11-26-2009, 07:45 | #1 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1166401 Status: Offline Thanks Meter: 5 | NOKIA 7610 rh-51 Flashing Problem When will the problem with 7610 rh-51 ends with cyclone box ? It is not supported yet ? Always showing error. Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918 Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.0C, (Nov 25 2009 03:18:28, gcc v4.3.2, RTOS V6.0.0), Type: Signed Production Application Box Serial Number: C00xxxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2008, wk27 Initializing security card... Card Serial Number: xxxxxx Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.12v PASSED MCU Voltage 3.27v PASSED Core Voltage 1.79v PASSED VBAT Voltage 1.37v PASSED VBAT Voltage 5.06v PASSED Box VPP disabled VPP Voltage 1.63v PASSED Internal Box VPP Enabled VPP Voltage 5.01v PASSED Box VPP disabled VPP Voltage 1.63v PASSED External Box VPP Enabled VPP Voltage 1.70v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Booting UPP... UPP ID: 1081 [HW_UPP_WD2_v3_1] Flashbus Write baud set to 100Kbits w3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.76.0, Algo: WD2 BT2 PLL Factor: 4 FlashChip[0]: 0x00ECDDFE @ 0x00000000, Samsung, SectorSize: 64kB, Ext: 00000121 FlashChip[1]: 0x00ECEEFE @ 0x02000000, Samsung, SectorSize: 64kB, Ext: 00000121 FlashChip[2]: 0x00EC2250 @ 0x04000000, Samsung, SectorSize: 64kB, Ext: 00000121 Signature: C60000EA750100EA780100EA7B0100EA Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits w3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00ECDDFE (128Mbits), Rev: 7.4.76.0, Algo: WD2 ALGORITHM Nominal VPP Voltage: 9V, Detected: 1.66V Flash Loading Failed -> Loader is not ready Failed to Check DCT4 Flashing Bus -> Problem with sending Flash Loader Failed to Read Security Code -> Phone not detected Booting UPP... UPP ID: 1081 [HW_UPP_WD2_v3_1] Flashbus Write baud set to 100Kbits w3_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.76.0, Algo: WD2 BT2 PLL Factor: 4 FlashChip[0]: 0x00ECDDFE @ 0x00000000, Samsung, SectorSize: 64kB, Ext: 00000121 FlashChip[1]: 0x00ECEEFE @ 0x02000000, Samsung, SectorSize: 64kB, Ext: 00000121 FlashChip[2]: 0x00EC2250 @ 0x04000000, Samsung, SectorSize: 64kB, Ext: 00000121 Signature: C60000EA750100EA780100EA7B0100EA Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits w3_amd.fia, Type: Algorithm, Target: FlashChip[0] 0x00ECDDFE (128Mbits), Rev: 7.4.76.0, Algo: WD2 ALGORITHM Nominal VPP Voltage: 9V, Detected: 4.43V Flash Loading Failed -> Loader is not ready |
7610 RH-51 or 6670 RH-68 ?? | tian | J.A.F. By Jafsupport.com | 2 | 08-03-2008 09:26 |
