Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 07-03-2012, 10:36   #1 (permalink)
Member: 1341279
Nokia c5-00 after flashing dead ?
I HAVE C5- 00 SET IT WAS ON BEFORE FLASHING BUT AFTER FLASHING IT IS DEAD HERE IS LOG
The Following User Says Thank You to pappusharma For This Useful Post:
Old 07-03-2012, 10:36   #2 (permalink)
Member: 1341279
Establishing Connection with Box in Main Mode...
Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic]
Initializing box...
Box Firmware: Cyclone Main Application v02.03, (Jun 1 2012 21:15:43, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012
Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs
Box Serial Number: C0005A2B
HW Revision: C, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk44
Initializing security card...
Card Serial Number: D00803B2
Card Firmware Revision: 010A
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 4.83v PASSED
MCU Voltage 3.30v PASSED
Core Voltage 1.77v PASSED
VBAT Voltage 0.01v PASSED
VBAT Voltage 4.78v PASSED
Box VPP disabled
VPP Voltage 0.02v PASSED
Internal Box VPP Enabled
VPP Voltage 4.79v PASSED
Box VPP disabled
VPP Voltage 0.04v PASSED
External Box VPP Enabled
VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
XGold/Blackberry Service Running, Counter: 100
Avaiable Physical Memory: 1.1023GB
Avaiable Virtual Memory: 1.446GB
Avaiable Pagefile: 3.1023GB
Initializing FBUS...
All initialized - Ready to work
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing rm745_081.003_prd.core.fpsx (CMT)...
Booting CMT...
[Nokia USB Flashing Generic]: Port opened OK!
Old ROM Detected
CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104
CMT_EM_ASIC_ID: 00000C35
CMT_EM_ASIC_ID: 00000C30
CMT_PUBLIC_ID: 0A700111B9DA0344F5F70FB82A7BBEC6C8C2D194
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B
CMT_BOOT_ROM_CRC: E693EF0D
CMT_SECURE_ROM_CRC: AC22615B
CMT Ready!
rm745_081.003_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
Searching for BootCode: DualLine 32Bit
RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.11.0, Algo: BB5
Using NEW BB5 FLASHING PROTOCOL
Waiting for USB Boot ROM Answer...
ROM Ret: 0xFFFD125D
ROM CMT dwAddr: 0x10004FF0
ROM CMT dwLength: 0x00627837
Seems ROM Initialized OK!
Transmission Mode Requested: Control USB, Accepted: Control USB
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0020005000000031, ST, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x0020005000000031, ST, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00200050 (ST), Size: 512MBytes, VPP: Not Supported
RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.11.0, Algo: XSR 1.6
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Transmission Mode Requested: Bulk USB, Accepted: Bulk USB
Box TX2 Data Pin set to: Service Pin 3
Waiting for FUR Client become avaiable...
FUR Avaiable!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Overriding VPP Setting, USB can't use VPP
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 5F18D62F8F3D105EEFB6633F44614F8C6DCCA7E8
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00020000-0x0003FFFF, ONENAND
EraseArea[0,CMT]: 0x00060000-0x004DFFFF, ONENAND
EraseArea[0,CMT]: 0x008E0000-0x0D3BFFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 3.110s
Writing all blocks...
TurboCache Loaded!
Writing CMT ADA Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT SOS+PMML Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT GENIO_INIT Certificate...
Writing CMT SOS*UPDAPP Certificate...
Writing CMT SOS*DSP0 Certificate...
Writing CMT LDSP Certificate...
Writing CMT SOS*ISASW Certificate...
Writing CMT SOS+CORE Certificate...
Writing CMT SOS+ROFS1 Certificate...
Programming Status OK!
All blocks written OK! Time taken 18.79s
Flashing Speed: 45316.38 kBit/S
Processing rm745_081.003_prd.core.fpsx (APE)...
Processing rm745_081.003_21.01_India_prd.rofs2.fpsx (CMT)...
rm745_081.003_21.01_India_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
Certificates OK
EraseArea[0,CMT]: 0x07C40000-0x0BD3FFFF, ONENAND
Erase taken 0.594s
TurboCache Loaded!
Writing CMT SOS+ROFS2 Certificate...
All blocks written OK! Time taken 5.407s
Flashing Speed: 49451.56 kBit/S
Processing rm745_081.003_21.01_India_prd.rofs2.fpsx (APE)...
Processing rm745_081.003_C00.01_DEFAULT_prd.rofs3.fpsx (CMT)...
rm745_081.003_C00.01_DEFAULT_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
Certificates OK
EraseArea[0,CMT]: 0x0BD40000-0x0D3BFFFF, ONENAND
Erase taken 0.219s
TurboCache Loaded!
Writing CMT SOS+ROFS3 Certificate...
All blocks written OK! Time taken 0.125s
Flashing Speed: 318.53 kBit/S
Processing rm745_081.003_C00.01_DEFAULT_prd.rofs3.fpsx (APE)...
Processing rm745_081.003_U000.000_prd.uda.fpsx (CMT)...
rm745_081.003_U000.000_prd.uda.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
Certificates OK
EraseArea[0,CMT]: 0x0D3C0000-0x1F13FFFF, ONENAND
Erase taken 4.453s
TurboCache Loaded!
All blocks written OK! Time taken 4.297s
Flashing Speed: 17663.19 kBit/S
Processing rm745_081.003_U000.000_prd.uda.fpsx (APE)...
Processing rm745_ENO_APE_ONLY_11wk02_v0.003.fpsx (CMT)...
rm745_ENO_APE_ONLY_11wk02_v0.003.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5
Certificates OK
EraseArea[0,CMT]: 0x004E0000-0x008DFFFF, ONENAND
Erase taken 0.78s
TurboCache Loaded!
Writing CMT SOS*ENO Certificate...
All blocks written OK! Time taken 0.500s
Flashing Speed: 37724.30 kBit/S
Processing rm745_ENO_APE_ONLY_11wk02_v0.003.fpsx (APE)...
Restarting MCU...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Phone not detected at USB -> Timeout, no any compatible USB device detected.
Sending User Abort Signal...
Phone not detected at USB -> User Abort
Factory defaults OK
Reading info...
Failed to read info -> Phone not detected
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
Old 07-03-2012, 11:05   #3 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: ( Protected )
Remove eno file and flash again... What's the phone status now ? Vibrate only?
Old 07-03-2012, 13:29   #4 (permalink)
Member: 1341279
yes set is only vibrate
Old 07-03-2012, 22:34   #6 (permalink)
Mr.3.'s Avatar
Member: 962029
Flash with higher version
If its same after flash with higher version
Backup all certs file
And tick new downgrade and flash it
Old 07-04-2012, 03:26   #7 (permalink)
Br.Ihsan's Avatar
Member: 1489021
Sonork: 100.1620946
whats importance new downgrade can guide with details
Old 07-04-2012, 05:35   #8 (permalink)
Crazy Poster
Member: 1537135
how new downgrade flash can guide with details cyclone .............
Old 07-04-2012, 06:01   #9 (permalink)
Mr.3.'s Avatar
Member: 962029
With new downgrade option
You don't have backup rpl,pm,certs manually cyclone will back up all automatically and erase and flash the phone and restore all backups with one click first in the world ha ?
Old 07-05-2012, 08:25   #10 (permalink)
Member: 1341279
nokia c5-00 after flashing contact retailer problem comes ?
Old 07-05-2012, 08:26   #11 (permalink)
Member: 1341279
after flash contact retailer comes pls help
Old 07-05-2012, 08:37   #12 (permalink)
Member: 1175029
Dear Br.
U 1st Chek Self Test
& Send Screenshot
I Will Help U.............
Old 07-05-2012, 10:00   #13 (permalink)
Mr.3.'s Avatar
Member: 962029
did you restore PM files?
did you repair SD?
Old 07-06-2012, 06:07   #14 (permalink)
Member: 1341279
no i flash only by usb
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.39896 seconds with 11 queries
