14:07
NOKIA 7210 Supernova CONTACT SERVICE akashub MXKEY Nokia Flasher and Unlocker (by Alim Hape) 8 01-31-2010 23:27
Nokia 5220 on Contact Service prince_arsalan Nokia Base Band 5 ( BB-5 ) 6 10-10-2009 17:59
nokia 7210 c contact service problem help alok gsm1 Nokia Base Band 5 ( BB-5 ) 0 09-26-2009 20:09
Nokia 2100 on Contact services lahoot Nokia Hardware & Hardware Repair 3 02-08-2006 15:50
Page generated in 0.21681 seconds with 9 queries
