Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 05-28-2012, 04:10   #1 (permalink)
Member: 1724900
nokia c2-05 success but cant unlocked
this is my log
Reading SL3 LOG File...
[Nokia USB Phonet]: Port opened OK!
MCU Version V 08.60
MCU Date 21-12-11
Product RM-724 (Nokia RM-724)
Manufacturer (c) Nokia
IMEI 351952057732528
Mastercode 6345616575
XGold213 Detected
Analyzing Profile Bits...
Phone can be NCK unlocked using KEYPAD
Phone can be NCK unlocked using FBUS
15 Digits NCK Found
Booting X-Gold via USB...
If PC Can't detect any new device, probably your phone is erased. Do following if needed:
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
Switching to RAW Mode...
[Nokia USB Flashing Generic]: Port opened OK!
Failed to Boot XGold213 -> Failed to Initialize USB Handshake
Failed to Read SL3 LOG File -> Failed to Boot XGold213
MCU Version V 08.60
MCU Date 21-12-11
XGold213 Detected
15 Digits NCK Found
1. Eject battery
2. Eject cable
3. Insert cable
4. Insert battery
5. Press power-on
X-Gold: Ready, MCU ID Block: 1FB300020303010100FF
[PBL] : Ready
[EBL] : Mode CC
[EBL] : Quantum_Bootloader_2.5_M1S1
[EBL] : Ready
Setting Baudrate to 6500000bps...
Baudrate Accepted (6500000bps)
Flash Chip 0x00EC3012, Samsung, Size: 64MBytes
Success!
i have tried to put 15 Digits NCK code into the phone but it didnt work
please help
thanks
Old 05-28-2012, 04:26   #2 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
try to reset the conters then retry using code level 7: if it fails, use code level 1
Alex
The Following User Says Thank You to moulnisky For This Useful Post:
Old 05-28-2012, 04:33   #3 (permalink)
Member: 1724900
reset
Read Security Block Problem -> Failed to read PM 308, this is critical
Counters resetted successfully
level 1-7
Failed to Calculate Level1-Level7 Codes from COD -> '' is not a valid integer value
Old 05-28-2012, 06:55   #4 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: ( Protected )
what the error msg you getting when you enter the code..
pls post Master sp code and imei to check
Old 05-28-2012, 11:16   #5 (permalink)
Member: 1724900
it said wrong code
thanks
Old 05-28-2012, 11:24   #6 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
Originally Posted by vpmelb View Post
it said wrong code
thanks
mastercode must be 15 digits.. this one is wrong.
who made the bruteforce of this mobile?
Alex
Old 05-28-2012, 12:55   #7 (permalink)
renegade's Avatar
Member: 426389
Alex
I think no one, he doesn't know about bruteforce (the mastercode posted is from "read info" log)
@vpmelb, read sticky threads like this one for instance:
Complete guide to the unlock of SL3 mobiles using oclhashcat-lite
PS.
You need super pc with capable amd graphic cards or use any sl3 server to do the job.
The Following 2 Users Say Thank You to renegade For This Useful Post:
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.34105 seconds with 11 queries
